glover1482
OR, USA Status: online
I'm also beginning the assembly a WH Ultimate, and just received a 87" Suhkoi yesterday. I'm using a DA-50R with standard DA silencer, HS225MG on throttle and HS5955MG on all control surfaces. (HS5955's are a lot cheaper now, and I'll operate the choke manually.) I now have the engine mounted, servos installed including initial install of rudder pull-pull and wings glued together. Yesterday I installed the Gold-N-Rod control for the throttle, and today I intend to remove the engine and fuel proof the engine area. But maybe I'll do something else today... such is the life of a retiree. The Ultimate looks to be well built. It is certainly on a par with the best ARF's I have assembled. At my assembly pace, I'll not be flying this Ultimate for quite a while; but I looks as if it'll be a typical Ultimate flyer... which is a good thing. My remaining questions relate to mounting the RX, routing the antenna, and where I'll place the batteries. The lack of a hatch will make those steps tedious since I'll be removing/mounting the wings to establish the CG. But the size of this toy means that fully assembled it will fit in the back of my old pick-em-me-up. Now that's a feature, when compared to the Chip Hyde Double Vision which this Ultimate is replacing. Also different from the DV, I hope that this Ultimate does not run out of air under it simultaneously with me running out of piloting skills and clever ideas. Fly safe, Glover
