Help With AFPD - LOst Scenery Folder
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Flight Simulator Software >> Ikarus AeroFly Pro and Aerofly Pro Deluxe >> Help With AFPD - LOst Scenery Folder Page: [1]
Login
Help With AFPD - LOst Scenery Folder - 10/4/2007 5:49:35 PM
jeffdoan
Status: offline
Hi Mike,
Before I go deleting AFPD and reinstalling it, I wanted to check with you on possible other steps. I'm running XP SP2 and I downloaded one of the new sceneries form the IPACS website and tried to install it. It's my error as I wasn't thinking when I did this because I tried to use the AFPD Import Wizard on an exe file (duh!). Everything seemed to work fine during the install but when I went into AFPD to verify the scenery was there, all of my other standard and other sceneries were gone and I'm left with only the one that I was using before the mishap. Is there something I can do before I delete and reinstall? I have both add-ons installed as well. When I go into Program Files\IPACS\AFPD\Scenery I see multiple folders of different sceneries that I've downloaded. When I look in the AFPD folder, there are only two files: cpano and ground. Here are the other folders in the scenery directory: AFPD, carrier, castle, desert, eggeland, farmland, forestlake, fuerteventura, Garten, grassau, hanggliding, ikarus, indoor, islemail, monumnetvalley, mountlake, neurenbuerg, ohmenhausen, omahawks, pagefield, pfaffenhofen, pilsum, roettingen, romaair, rottenburg, scenery, seiser-alm, sparingfield, thefield, tyson, usa, wittgenstein, woellaner-nock.
Any insight you can provide would be greatly appreciated!
Jeff
       Post #: 1
RE: Help With AFPD - LOst Scenery Folder - 10/5/2007 1:00:51 AM
rajul
Status: offline
Hi Jeff, I do not know what exactly is the algorithm of these "import wizards" and I would avoid using them. These wizards are third party softwares and have not been created by IPACS or Ikarus. I would suggest that you refer to the model and scenery download procedures that I have stickied above this forum. For now, I think the safest route you can take is to do a complete uninstall and reinstall.
_____________________________
Mike Marks
RCU Moderator
Aerofly Support Representative http://www.aerofly.com/index.html
(in reply to jeffdoan)
       Post #: 2
RE: Help With AFPD - LOst Scenery Folder - 10/5/2007 9:18:58 AM
jeffdoan
Status: offline
Hi Mike,
This is getting a little bizarre. I did as suggested and deleted the entire AFPD using the XP control panel and then I reloaded the software and then upgraded to the latest version. When I opened the program to fly I noticed that none of the scenery files copied over. Is this something that you can provide some insight on ? I'd really like to fly this latest update...any chance you can provide some additional insight before I break down and grrom them for a job.
jeff
(in reply to rajul)
       Post #: 3
RE: Help With AFPD - LOst Scenery Folder - 10/5/2007 9:27:02 AM
rajul
Status: offline
Jeff, did you install any addon? Which patch did you install? When you mentioned that none of the scenery files copied over, do you mean that you could not see any scenery for selection in the main menu? Were you able to run AFPD in your system before?
Mike Marks
RCU Moderator
       Post #: 4
RE: Help With AFPD - LOst Scenery Folder - 10/5/2007 5:39:29 PM
jeffdoan
Status: offline
Mike, yes I did install the two Add-ons and I upgraded to the latest version 1.97xxx before I launched the program. After deinstalling and then reinstalling and updating I still cannot load any sceneries from the scenery tab....there's nothing visible to load. Yes, prior to attempting to load one of the downloadable sceneries, I had all of the other choices available to me. Any thoughts? Anyone you think I should contact? I can only fly the Winzen field at this time. Thanks for your help, it's much appreciated!
(in reply to rajul)
       Post #: 5
RE: Help With AFPD - LOst Scenery Folder - 10/7/2007 2:36:17 AM
rajul
Status: offline
Which video card are you using, and have you installed the latest card driver? Pls post your tm.log file here if possible.
Mike Marks
RCU Moderator
       Post #: 6
RE: Help With AFPD - LOst Scenery Folder - 10/7/2007 5:22:41 AM
jeffdoan
Status: offline
Hi Mike,
I'm running an NVIDA GeForce 7600 GS video card with 512MB of RAM. Yes, I do have the very latest drivers downloaded as well. IF you can tell me how to create a "tm.log" file for you I'll galdly do that as well.
