Ed Cregger
GA, USA Status: offline
Troubleshoot and test your gas powered models with an FM receiver. PCM hides interference by not permitting the servos to respond to the glitches that would severely affect an FM receiver, but, with the model very close to the transmitter, the system may appear to operate normally. As the model moves away from the transmitter, it's signal strength diminishes as the distance increases. At some point, your PCM system will cease to work at all. It is best to make your model pass a ground range check with no more than a 10% loss in operating range with the engine running at various rpm settings utilizing the FM receiver. The same rules apply to an AM receiver, on the off chance that you have one in use. Once the model has been cleaned up of extraneous RF emissions and your system is working properly, by all means feel free to use a PCM receiver in place of the FM receiver. Periodically check your model's ground range with the FM receiver. Also check your ground range with an FM receiver whenever your PCM system becomes sluggish in the air. The jury is out on the new 2.4 GHz spread spectrum systems, but they have been performing well according to most folks. Still, do not get sloppy with your installation just because you are using a 2.4 GHz spread spectrum system (I'm addressing the group). Radios are radios and there isn't one in existence that doesn't perform better in a noise free environment. Ed Cregger
_____________________________
Artisan "Flying models since the Fifties - I'll get the hang of this yet!!!"
