RE: New SV Gassers    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: New SV Gassers Page: <<   < prev  26 27 [28] 29 30 31 32 33 34 35   next >   >>
Login
RE: New SV Gassers - 5/7/2008 11:47 PM
freeonthree
Score: 100
Last Login: 4/4/2013
Status: offline
Good verticle, wow ! , my slug weighs 15lbs, no wonder im vertically challenged. lol
_____________________________
Have you hugged your RC Plane today ?
Hide Signatures
(in reply to ca$hey)
       Post #: 676
RE: New SV Gassers - 5/7/2008 11:49 PM
freeonthree
Score: 100
Status: offline
I think my Stearman needs a 40. lol
Hide Signatures
       Post #: 677
RE: New SV Gassers - 5/7/2008 11:52 PM
ca$hey
Score: 100
Last Login: 12/21/2008
Status: offline
Yea these motors are good for a lot of different types,,,from scale like yours thru to 3D like mine
Hide Signatures
(in reply to freeonthree)
       Post #: 678
RE: New SV Gassers - 5/8/2008 12:13 AM
freeonthree
Score: 100
Status: offline
And no deadstick langings ! Gas is where it's at !
Hide Signatures
       Post #: 679
RE: New SV Gassers - 5/8/2008 1:04 AM
ozzmanace
Score: 100
Last Login: 11/10/2008
Status: offline
thanks to all for adding the weight of your planes. the nitro ultra bipe comes weighing 10 pounds. so if you guys are pulling 12-15 pound planes with this motor and your happy about it. i should be fine. as long as it has enough power to hover it will be enough for me.
Hide Signatures
       Post #: 680
RE: New SV Gassers - 5/8/2008 1:36 AM
freeonthree
Score: 100
Status: offline
My Stearman won't hover, no way ! It's just a little over scale power really, but im at 15 lbs.
Hide Signatures
(in reply to ozzmanace)
       Post #: 681
RE: New SV Gassers - 5/8/2008 5:18 AM
togatoga
Score: 106
Last Login: 7/13/2011
Status: offline
Guys, been following the thread with interest.Swore never to buy another chinese engine but hit the pay button on a sv26 in a moment of weakness. I understand that tech support is zilch and the motor has issues to say the least but I also noticed that almost everyone is happy once the bugs are ironed out.
My questions are :- do I need to do anything special before i fire it up the first time? I understand the mounting ears are the most vulnerable- would adding an aluminium plate be good or mounting direct to a ply box without the standoffs work? Is there life span for the reeds? Is 40:1 mix OK for the run in?
Thanks very much
Hide Signatures
       Post #: 682
RE: New SV Gassers - 5/8/2008 5:41 AM
freeonthree
Score: 100
Status: offline
Plug the little hole in the throttle butterfly, make sure the spark occures at 30 deg BTDC, and adding a plate is a good Idea in my opinion. Mine is sanwiched between the reeds assy and the case, and I ground off the ears. I run 100:1 full synthetic myself. I ran almost 1 tank of 32:1 petroleum based mix, and was disgusted with the oil residue on the plane, and switched to 100:1 full synthetic immediately, and so far, no mess or other issues.
Hide Signatures
(in reply to togatoga)
       Post #: 683
RE: New SV Gassers - 5/9/2008 2:40 AM
ozzmanace
Score: 100
Status: offline
johnny rotten i just watched your vid. nice plane. what was that a giles? the compititions down under are sure different than u.s. this weekend (weather permitted) i'll snap some shots of my flying field here in cherokee, north carolina. it really should be a real flight flying field. but i grew up in the mojave desert. flying when it wasn't over 120 degrees.
Hide Signatures
       Post #: 684
RE: New SV Gassers - 5/14/2008 6:11 AM
GUAIO
Score: 100
Last Login: 5/21/2013
Status: offline
just received my SV26
how do you retard the timing?? I dont know how to do it!
I ll install t his engine on a 81" AT-6 from CMP PRO
should be fun
Hide Signatures
       Post #: 685
RE: New SV Gassers - 5/14/2008 7:32 AM
freeonthree
Score: 100
Status: offline
You move the hall sensor in the direction of rotation. You should make a degree wheel, and set it so the spark occures at 30 deg BTDC. You can do it with the plug out by turnin the engine. (Static Timing)
Hide Signatures
(in reply to GUAIO)
       Post #: 686
RE: New SV Gassers - 5/15/2008 8:39 PM
togatoga
Score: 106
Status: offline
Thanks for the tips freeonthree.I just received the 26 and looks OK.A bit of paint came off the sides but i guess thats cosmetic.Overall, for the money I suppose I shouldn't quibble.The ignition looks like a rcexl clone. Engine alone weighs 985gm.The black steel muffler is kinda heavy but looks tough.
Hide Signatures
       Post #: 687
RE: New SV Gassers - 5/15/2008 8:47 PM
freeonthree
Score: 100
Status: offline
26 what ? There sold under 22 different names. Check the timing first, mine was off 10 degree's... If there's a little hole in the throttle butterfly, plug it, or it wont idle down to a useable speed. My SV26 muffler was trash, not worth tossing in the trash. Buy a slimline or other quality unit for it.