(in reply to rajul)
       Post #: 7
RE: Help With AFPD - LOst Scenery Folder - 10/7/2007 5:28:11 AM
rajul
Status: offline
Hi Jeff, you'll find the tm.log file in this directory C:\Program Files\IPACS\AeroFly Professional Deluxe You can open it with any text editor like notepad or word. Copy the entire content and post it here. Thanks
Mike Marks
RCU Moderator
       Post #: 8
RE: Help With AFPD - LOst Scenery Folder - 10/7/2007 5:31:17 AM
jeffdoan
Status: offline
Hi Mike,
Thanks for the tip...here it is in all it's splendor:
tm: Library Version 4.3, Copyright (C) 1999-2006, IPACS
tm: http://www.ipacs.de
tmsystem: init random with 46758
tmsystem: cpu type=(nlogical=1) (nphysical=1) (hyper-threading disabled)
tmsystem: cpu=0 Mhz
tmsystem: memory=(physical=2047MB, avail=2047MB) (virtual=2047MB, avail=1734MB)
tmsystem: operating system=Microsoft Windows XP Version 5.1 Service Pack 2 (Build 2600) Service Pack: Service Pack 2 (Build 2600)
loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok
tmgl: loading mouse texture/mouse.tmt=ok
tmprogram: AeroFly Professional Deluxe Version 1.9.7.11, Copyright © 1998-2007 IPACS
loading configfile config/main.mcf=ok
loading player configfile config/player1.mcf=ok
loading player configfile config/player2.mcf=ok
directsound: register sound sound/beep.wav=ok
directsound: register sound sound/balloon.wav=ok
directsound: register sound sound/crash.wav=ok
directsound: register sound sound/splash.wav=ok
directsound: register sound sound/glider.wav=ok
directsound: register sound sound/glider2.wav=ok
tmgl: failed to load texture texture/cockpitmain.bmp
afdesign: init ok
directinput: init=ok
tmsystem: current monitor frequency=60
init window=(window=1920x1200) (screen=1920x1200) (32bpp) (60Hz) (fullscreen)
directsound: init=(speakerconfig=unknown) (certified) (cont.rate) (primary 16bit) (samplerates 1,192000) (128 hwbuffers) (0 hwbytes)
init pixelformat=ok
gl: vendor=NVIDIA Corporation, renderer=GeForce 7600 GS/PCI/SSE2, version=2.1.1, opengl version=2.1
gl: (viewport=4096x4096) (texturesize=4096) (stencil=8)
gl: extensions=GL_ARB_color_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_timer_query GL_EXT_vertex_array GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
wgl: extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
gl: extensions=(lockarrays) (multitexture) (pointparameter) (vertexbufferobject) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps)
wgl: extensions=(wglpixelformat) (wglrendertexture) (swapcontrol)
gl: reducing max texture size from 4096 to 2048
tmsystem: fullscreen modes=(rj-640x480x16x60) (rj-640x480x32x60) (rj-640x480x16x75) (800x600x16x60) (rj-800x600x16x75) (1024x768x16x60) (rj-1024x768x16x70) (rj-1024x768x16x75) (rj-1024x768x16x85) (1280x960x16x60) (1280x1024x16x60) (rj-1280x1024x16x75) (rj-1280x1024x16x85) (1600x900x16x60) (1600x1200x16x60) (1920x1200x16x60) (1920x1440x16x60) (rj-640x480x32x75) (rj-800x600x32x75) (rj-1024x768x32x70) (rj-1024x768x32x75) (rj-1024x768x32x85) (rj-1280x1024x32x75) (rj-1280x1024x32x85)
directinput: searching joysticks=none
tminput: searching for input devices...(1)
tmsystem: searching usb interface (0) 0=unable to open interface device
tmsystem: searching usb interface (1) 0=unable to open interface device
tmsystem: searching usb interface (0) 0=joyinterface
tmsystem: searching usb interface (1) 1=unable to open joystick device
tminput: 1 devices found
tminput: searching for input devices...(2)
tmsystem: searching dummy usb interface (0) 1=dummy radiointerface
tmsystem: searching dummy usb interface (0) 2=unable to open joystick device
tminput: checking for joystick 0=fail
tminput: 2 devices found
sim: loading scenery scenery/winzeln.geo...
sim: 1 objects 0 dynobjects
sim: start position 1 (not for helicopter)
sim: start position 2 (not for helicopter)
sim: start position 3 (not for helicopter)
sim: start position 4 (not for airplanes)
sim: load texture grid 5x5 (compress=1) named winzeln/winzeln=(5x5) (24x13) (72.00 36.00) (3.00 3.00)
sim: sphere params(3)=-1.5000 0.0000 -0.7000
sim: loading ground object scenery/winzeln/winzeln.obj=ok
sim: loading time=1272176 mus
tmcollision: 1604 triangles using 205312 bytes
tmcollision: omin=(-5000.0,-5000.0,-2.1) omax=(5000.0,5000.0,59.6) octmin=(100.0,100.0,100.0)
tmcollision: otnodes=61 otendnodes=31 otdepth=14 otlistareas=23746
tmcollision: otnmaxareas=370 otnavgareas=67 otnminsize=(78.125,78.125,61.766)
tmcollision: otareas=2088 mem=213664
tmcollision: 61 octrees, using 9272 bytes
tmcollision: total mem=222936 bytes
tmcollision: time=0.03s
tmcolldynamic: no dynamic objects or triangles
sim: loading aircraft 1 Yak55_102...
