RE: Another Top Flite Giant P51-D rolls onto the production line    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: Another Top Flite Giant P51-D rolls onto the production line
Page: <<   < prev  1 2 3 4 5 6 [7] 8 9   next >   >>
Login
RE: Another Top Flite Giant P51-D rolls onto the produc... - 1/20/2012 11:01 PM
Leroy Gardner
Score: 116
Last Login: 5/22/2013
From: Coeurd'''''''''''''''''''''''''''''''' ALENE,
Status: offline
Goose the lower left picture shows the angle and it is bolted to canopy at same angle as the slide member when in the track. Angle flanges are not wide enough or heavy enough to make the angle to slide in one piece so another wedge shaped piece was cut to sit on top to make joiner. You need access through bottom to do this, glue wedge in with just enough glue to hold it together. After it's set up remove screws and pull slides out then use the solvent to weld it all together then canopy cement to finish exposed edges. It's real clean when finished and strong for what it is. You can bolt canopy back in or glue it and use bolts to hold it while it dries. I went to all that trouble because if you take brace off, canopy will spread and it's holding the shape at this point and is support when open.
To get strength I made that angle out of a heavy I beam so I could drill and tap it for the 2-56 X 3/16" screws that hold things together. Front of canopy lip will have a 5/16 strip of styrene glued under it with about 1/8" exposed to fit under front screen when closed, for alignment and keep air out thus no lifting/no worry. I'm very happy with how it came out Leroy
_____________________________
Leroy Tiger Club # 53, TF 1/5th P-51 mustang
Eagle 2'' bashed Tiger 60
Hide Signatures
(in reply to v6goose)
       Post #: 151
RE: Another Top Flite Giant P51-D rolls onto the produc... - 1/23/2012 2:30 PM
v6goose
Score: 105
Last Login: 5/24/2013
Status: offline
Great!
"Oh yeah, Kiwi''s can fly..."
http://www.goosesworld.com
Hide Signatures
(in reply to Leroy Gardner)
       Post #: 152
RE: Another Top Flite Giant P51-D rolls onto the produc... - 2/17/2012 5:42 AM
Leroy Gardner
Score: 116
Status: offline
Well guys I got the cockpit done except for gauges (back order) you know how that goes? Right pannel needs the crank and regulator plus oxy. hose, what do I use, anyone know? Leroy
Heres a couple more picta, making this stuff was kinda fun once I got started and figured out how to do it.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Leroy Gardner -- 2/18/2012 3:52 AM >
Hide Signatures
       Post #: 153
RE: Another Top Flite Giant P51-D rolls onto the produc... - 2/17/2012 2:34 PM
v6goose
Score: 105
Status: offline
Hey Leroy...
Nice job!
How did you make all your switches and levers?
Hide Signatures
       Post #: 154
RE: Another Top Flite Giant P51-D rolls onto the produc... - 2/18/2012 4:23 AM
Leroy Gardner
Score: 116
Status: offline
Hi v6goose. the switches are made from 16 ga. aluminum wire. I have a pair of bare terminal pliers that will flatten the end of wire what ever length you want and then I taper the sides with a micro flat file that makes the toggle, mine are about 3/16" long. I make the ring at base by punching out 3/16" x .030 thick styrene and drill holes in center that fit wire snugly and slide them up to toggle and a tiny drop of thin CA binds them, shake off excess glue. You can bend toggle to be off / on when installed, they are glued in whatever with canopt cement from back side.
All the other parts are made from styrene sheets of various thicknesses. Trim dials are punched out with leather punch and 3 stacked up for height and bonded with solvent cement that weldes this stuff together. Eievator is cut out on scroll saw with a raised ring on top(smaller) and edges are 1/2 hole punched to serate edge. Once you get going stuff just comes to you.I'll be glad to help you on spacific things if I can. I used pictures to guide me along, they really help Leroy
Hide Signatures
       Post #: 155
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/17/2012 9:56 PM
orthobird
Score: 105
Last Login: 5/21/2013
Status: online
advice
does anyone know the largest diameter prop that could be used on a top flite P51 with the 85" wingspan?
i am referring to issues of clearance.
i am planning to use an engine that uses a 30 x 10 prop,
i do not know if this will clear it.
avoid crashing!!
Hide Signatures
       Post #: 156
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/17/2012 10:02 PM
ccostant
Score: 100
Status: offline
Just curious but what size engine will swing a 30x10 and fit within the TF P51 cowl? I'm assuming there isn't any kind of gearing involved?
Hide Signatures
(in reply to orthobird)
       Post #: 157
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/17/2012 10:13 PM
ROGER RUSSELL
Score: 115
Status: offline
quote:
ORIGINAL: cshahrdar
advice
does anyone know the largest diameter prop that could be used on a top flite P51 with the 85'' wingspan?
