RE: FeiBao F-9-F Panther
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: FeiBao F-9-F Panther
Page: <<   < prev  5 6 7 8 9 10 11 12 13 [14]
Login
RE: FeiBao F-9-F Panther - 7/22/2008 2:27:45 PM
R_Belluomini
Status: offline
Chris,
I was with Joe when he had the OC Power failure. He did use a 1 amp load to check all of the batteries.
Bob
_____________________________
"LUCKY" Electro Bob
(in reply to Chris Smith)
       Post #: 326
RE: FeiBao F-9-F Panther - 7/22/2008 9:14:39 PM
Chris Smith
Status: offline
I apologize for not being clear, and sorry for interupting. My only point was that the BR-2000 can't check batteries at 1amp. That is all I'm saying.
It sounds as if Joe may be putting the batteries on 1amp discharge then looking at the meter. But the only way to do that is to hold the "start" button down for more than 3 seconds. I know of a few fellows in my local area that didn't know that. Turns out they were not checking the batteries under load after all. Just because the discharge switch is set to 1 amp does not mean that load is applied unless the start button is held more than 3 secs and the unit enters discharge mode.
Sorry for the confusion.
Chris
Fly Army
(in reply to R_Belluomini)
       Post #: 327
RE: FeiBao F-9-F Panther - 7/22/2008 9:42:50 PM
R_Belluomini
Status: offline
Chris,
Can you explain in greater detail how the BR-2000 works exactly?
That is a great point your making and I will bring it to Joe's attention and you are NOT interrupting anything in my opinion.
Sorry if I came off abrupt that was not my attention at all. I will ask Joe about this tonight.
It sounds as if Joe needs to get a simple amp meter such as a Hangar 9 unit?
When Joe checked the Turbine pack (3800 mah) after the third flight the BR-2000 indicated 6.4 volts.
Joe charged the pack prior to the 4th flight when the motor quit indicating the OC Power failure
Regards,
Bob
< Message edited by R_Belluomini -- 7/22/2008 9:56:17 PM >
"LUCKY" Electro Bob
       Post #: 328
RE: FeiBao F-9-F Panther - 7/22/2008 10:29:55 PM
Joe Dirr
Status: offline
Hi Chris,
Once again, I sincerely appreciate your concern - I know you're here to help and that's awesome! I welcome all the feedback I can get - as I don't always get it right for sure.
But, let me reaffirm that I have been 'holding' the 'on' button of the BR-2000 'until' the 'fan' comes on signifying that I am 'viewing' the battery voltage 'while' under the 'selected' amperage load - in this case 1amp was selected.
In other words, I am placing the battery in question under the selected load 'when' and 'only' when the fan comes on. Further, in general, I understand that checking batteries under a 'no load' condition (or static voltage) is simple not valid for troubleshooting purposes.
That said, I don't know if the selected 1 amp load is sufficient for testing purposes - there probably exists some formula based upon the average amp draw of the servos (while being actuated) and the number of servos used and the battery mah rating that suggests to use a determined amp 'load' for testing purposes - if you know what that might be, please let me know.
Chris, if I'm still off-base, please let me know - it won't be the first time or the last.
Thanks Chris,
Joe
       Post #: 329
RE: FeiBao F-9-F Panther - 7/23/2008 4:36:52 PM
Chris Smith
Status: offline
Joe,
I hate to talk batteries in the Panther thread, but if no one minds I'll make these the last comments in hopes of helping.
Since you know to hold the button long enough for the blue backlight indicating discharge mode, you should be ok.
Using discharge mode is sort of a round-about way to use the BR-2000. Cross check your results a couple of times using another quality checker to be sure. I had friends that thought they were checking the battery under load just by holding the button only long enough for a reading (red backlight) yet only 72mah load was applied. For .40-.60 size models that might be ok. It cost one of them an airplane because they thought the 6.2 was showing with the 1amp applied, yet it was not. The BR-2000 is a bit tricky. I highly recommend the Radio South battery checker for jet dudes. It has a very simple digital meter, it reads any number of cells, and has 3 load settings 500mah, 1000, and 1500mah that are applied as soon as you hit the button. It is also small and reliable.
http://www.radiosouthrc.com/ProESVTester.htm
Once you get the engine back and it checked ok. You may want to do some other checking for piece of mind. Then if there is nothing obvious, go fly.