tmdairfoil: loading naca0015 ok
directsound: register sound sound/g15-3000.wav=ok
directsound: register sound sound/g15-5000.wav=ok
directsound: register sound sound/g15-10000.wav=ok
generating shadow Yak55_102shadow0=radius=2.60 bbmin=(-1.80 -1.80 -0.51) bbmax=(1.80 1.80 0.41)
sim: creating blurr=Propeller
loading input device calibration config/usbgc0.tmc=ok
loading input device calibration config/dradio0.tmc=ok
tmmusic: off
tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=30993) -36 4) 88 (5A204B26)
directsound: loading sound 1 sound/beep.wav=(in hardware) cpu=0
directsound: loading sound 2 sound/balloon.wav=(in hardware) cpu=0
directsound: loading sound 3 sound/crash.wav=(in hardware) cpu=0
directsound: loading sound 4 sound/splash.wav=(in hardware) cpu=0
directsound: loading sound 5 sound/glider.wav=(in hardware) cpu=0
directsound: loading sound 6 sound/glider2.wav=(in hardware) cpu=0
directsound: loading sound 7 sound/g15-3000.wav=(in hardware) cpu=0
directsound: loading sound 8 sound/g15-5000.wav=(in hardware) cpu=0
directsound: loading sound 9 sound/g15-10000.wav=(in hardware) cpu=0
sim: switching to simulation mode...
tmdynamics: simulation started
sim: aircraft=(-8.00,7.50,0.50), viewer=(0.00,0.00,1.65)
sim: 393 memory blocks using 51679862 bytes
saving configfile config/main.mcf=ok
saving player configfile config/player1.mcf=ok
tmdynamics: simulation stopped
directsound: loading sound 1 sound/beep.wav=already loaded
directsound: loading sound 2 sound/balloon.wav=already loaded
directsound: loading sound 3 sound/crash.wav=already loaded
directsound: loading sound 4 sound/splash.wav=already loaded
directsound: loading sound 5 sound/glider.wav=already loaded
directsound: loading sound 6 sound/glider2.wav=already loaded
directsound: loading sound 7 sound/g15-3000.wav=already loaded
directsound: loading sound 8 sound/g15-5000.wav=already loaded
directsound: loading sound 9 sound/g15-10000.wav=already loaded
directsound: shutdown
directinput: shutdown
tmsystem: 0 memory blocks:
tmsystem: shutdown, 0 memory blocks left using 0 bytes
(in reply to rajul)
       Post #: 9
RE: Help With AFPD - LOst Scenery Folder - 10/7/2007 5:33:23 AM
rajul
Status: offline
Thanks Jeff, I'll have to get back to you later on this one.
Mike Marks
RCU Moderator
       Post #: 10
RE: Help With AFPD - LOst Scenery Folder - 10/7/2007 5:34:58 AM
jeffdoan
Status: offline
Thanks! Have a GREAT rest of the weekend.
(in reply to rajul)
       Post #: 11
RE: Help With AFPD - LOst Scenery Folder - 10/8/2007 1:00:49 AM
rajul
Status: offline
Your tmlog does not reveal anything unusual. It is suspected that the "import wizard" somehow screwed up the
afpd installation. Please uninstall that tool and try to uninstall/reinstall AFPD over again. The sequence of installation should be:
AFPD
AddOn 1
StarFlight AddOn
Patch V1.9.7.11
I hope this helps
< Message edited by rajul -- 10/8/2007 1:01:14 AM >
Mike Marks
RCU Moderator
       Post #: 12
RE: Help With AFPD - LOst Scenery Folder - 10/8/2007 2:15:59 AM
jeffdoan
Status: offline
Hi Mike,
I did as suggested and I still don't have any other flying fields. Any idea where AFPD hits the registry files? Do I need to go in there to clean this up again? Thoughts?
(in reply to rajul)
       Post #: 13
RE: Help With AFPD - LOst Scenery Folder - 10/8/2007 3:21:19 PM
rajul
Status: offline
Hi Jeff, AFPD does not have any entries in the registry. Did you uninstall the import wizard? Do you know if the flying fields "disappeared" after installation of the main disk, or after the addon installation, or after running the patch? Take a look in this directory C:\Program Files\IPACS\AeroFly Professional Deluxe\scenery Are there any scenery folders in it?
Mike Marks
RCU Moderator