Are you using a BELT DRIVE?
Have a club member with a G62 using a 22" prop.
Remember to FLY HARD and LAND SOFT
Hide Signatures
       Post #: 158
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/17/2012 10:25 PM
orthobird
Score: 105
Status: online
No
No belt drive
Do you think a 30 inch prop is too big? For this plane?
avoid crashing!!
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 159
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:21 AM
ccostant
Score: 100
Status: offline
Honest answer, yes. I'm flying one with a DA50 and 22x10 prop. I've seen mostly 50cc - 62cc engines mounted in the TF P-51. I would think to swing a 30 inch prop would require an engine way over 100cc.
Hide Signatures
       Post #: 160
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:24 AM
glazier808
Score: 291
Status: offline
Not if its electric....a 65cc rimfire perhaps?
Casey
Fliteskin, Sierra, Nelson Hobby, MICKO aircraft, Getstencils, Holman Plans, VicRC, Castle Creations, Addicted to Luft
Hide Signatures
(in reply to ccostant)
       Post #: 161
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:31 AM
ccostant
Score: 100
Status: offline
Good point. Didn't consider electric. But can it really spin a 30x10 prop?
Hide Signatures
(in reply to glazier808)
       Post #: 162
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:36 AM
glazier808
Score: 291
Status: offline
Not sure about the rimfire(perhaps), but I have seen an AXI motor that can.
Casey
Hide Signatures
       Post #: 163
orthobird
Score: 105
Status: online
Do you think clearance would be an issue with a 30 inch prop?
avoid crashing!!
Hide Signatures
       Post #: 164
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:38 AM
orthobird
Score: 105
Status: online
The engine is inline
2 cylinder
100 cc engine
Gas
4 cycle
avoid crashing!!
Hide Signatures
       Post #: 165
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:39 AM
glazier808
Score: 291
Status: offline
...Just checked on the rimfire...26/12 prop for that one.
Hide Signatures
       Post #: 166
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:44 AM
glazier808
Score: 291
Status: offline
Well there ya go...a monster twin...
Dont know on clearance....probably tighter than you would like. More likly to peel the covering off and shake her to death lol
Hide Signatures
       Post #: 167
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 12:49 AM
ccostant
Score: 100
Status: offline
I'd be suprised if a 100cc engine can turn a 30x10 with any kind of RPM. But then again you won't need to. A TF P51 with a 100cc engine will be a rocket. I think it's way to much engine. Even a 85cc would be overkill.
Hide Signatures
       Post #: 168
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 2:12 AM
orthobird
Score: 105
Status: online
it has 12 hp,
p51 is reinforced
there is fiberglass in the wing center section, i have stiffen the stabs, there is tight linkage and titanium servos, i think it should handle it.
the DA 100 has 9.8 hp and turns a 28 x 10 prop
i can probably put in a 24 x 16     4 blade zinger prop
avoid crashing!!
Hide Signatures
       Post #: 169
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 2:17 AM
ccostant
Score: 100
Status: offline
It's the newly announced DA100 inline twin? Spinning a 4 blade will definitely be cool. The 24x16 should be okay for ground clearance, not sure on the 28x10.
Hide Signatures
       Post #: 170
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/18/2012 11:22 AM
orthobird
Score: 105
Status: online
avoid crashing!!
Hide Signatures
       Post #: 171
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/21/2012 6:24 AM
Leroy Gardner
Score: 116
Status: offline
" Hey Goose where are you", you need to get back here and restore your thread, it's turning into something else.
Come out, come out where ever you are, miss ya. Leroy
Hide Signatures
       Post #: 172
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/23/2012 4:28 AM
frank99
Score: 100
Last Login: 5/12/2013
Status: offline
engine mounted, dle 55 fuse covered, WILL PAY 500 4 FOR YOUR COCK PIT , have the top flight version and can get it to fit, help, pics to come thanks frank
Hide Signatures
       Post #: 173
RE: Another Top Flite Giant P51-D rolls onto the produc... - 4/23/2012 6:40 AM
Leroy Gardner
Score: 116
Status: offline
quote:
ORIGINAL: ccostant
It won't be a rocket, it'll be a pile of rubble at the end of the runway and it will not turn a 30" prop. Cripes a 170CC will only turn a32" 3 blade.
Hide Signatures
       Post #: 174
RE: Another Top Flite Giant P51-D rolls onto the produc... - 6/15/2012 5:20 AM
Leroy Gardner
Score: 116
Status: offline
"What !, did this thread die too ?, Gotta geter fired up again.
Got the rivets and lines in my plane and it's ready to paint, just waiting for humidity to drop and air temp to get in the 70"s. Finished my instrument pannel, Had to make my own gauges. Working on a 4 blade static prop for it.
Hope to see some of you back. Leroy
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 175
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.608RCU1
