RE: Walkera 1#A... it hurts being number 1
Tower Hobbies
Logged in as Guest
  Printable Version
Miniature Aircraft USA Ion-X - RTF
Seller:  1surfer
Details:   $5,000.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> RE: Walkera 1#A... it hurts being number 1
Page: <<   < prev  1 [2]
Login
RE: Walkera 1#A... it hurts being number 1 - 3/22/2008 6:14:57 AM
downunder
Status: offline
This is a "temporary" (which means it's likely to be permanent ) mod I've done to the main gear to keep it flyable until I get a new gear. Both of these gears have had teeth stripped (if you look at the bottom gear you can see the stripped teeth off to the left) so I made 3 fairly tight fitting plugs to lock the two together and align both sets of teeth so that no stripped teeth overlapped. The plugs were flared out slightly both ends so they can't slide out. The pinion gear on the motor is long enough to completely engage both sets of gears so when some stripped teeth arrive at the pinion the other gear keeps full engagement. The second gear obviously had to be hogged out in the centre for access to the drive pin.
Click to see fullsize image.
Click for fullsize
(in reply to Tucson-120%)
       Post #: 26
RE: Walkera 1#A... it hurts being number 1 - 3/25/2008 3:06:52 AM
Tucson-120%
Status: offline
Thats a good fix, that Walkera motor is a good one.
(in reply to downunder)
       Post #: 27
RE: Walkera 1#A... it hurts being number 1 - 7/30/2008 1:55:23 AM
underthefloor
Status: offline
I have a HBK2 with a 3100kv brushless but was thinking of getting a 1#a. How would you compare these two helis? Is the 1#a an upgrade or just different?
       Post #: 28
RE: Walkera 1#A... it hurts being number 1 - 7/30/2008 4:00:08 AM
Tucson-120%
Status: offline
you need a higher kv to fly the 2 cell pack the 4100 kv motor that it comes with is a good one
(in reply to underthefloor)
       Post #: 29
RE: Walkera 1#A... it hurts being number 1 - 7/30/2008 7:15:23 AM
underthefloor
Status: offline
So do you think that the 1#a is an overall better heli than a king v2?
       Post #: 30
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