Hide Signatures
       Post #: 688
RE: New SV Gassers - 5/23/2008 8:38 AM
GUAIO
Score: 100
Status: offline
ran my SV26 today for the first time on a test bench...started right up and ran ok...at half stick and up...the engine sputters a little..could it be too rich or the timing off ?? but I think its going to be a strong runner
Hide Signatures
       Post #: 689
RE: New SV Gassers - 5/23/2008 8:51 AM
freeonthree
Score: 100
Status: offline
Make sure it's fireing at 30 degrees BTDC, and yes, if it's 4 cycling a little at low stick, thats normal. If it wont idle down enough, plug the little hole in the throttle butterfly with epoxy on both sides (one drop) each side, and use a pin to make sure they connect in the middle.
Hide Signatures
(in reply to GUAIO)
       Post #: 690
RE: New SV Gassers - 5/23/2008 5:56 PM
61ahs
Score: 100
Last Login: 9/4/2011
Status: offline
I noticed last night that HobbyCity no longer offers the SV engines, except for the 100 twin. Hmmm....... I had planned to buy the 26.
BTW, they also no longer list the DL50.
http://www.hobbycity.com/hobbycity/store/uh_listCategoriesAndProducts.asp?catname=Gas+Engines&idCategory=80&ParentCat=55&cda=3586
Rick
Hide Signatures
       Post #: 691
RE: New SV Gassers - 5/23/2008 6:31 PM
freeonthree
Score: 100
Status: offline
They recently promised us that the parts for the SV26's would be posted, yet another lie to add to the list. They never even told us where we could get parts. We don't even know who made them. I won't buy anything from them anymore. They have lousy customer service. The worst I have ever seen. They don't even answer their phones when their open.
Hide Signatures
(in reply to 61ahs)
       Post #: 692
RE: New SV Gassers - 5/23/2008 7:32 PM
togatoga
Score: 106
Status: offline
Agree with you on the customer service.They don't pick up the phone-period.Sending damaged stuff back doesn't make economical sense.I see they no longer stock the SV engines. I got mine just in the nick of time- whether lucky or not the jury is out.Spares will be a problem. I guess its going to be fly and throw away for this engine. The SPE pitts muffler fits but you need to grind off the rear fins a bit. Its much lighter and better made.
Just wondering whether this engine will be more stronger running than my SPE 26 which turns a 17x8n apc at 7400rpm.
Hobby City is run by an Aussie guy I think.
Hide Signatures
       Post #: 693
RE: New SV Gassers - 5/23/2008 9:22 PM
freeonthree
Score: 100
Status: offline
My rear bearing was very rough from new, and now my crank has some up/dn play at the rear. Time to start thinkin about pullin and measuring them. Boca will have the bearings.
I want a Zenoah G26ie eventually, but I have about $350.00 in my SV26, so im going to run it until it's wore out. I was more concerned about the reeds. I have SV50 reeds in it now.
Hide Signatures
       Post #: 694
RE: New SV Gassers - 5/23/2008 10:10 PM
freeonthree
Score: 100
Status: offline
My SV26 turns my 18x8 master airscrew classic at about 7000 rpm.
Hide Signatures
       Post #: 695
RE: New SV Gassers - 5/24/2008 1:56 AM
Starfighter
Score: 100
Last Login: 6/18/2013
Status: offline
Has any tried RC Showcase for the status of parts for the SV 26 as their website shows it's available from them.
Hide Signatures
       Post #: 696
RE: New SV Gassers - 5/24/2008 2:48 AM
freeonthree
Score: 100
Status: offline
Yeah, I just did, thanks ! I see theirs has a choke ! $225.00 is fine, if their in the USA and shipping is reasonable, for me anyway. My friend needs two for a Cessna. I see they also state the ign voltage as 4.8 to 6.7, so my 2000ma 6 volt NiHM batt is just fine. If shipping is $8.00 to $12.00 now, we'll be very happy. Thanks for the website ! Dennis
Hide Signatures
(in reply to Starfighter)
       Post #: 697
RE: New SV Gassers - 5/28/2008 3:35 AM
ozzmanace
Score: 100
Status: offline
ok i ran my 2nd engine today. runs awesome. dialed the high and low needle valves and i'm very happy. but my first engine is not so good. i have run maybe a 1/2 a gallon thru it. i've changed carbs, mufflers, gas mix., everything mentioned in this web site. the problem from the start and still is when i try to give it full gas it dies. everytime. any suggetstions? i've looked on the web for a new stock carb, or even a rebuild kit. could not find any.
Hide Signatures
       Post #: 698
RE: New SV Gassers - 5/28/2008 5:59 AM
ca$hey
Score: 100
Status: offline
New Vid ,,,still goin Strong
http://www.youtube.com/watch?v=XEgspYVJdrA&eurl=http://www.3d-downunder.com/forum/viewtopic.php?t=1272&postdays=0&postorder=asc&start=30
Hide Signatures
       Post #: 699
RE: New SV Gassers - 5/28/2008 6:52 AM
freeonthree
Score: 100
Status: offline
Open the high speed needle 1/4 turn and let me know how it runs
Hide Signatures
       Post #: 700
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.969RCU1
