off2fly
VA, USA Status: offline
Reza,thanks for posting the video ,still good to watch even w/quality not being the best.Yea ive been a little disappointed with quality on this model.The covering on the wings had razor cuts(i guess) where two colors meet and seperated,so i have to try and fix that some how.The wing tube would'nt go into either wing,after sanding still very,very tight.Then the wings wouldn't fit the openings,I had to remove the balsa at the leading edge of both wing openings on fuslage and replace,where they squared the front of the wing openings i feel is a little corner cut.I don't know if the wings were not shaped correctly or the fuse not cut out correctly.Thanks ,Vann Jeter
