RE: Amps Outboard
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
NEW MHZ Speedmaster S6 Stern Drives - price reduced!! - Kit
Seller:  Justaddwata
Details:   $500.00   |  10/30/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Amps Outboard
Page: <<   < prev  1 2 [3]
Login
RE: Amps Outboard - 2/19/2008 11:53 PM
gas pump bill
Score: 100
Last Login: 11/7/2009
Status: offline
i nead a engine cowling for the mercury engine on my baja boat. are they fiberglass or plastic? thanks bill payne
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to slivic003)
       Post #: 51
RE: Amps Outboard - 2/20/2008 1:12 AM
specialk1
Score: 100
Last Login: 11/8/2009
Status: offline
fiberglass ..they are first thing to go....what size is that OS? looks like a 40 size
_____________________________
http://www.ampsinternationalhobbies.com coming soon for all your amps restore parts
Hide Signatures
(in reply to gas pump bill)
       Post #: 52
RE: Amps Outboard - 2/20/2008 1:41 AM
gas pump bill
Score: 100
Status: offline
it says os max 46 and the shaft that goes from the engine to the lower gear drive is also missing. it was a bear to get it off of the boat. the retainers inside of the hull would not hold and there seams to be no way to servise the fuell cell or inside work like routeing throttle cables and stering cables. or serviseing fuell hoses. . thanks for the answer of fiber glass but where can we get them.?
Hide Signatures
(in reply to specialk1)
       Post #: 53
RE: Amps Outboard - 2/21/2008 1:25 AM
specialk1
Score: 100
Status: offline
I thought that guy had the cover for you ...the only repo covers's i see for sale is one eBay but i think they are only for the 3.5.. I don't right now own the 46 size only 3.5 and os 65's AMPS moters but i did just buy 2 os 46 amps one running and one for parts should be here in a week i will look at the gears and see if we can repo them ..I wonder if i can make a mold out of the cover???I know a good fiberglass shop here the do great repo work ...you should ask{ Rcollector} for help i think he has your same boat...
Click for fullsize
< Message edited by Lightfoot -- 8/17/2008 8:26 PM >
Hide Signatures
       Post #: 54
RE: Amps Outboard - 2/21/2008 9:33 AM
ocrda
Score: 100
Last Login: 10/23/2009
Status: offline
I have a guy looking at mooulding the Cowls as we speak !! We are modifying the lower tray to suit the .46 & .67 motors.
Will keep in Touch
Bob
Hide Signatures
       Post #: 55
RE: Amps Outboard - 2/21/2008 4:39 PM
gas pump bill
Score: 100
Status: offline
does any one have a blow up diagram of this amp`s mercury motor where we can tell what parts should be there and where they should go> thanks bill payne
Hide Signatures
(in reply to ocrda)
       Post #: 56
RE: Amps Outboard - 2/21/2008 10:53 PM
ocrda
Score: 100
Status: offline
Yes I have a full size exploded drawing complete with all the part numbers email me bob@ocrda.freeserve.co.uk I will try and scan it !!
I am away in Belgium until Monday but will look at it when i get back.
Bob
Hide Signatures
       Post #: 57
RE: Amps Outboard - 2/25/2008 2:39 AM
gas pump bill
Score: 100
Status: offline
i have started cleaning and polishing the motor from my baja and counting up the missing parts.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to ocrda)
       Post #: 58
RE: Amps Outboard - 3/7/2008 1:01 AM
gas pump bill
Score: 100
Status: offline
has any one made any head way getting a patern /mold of the merc cowling ? is their 2 pieces or just one ? how does the top attatch to the bottom?
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Lightfoot -- 8/17/2008 8:28 PM >
Hide Signatures
       Post #: 59
RE: Amps Outboard - 3/8/2008 4:14 PM
specialk1
Score: 100
Status: offline
it is a two piece set up ..I was looking at yours from the pic's and see that your missing 3 parts the steering bracket/ the lower half of the cowling and the cover......look at these ..ps nice bruiser...
< Message edited by Lightfoot -- 8/17/2008 8:29 PM >
Hide Signatures
       Post #: 60
RE: Amps Outboard - 3/8/2008 5:38 PM
gas pump bill
Score: 100
Status: offline
thanks specialk1 great pictures. i havent seen any of these 3 pieces that i am missing but i cant help beleiveing that they could be very easily in fiberglass. or maby even cast in aluminum. i do a bit of aluminum casting in my gas pumps and a re production of the old dooling tether car. im not sure if we could get a casting thin enough to be efective but we might. look at my gas pumps
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 61
RE: Amps Outboard - 9/25/2008 6:46 PM
Doubledog
Score: 100
Status: offline
Awesome thread that deserves a little more attention.
You never know what your faith is, until your faith has been truly tested.
Hide Signatures
       Post #: 62
RE: Amps Outboard - 10/9/2008 1:44 AM
specialk1
Score: 100
Status: offline
quote:
ORIGINAL: Doubledog
we moved it to ... http://www.rcuniverse.com/forum/fb.asp?m=7229915
Hide Signatures
(in reply to Doubledog)
       Post #: 63
RE: Amps Outboard - 6/29/2009 10:08 PM
dustrm
Score: 100
Last Login: 11/6/2009
Status: offline
Hell all, Tony Rogillio, owner of AMPS Products/International Hobbies...here to answer your questions. If you do not wish to use the forum, write me at : dustrm@msn.com .  Talk to you soon.  Best Regards, Tony
Hide Signatures
       Post #: 64
RE: Amps Outboard - 6/29/2009 10:15 PM
dustrm
Score: 100
Status: offline
I have all the molds for the engine cowls. Regards, Tony
Hide Signatures
       Post #: 65
RE: Amps Outboard - 7/27/2009 2:02 AM
specialk1
Score: 100
Status: offline
Hide Signatures
       Post #: 66
RE: Amps Outboard - 8/7/2009 1:18 PM
stealth assassin
Score: 100
Last Login: 11/1/2009
Status: offline
quote:
ORIGINAL: rcollector
Yes, I have seen a few of the bass boats, they have a metal flake gel coat finish. They do not seem to be very common . I think I have seen maybe 4-5 on ebay in the last 5 years. I have a old color catalog of the amps products and there is a picture of it in there. It is a scale model of a skeeter 175. length:38'' beam: 16''. I have several differant boats but not the bass boat. That fiberglass cover looks good, should be a lot better than the standard plastic covers. It looks like the ebay outdrive is missing the transom mount and probably the u-joint.
Where did all of the boat molds go??? None seem to be able to answer that one? Did they get trashed?
D
Hide Signatures
(in reply to rcollector)
       Post #: 67
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.953RCU1