Here's some thoughts:
I'd worry if a 6-cell 7.2 battery ever went down to 6.4 volts. Even under load could be iffy. Seems like that would be below the min volt ECU threshold too. Could indicate a bad cell. Use the 1.1-1.2 volt per cell minimum rule to indicate each cell is still ok. That battery would go into my ground toy, fuel pump battery drawer marked "not for flight". If your battery goes from a sustained 8.2V under load to around 7.2V in 2 or 3 flights that could be perfectly normal. You would have to know average flight loads to be sure, or just charge between flights to keep it simple.
For Rx batteries seems 500mah load testing should be sufficient for most jets, but you'll have to test using a device that can tell you average amps used over time of flight. Maybe 1 amp would handle worst case unless there is serious binding somewhere. The only magic formula to determine that would be a recorder in-line between Rx battery and the receiver bus during flight, or add a large safety margin to the total of amps each servo draws during set-up.
For ECUs a 1 amp test load may be ok for an ECU battery under flight load and sustained running, but it may not account for the peak loads the battery will see during engine starts with the starter motor, glow plug, etc. All depends on what amps your ECU should be using. Maybe they are really low, but my guess is they can easily approach or exceed 1 amp during engine start. The engine manufacturer should be able to tell you that. Then, if you find your ECU is demanding more, it may indicate a problem such as bad starter motor, bendix, bearings, or other inefficiencies the ECU battery is drained for. But don't assume the worst.
Maybe the ECU software ignors spike or peak loads during start, but not while running. If the battery is on the edge of a minimal charge, weak cell, or there is other intermittant in-line resistance through a connector or switch, the start sequence alone could drain it to the point of marginal amperage yet be ok voltage as far as the ECU sees in flight. Until a larger amperage demand is placed. Then amperage loads would spike and voltage would have to drop in such a case. You wouldn't know until the ECU commands a low volt shutdown due to a momentary battery brown-out. Maybe right at the point of throttle-up and smoke-on for example. The key word is "momentary" which makes troubleshooting hard.
The only way to be sure you know the normal loads your ECU battery is seeing during a flight would be to use an amp recorder in line between the battery and ECU while the engine is running. I would only do that on the ground. But do it for the time a typical flight would be such as 6-7 mins. Guys that do a lot of electric flight have these small meter/recorders that will show and log amps, voltage, watts, time, and average amps, etc. I bought mine specifically to determine what kind of battery loads my Flash with 10 high power digital servos was using. Made a dual Rx batteries believer of out of me. Dual batteries drops the load on each battery in half. So duals are not just good for redundancy. They also help minimize or eliminate brown-outs which probably happens in jets more than we know. We tend to blame the radio RF or engines. I have not used the recorder for looking at ECU batteries, but now I'm curious.
What's hard to account for is battery cell quality and impedance. Some of the larger sub-C and C-cell sizes used in cheaper packs have internal chemistry and impedance characteristics that can act as a choke point when loads spike. Again, the best way to account for that is always top-off the battery between flights and use a good battery checker.
Let's hope the engine checks out ok. That way you can concentrate on the battery and installation troubleshooting. You may never find the smoking gun. But it helps to know you've checked things out. ECUs are like any other computer. Sometimes they do unexplained things and need a re-boot. Luckily those instances are rare.
Good luck,
Chris
Fly Army
(in reply to Joe Dirr)
       Post #: 330
RE: FeiBao F-9-F Panther - 7/23/2008 8:52:45 PM
Joe Dirr
Status: offline
Chris,
Thanks for the good information on batteries. I appreciate your time to explain - I understood each point made.
At this point, I will wait for the results from JetCat to see what they have to report about the turbine and the ECU battery, which they already believe is 'suspect' - as do I.
