moogly
MN, USA Status: offline
quote:
ORIGINAL: dbl8ts Thanks for the recommendation. While the APC prop is a composite electric prop (11X8.5E), the E-Flite is lighter. Concern: The E-Flite prop has an indentation in the hub for a hex nut. However, the 450 motor shaft is much wider than that opening, and it is threaded. The APC accepts the threaded shaft and backplate perfectly without the need to remove any material to make it fit the shaft. Will the E-Flite prop be safe to use after reaming so much material from the hub to get it on the shaft? Man an 11X8? I ran A 11X 3.5 APC (thay come with adapters for any sise shaft) at first and have sense down graded to a 10X6 master airscew (but what size shaft do you have 4mm ?) and it flys great pulling only around 6-7 amps avg. with 14-18amps on take off and I fly at 1/2 thottle
