rctom
TX, USA Status: offline
quote:
I have the TOC 3mm 53cc from Tom, I got mine with the plane. I think it is a great engine I am just at the end of my break in period, I just changed over the gas mixture and I changed out the 22x8 prop for a 22A Vess Prop. I had the 22B and it few great, but I am looking for a bit more pulling power in a climb. Here's a note for all my TOC-53 users. I hope to have a hop-up kit available for the TOC-53 about the end of April. The kit involves replacing the 2 petal flat reed valve with a 4 petal V-block reed. It also does away with the stripped threads in the plastic carb mount and uses an aluminum plate instead. I have built a few prototypes and tested them. Throttle response is excellent, starting is even better, there is none of the problem with changing attitudes making the mixture change, and power is greatly improved. In my testing I am getting a solid 7200 rpm with a Vess 22-A, with flashes to 7250. With the 22B I get solid 7100. With a Bunny/TBM 22-8 I get solid 6800 and have seen 6900. The ones I say are "solid" are reliable repeatable numbers, the others probably involve variables in air density and tach fluctuations. These numbers were done on a test stand here in Texas on a moderatlely broken in engine that was repaired after a crash, so it's anything but special. One flip warm starts are normal, the engine handles as well as any I've seen. This IMHO is the ideal engine, powerful, reliable, inexpensive. The hop-up kit will cost $69. It uses the standard carb that comes with the engine. I will install it on any new engine that you purchase from me for no charge, or you can easily install it yourself. It requires only simple tools, includes all necessary parts. The most complicated part will involve drill/tap the fuel pump diaphragm cover plate for 8-32. TF
