rcjetmodels
Joined: 8/19/2006 From: Miami, FL, USA Status: offline
quote:
ORIGINAL: icepilot I don't know if anyone else has this problem, but the hinges on one of my gear doors and the hinge on the dive brake have both broken off at the point where the ball link has been screwed in. I was able to replace the one on the gear door with one of Tam's offset hinges, but the one on the dive brake is a double version that I have not seen before. The hinges seem to be very brittle, just like the early SM hinges. Anyone else having the same problem? Wagner - can you supply the double hinges for the dive brakes? Thanks, Tor Hi Tor, This issue has been discussed here and they will take care of the problem, also I'll send you a bag o f hinges.
_____________________________
Wagner Machado Fei Bao/ JetCentral/ Yellow aircraft JetCat US authorized dealer
