snellemin
TX, USA Status: offline
The cheapest way to start off, would be using a mamba 5700 system and a RJ speed dragster. The RJ vehicles will be available at towerhobbies and are basically rebadged bolinks. For crazy speeds go to lipo batteries. Convert your touring car into 2wd and use wider rear tires if you can. Your brushed motor is fine to start off with. You can dragrace with anything if you set it up right. But if you plan to compete for points, go for a purpose build dragster. Just remember, in electric brushless rules the topspeeds.
_____________________________
check out www.Hamdrl.org Snelle-RC, A123 Racer
