Getting bikes in the ROAR books -- need your help!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Motorcycles >> Getting bikes in the ROAR books -- need your help!
Page: [1]
Login
Getting bikes in the ROAR books -- need your help! - 10/11/2007 9:32:23 PM
Guidoracer
Status: offline
The ROAR Executive Committee will be meeting at the end of the month, and Dawn Sanchez, ROAR VP, will be bringing the possibility of adding 1:5-scale on-road motorcycles to the books. I've sent her and Mike Queller, ROAR Pres., a copy of the draft rules listed below, which has been distributed to all Executive Committee members for review. Basically, I used the existing BRCA rules and did a couple of minor tweaks, like adding a weight minimum for the Superbike class (a necessity in any class of racing), and bumping up the allowed displacement for 4-stroke bikes to include the O.S. FS-30. Otherwise, they are pretty well much the same.
So now I'd like you guys who want to see bikes as a ROAR-recognized racing class to send a memo to ROAR stating your support to MSanchez@cox.net">DMSanchez@cox.net. If you are a current ROAR member, please include your ID number (which also includes your ROAR region). If you aren't a ROAR member, it might be nice to say that you would certainly join if a racing class for bikes became available locally.
Thanks for you help guys, and let's see this class get in the books!
Lito Reyes
Proposed 2008 ROAR 1/5-scale On-Road Motorcycle Racing Rules
Version: Draft
Prepared by Lito Reyes, ROAR number 12-91579
1. Racing Classes:
1.1. Super Bike:
· Electric powered modified class.
· 540 class size maximum. Brushed and Brushless motors permitted.
· Minimum weight 60 oz.
· Batteries 7.4V nominal max, NiCd / NiMH 6 cells or 2 Lithium cells max
· Two speed gears are not allowed
1.2. Nitro Bike:
· Nitro powered modified class.
· Max engine size 3.5cc (0.15ci) 2 stroke, 10cc (0.30ci) 4 stroke.
· Minimum weight 68 oz.
· Fuel tank max 75cc limit.
2. Construction Rules:
2.1. The bikes must have complete bodywork including rider and all of which should be painted.
2.2. Rider must be present on motorcycle at start of race. A motorcycle that finishes a race without the rider figure will be penalized 1 lap.
2.3. The racer can complete the race in the event that the bike body/driver becomes damaged as long as that damage does not pose a risk to the other bikes or the Race Marshals.
2.4. The receiver antenna must be flexible.
2.5. Bodywork and rider cannot be trimmed in a way that detracts from the bikes scale appearance.
3. Dimensions:
3.1. Wheelbase Max 320 mm, Min 270 mm.
3.2. Front and Rear Tire Diameter Max 155 mm, Width Max 35 mm.
3.3. Front and Rear Rim Diameter Max 95 mm, Min 80 mm.
3.4. Height of bike including Rider Max 300 mm, Min 230 mm.
4. Tires:
4.1. Tires to be specifically available for 1/5 bikes and to be commercially available.
4.2. Tires must be in black rubber except for sidewall detail.
5. Racing rules:
5.1. Qualifying Heats:
· Super Bike: 5 minutes rolling start qualifying heats.
· Nitro Bike: 5 minutes rolling start qualifying heats.
· Qualifying order is established by taking the best heat result of each driver.
5.2. Mains
5.2.1. Super Bike: 7 minute Mains.
· Bikes are to be launched simultaneously in qualifying order. Prefered order of launch method is pit man, followed by rails, followed by leaned against the pit lane wall.
5.2.2 Nitro Bike: 7 minute Mains.
· Bikes are to be launched simultaneously in qualifying order by pit man.
· If a Nitro Bike engine stops during a qualifying or main round, it must be restarted from the pits and set on the track in front of pit lane, once traffic is clear.
       Post #: 1
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU1
