RE: FeiBao F-9-F Panther
Tower Hobbies
Logged in as Guest
  Printable Version
MIBO A-10 - ARF
Seller:  jet time
Details:   $6,500.00   |  10/8/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: FeiBao F-9-F Panther
Page: <<   < prev  5 6 7 8 [9] 10 11 12 13 14   next >   >>
Login
RE: FeiBao F-9-F Panther - 1/10/2008 7:17:08 PM
chzonio
Status: offline
quote:
Mine is coming along nicely - made 3 new plywood boards - one in the nose for the batteries,
one for the Weatronic and the air valves (JetTronic) and a new main board as the one that came
with the plane was twisted and made from very poor plywood. All the boards are removable for
service and I am hoping to avoid putting any lead in the nose.
The small air bottles were painted silk matt black and placed over the large body flaps - because
of the color, they will not be noticeable if I use the flaps. The large air bottle was placed up in
the tail section. I still haven't decided if I'll use the body flaps and the dive brakes - it looks cool,
but I really like to keep things simple.. I may have to paint the large air bottle with BVM heat
shield, but from experience, the outer pipe wall on my GBooster 160-powered F-16 does not get hot.
I'd recommend that you do not place the air bottles near the hot side of the jet...The last thing you want is a bottle charged to 100 psi get hot.
(in reply to icepilot)
       Post #: 201
RE: FeiBao F-9-F Panther - 1/10/2008 7:53:56 PM
icepilot
Status: offline
In my SM F-15 the air bottles were alongside the pipe, and I never had a problem with that.
If the temperature rises 30-40 degrees back there, that's no more than the sun will heat the
inside of the plane on a summer day. I only use 55-60 psi in my planes and will have a lot of
margin - even so, I will place a thin steel plate under the large bottle just to be on the safe side.
Tor
(in reply to chzonio)
       Post #: 202
RE: FeiBao F-9-F Panther - 1/12/2008 9:37:56 PM
MaJ. Woody
Status: online
I will be testing my new 12FGA in my new E-Flight Taylorcraft tomorrow. I'll let you know how it goes. If all is well, this receiver will go into my Panther. I'll get some final install photos of the receiver when I'm done.
Dom
Dom
_____________________________
Dom
Team FeiBao
       Post #: 203
RE: FeiBao F-9-F Panther - 1/13/2008 10:08:47 PM
MaJ. Woody
Status: online
Hi Guys.
I tested my new 12 FGA and also new E-Flight Taylorcraft today.
I performed a range check using the range check function on the transmitter. This is supposed to limit the TX power and simulate long distances under normal power. I went out to about 150 feet and had total control. I even turned my back to the aircraft and still had total control. You are not supposed to have control in this configuration but I did. Next I test flew the T-Craft. What a sweet bird. The model needed zero trim!!! It does it all….every aerobatic maneuver you can think of. Well I put on 4 flights at three different locations. Each flight included a range test where I climbed up to aprox 600 feet or higher and out at least that far. I could barley see the airplane I was so high and far. Total rock solid control. Each of my selected test sites featured different obstacles. At one site I flew behind a baseball backstop that was made of metal fence and extended upward of 30 feet. I also flew behind trees and over power lines and even between a brick building and a large roll off dumpster. Rock solid everywhere every time. I will continue to test fly this radio in every horrible environment I can find then put it into my Panther. I will then install the next new Receiver and repeat until all my jets have the new FASST on board. The pictures show how I have the receiver mounted. I never considered that I have the antenna’s mounted right on top of the metal pushrods but it was obviously not a problem. I can say that I currently have 100% confidence in this system. I will keep you updated as my testing continues.
Dom
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Dom
Team FeiBao
(in reply to MaJ. Woody)
       Post #: 204
RE: FeiBao F-9-F Panther - 1/13/2008 11:22:33 PM
jetnuno
Status: online
Hi Dom
Are you using a powerbox in your Panther? I understand that you are using the 3050 in all surfaces. These should be 7, right? Plus the standars for the air valves.
How many Amps. can the Fasst handle?
Nuno
       Post #: 205
RE: FeiBao F-9-F Panther - 1/13/2008 11:27:48 PM
MaJ. Woody
Status: online
Hi Nuno.
I use two 6V 1950 Mah Nimh packs and two HD switches. Each switch is plugged into a different port in the RX. No regulator. Less is more for me.....in my opinion any additional gadgets like matchboxes and powerboxes and regulators are another link in the chain of parts to fail.
I get my batteries from Hangtime hobbies. There is a tremendous amount of GOOD info on their site. My Nimh packs are only 4 Ohms impedance per cell so each pack can deliver 40 amps!! Running them in parallel like I do gives me nearly 4000 Mah capacity and 80 amps of current. Plenty for high servo count and high tork digital setups. I use these same packs and configuration in all my jets.
You will see many opinions on what setup is best so I would say to do lots of research and formulate your own opinion.
Dom
Dom
Team FeiBao
(in reply to jetnuno)
       Post #: 206
RE: FeiBao F-9-F Panther - 1/15/2008 12:09:53 AM
MaJ. Woody
Status: online
I completed the final installation of my receiver in the Panther today. I routed some wires a bit different to clean things up and made a neat little mount for my antennas. It is made from balsa and Dubro antenna tube that I cut to shape and then heated with a heat gun to produce the curve This puts the antennas at an optimum position in the jet. Here are a few shots of the fully assembled Panther with everything hanging. I like the shot of the business end. She is all waxed up and ready to go...............Wagner don't forget my new retracts and springs
Dom
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Dom
Team FeiBao
       Post #: 207
RE: FeiBao F-9-F Panther - 1/15/2008 12:11:56 AM
MaJ. Woody
Status: online
More.......
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Dom
Team FeiBao
       Post #: 208
RE: FeiBao F-9-F Panther - 1/15/2008 12:23:38 AM
jetnuno
Status: online
Give her a kiss for me
Good luck for the maiden
Nuno
       Post #: 209
RE: FeiBao F-9-F Panther - 1/15/2008 12:38:35 AM
MaJ. Woody
Status: online
Thank you
Dom
Dom
Team FeiBao
       Post #: 210
RE: FeiBao F-9-F Panther - 1/15/2008 10:15:59 PM
Terry Holston
Status: offline
Dom, Got any pictures of the finished cockpit installed????
Terry Holston,I Fly TGA Jets As a REP
I'm NOT speeding, I'm QUALIFYING
       Post #: 211
RE: FeiBao F-9-F Panther - 1/16/2008 12:34:23 AM
MX240
Status: offline
She is beautiful...I want one.........I want one....Hope you can put on a video of a flight.
I would want to know how she handles slowed down for a landing??
Jim
(in reply to Terry Holston) </
