SJ .26 Weight?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> SJ .26 Weight?
Page: [1]
Login
SJ .26 Weight? - 10/9/2007 2:18:42 AM
iAlex
Status: offline
Was just curious if the 16.7 oz weight of the .46 Sport Jett was with the muffler or without?
Alex
       Post #: 1
RE: SJ .26 Weight? - 10/9/2007 5:36:33 AM
Pathous
Status: offline
Alex the web sight shows the weight with muffler spinner nut and glow plug.
Scott
_____________________________
AMA 6256
RCCA 812
(in reply to iAlex)
       Post #: 2
RE: SJ .26 Weight? - 10/9/2007 2:07:41 PM
bob27s
Status: online
quote:
ORIGINAL: iAlex
Alex
Hi Alex,
Thank you for writing.
The SJ-46, ready to fly (with muffler, glow plug) is just at 17oz. So the 16.7 is pretty close if you were to use a standard prop nut.
Engine only weight is about 13.5 oz - engines do vary a slight bit.
The prop nuts actually weight a bit more than they did 4-5 years ago. I'm not sure I compenstated for that.
For comparison, the SJ-60LX high output version (same size as the 46) weights just a bit more engine only, but has pretty much the same flying weight at 17oz because the muffler is a bit shorter/lighter.
AAC versions of the engines weight a bit less. The BSE engines tend to weight a little bit more.
Every so often there is a tiny bit of weight creep should Dub decide to increase a thickness, or change a material or something releated to durability. The current sleeve design and newer crankcases probably added a few grams I should account for.
I probably should weight some engines and update the website just to be sure. I strive to keep accurate information on there for complete, as delivered engines.
The two engine in images here were weighed recently.... for a more visible reference.
I hope this is helpful.
Bob
Since your post title might confuse some folks, let me put the mini-block engine weights here too..
BSE-25 thru BSE-35 weight between 14.0 and 14.7oz depending on engine size and whether it is AAC or ABC
and for comparison..... engine only weight
OS25FX ABN 248g (8.8 oz)
OS 32SX ABN 270g (9.5oz)
Jett BSE.30 AAC 273g (9.6 oz)
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by bob27s -- 10/9/2007 2:08:28 PM >
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
(in reply to iAlex)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