I'll post the results to this thread as soon as I hear.
Thanks a bunch!
Joe
       Post #: 331
RE: FeiBao F-9-F Panther - 7/30/2008 1:33:24 AM
Joe Dirr
Status: offline
Hi Dom,
I spoke to Bob Wilcox today, who reported that they could not find anything specifically wrong with my Titan. They did however, update the ECU software/firmware, which according to Bob makes the ECU less susceptible to 'Power Failures' due to static discharges etc.
I then asked about the 7.2 volt 3800mah battery, again there was nothing conclusive found wrong. Bob indicated that of the 3800 packs that they found defective none of them would hold close to the expected 3800mah charge. In other words, if at any point the pack held close to 3800mah the pack was deemed 'good'- as did mine.
We then discussed the 'anti-static' liquid, which Bob highly recommends as a preventative measure - I know that you are 'not' using this and are having great success, so I will hold off for the time being and see what happens.
As I mentioned before, I will re-route the servo leads, add the 'aux' lead between the ECU and receiver, double-check my receiver batteries and press-on!
I should have the Titan back by Friday or Monday at the latest.
I'll keep you posted from here.
Joe
(in reply to MaJ. Woody)
       Post #: 332
RE: FeiBao F-9-F Panther - 7/30/2008 11:40:53 AM
MaJ. Woody
Status: online
Sounds good Joe.
Best of luck. Just an FYI, I have the 3800 Mah Nimh pack from Jetcat and I regularly fly 5-6 flights between charges with no problem. I guess I have one of the good ones.
Dom
Team FeiBao
       Post #: 333
RE: FeiBao F-9-F Panther - 9/22/2008 5:44:25 PM
V2PLUS10
Status: offline
quote:
ORIGINAL: MaJ. Woody
Thank you for the compliment and good luck with the build. You are using the same power plant and Radio as me so my build can be a solid resource for you. I always ask myself why I go through all the trouble to document my building and if anyone really cares but you answered my question. I have learned a lot from these forums and like to give back when I can.
Dom
Hi Dom,
This seems as good a place as any to compliment you on your fine model and the skill with which you are assembling it. I am new to jets and have not yet ordered one, but I am gaining invaluble knowledge from your thread......now I'm learning just what I'm in for ...I can't wait!!
Randy
       Post #: 334
RE: FeiBao F-9-F Panther - 9/22/2008 8:10:12 PM
BuschBarber
Status: offline
Please do not swell his head by giving too many compliments. He already has had to sell his Ford Explorer and buy a Ford F150 4x4 just to give him more Headroom, as it is. Next thing you know he will be buying a School Bus or a Cube Van!!!
(in reply to V2PLUS10)
       Post #: 335
RE: FeiBao F-9-F Panther - 9/22/2008 9:43:52 PM
MaJ. Woody
Status: online
LOL....head room
Thanks Randy,
I'm here to help if you need it!!
Dom
Team FeiBao
(in reply to BuschBarber)
       Post #: 336
RE: FeiBao F-9-F Panther - 9/22/2008 10:03:25 PM
V2PLUS10
Status: offline
Well, I do have a question. Could you describe the fuel flow/routing while filling the tanks and also while the tanks are supplying the turbine? The multiple tank/UAT thing is a bit of a mystery...And how did you solve the clunk hanging up on the main tank's shelf problem?
Randy
       Post #: 337
RE: FeiBao F-9-F Panther - 9/23/2008 12:45:22 AM
MaJ. Woody
Status: online
The clunk problem was solved by careful positioning of the brass tube, Smaller diameter flexible tygon and heavy clunk.
The uat has 3 nipples on it. The main nipple on the cap of the bottle feeds the fuel pump. There are two others on the top of the uat. One goes to the main tank and the other is for fueling/defueling. The main tank clunk line goes to the uat. The main tank vent line goes to the clunk lines of the two saddle tanks (these are connected with a T) and the saddle tanks vent line exits the fuse bottom. This again connecting the two tanks with a T
