bobcat ply formers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> bobcat ply formers
Page: [1]
Login
bobcat ply formers - 10/6/2007 5:07:06 PM
dani2002
Status: offline
My new BOBCAT 50 arrived with 1 loose inernal ply former (the last one) with small finger preshure one mor former falls off the fiberglas body.
On close inspection i saw that the glue is very soft and sticki like apoxy that did not mix well.
I thik that i can not use this body, probably the retracts will fall off in first landing.
HELP
regards
PINHAS D LADO
       Post #: 1
RE: bobcat ply formers - 10/8/2007 5:20:31 AM
opjose
Status: offline
quote:
ORIGINAL: dani2002
HELP
regards
PINHAS D LADO
Many people are removing the formers and flying the plane without them. They do this to provide more space for Jet fuel as they are using real Turbines!!!
This puts far more stress on the body then you would with a pusher prop engine.
So it is no big deal...
If you have a loose former, either removing it altogether or epoxy it back in place.
You don't need to do anything else.
If you epoxy it back in place, mix a little acetone or alcohol with the epoxy to thin it a bit ( once it is mixed ) so that the expoxy will coat the areas well.
Except for the nose gear the retracts do not screw into the former.
If you are putting in retracts, having the former loose will actually HELP you.
It gives you the opportunity to re-inforce this area. Do so. Add more wood supports and apply epoxy liberally.
Also do this to the wing gear mounts.
this will help you have a successful first flight.
< Message edited by opjose -- 10/8/2007 5:21:27 AM >
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to dani2002)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
