rc4flying
PA, USA Status: offline
quote:
ORIGINAL: off2fly Joe looks good to me.I'm going to give it a try on mine.What kind of range check do you get?Did you see qq's recommended range check on horizons site?I'm going to try it on mine if i ever finish it,problems problems,I was trying to set up my pull pull today and the geometry is off,It appears i did'nt get my control horn in right,that not going to be easy to fix!I tried to call and email qq's aircraft,no response.This is when i wish i waited for the aeroworks Yak to come out.DAWG.I guess ill put a drill bit in the dremal and grind the horn out and order a new one if they ever respond.I think how i bugger'd it is one side of the rudder is shaped differently than the other and using a template like in instructions will give crappy results .Hell i ain't no builder.Any ideas?Thanks, Vann Vann, Sorry to hear about the rudder problem. Can you get any pics posted. Hard to tell if I got any ideas without seeing the problem. Take one looking straight down the hingeline with rudder centered if you can. One from each side also. I know when I installed mine, I was not too happy with what I was seeing and moved the rudder horn back in the slot to have the control horn holes line up with the hinge line. Maybe if you are too far forward in the slot, you can look at drilling a new set of holes in the horn to be in line with the hinge line and the same distance out from the center on the hinge line. Just an idea. If that is where your problem is.
_____________________________
rc4flying Joe
