RE: New SV Gassers
Tower Hobbies
Logged in as Guest
  Printable Version
Used Quadra 35 with Spring Starter and Muffler - RTF
Seller:  gdeezer
Details:   $140.00   |  10/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New SV Gassers
Page: <<   < prev  25 26 27 [28] 29 30 31 32 33 34   next >   >>
Login
RE: New SV Gassers - 5/7/2008 8:47:32 PM
freeonthree
Status: offline
Good verticle, wow ! , my slug weighs 15lbs, no wonder im vertically challenged. lol
_____________________________
I dont crash, I just land hard
(in reply to ca$hey)
       Post #: 676
RE: New SV Gassers - 5/7/2008 8:49:42 PM
freeonthree
Status: offline
I think my Stearman needs a 40. lol
       Post #: 677
RE: New SV Gassers - 5/7/2008 8:52:15 PM
ca$hey
Status: offline
Yea these motors are good for a lot of different types,,,from scale like yours thru to 3D like mine[)]
(in reply to freeonthree)
       Post #: 678
RE: New SV Gassers - 5/7/2008 9:13:39 PM
freeonthree
Status: offline
And no deadstick langings ! Gas is where it's at !
       Post #: 679
RE: New SV Gassers - 5/7/2008 10:04:20 PM
ozzmanace
Status: offline
thanks to all for adding the weight of your planes. the nitro ultra bipe comes weighing 10 pounds. so if you guys are pulling 12-15 pound planes with this motor and your happy about it. i should be fine. as long as it has enough power to hover it will be enough for me.
       Post #: 680
RE: New SV Gassers - 5/7/2008 10:36:36 PM
freeonthree
Status: offline
My Stearman won't hover, no way ! It's just a little over scale power really, but im at 15 lbs.
(in reply to ozzmanace)
       Post #: 681
RE: New SV Gassers - 5/8/2008 2:18:33 AM
togatoga
Status: offline
Guys, been following the thread with interest.Swore never to buy another chinese engine but hit the pay button on a sv26 in a moment of weakness. I understand that tech support is zilch and the motor has issues to say the least but I also noticed that almost everyone is happy once the bugs are ironed out.
My questions are :- do I need to do anything special before i fire it up the first time? I understand the mounting ears are the most vulnerable- would adding an aluminium plate be good or mounting direct to a ply box without the standoffs work? Is there life span for the reeds? Is 40:1 mix OK for the run in?
Thanks very much
       Post #: 682
RE: New SV Gassers - 5/8/2008 2:41:22 AM
freeonthree
Status: offline
Plug the little hole in the throttle butterfly, make sure the spark occures at 30 deg BTDC, and adding a plate is a good Idea in my opinion. Mine is sanwiched between the reeds assy and the case, and I ground off the ears. I run 100:1 full synthetic myself. I ran almost 1 tank of 32:1 petroleum based mix, and was disgusted with the oil residue on the plane, and switched to 100:1 full synthetic immediately, and so far, no mess or other issues.
(in reply to togatoga)
       Post #: 683
RE: New SV Gassers - 5/8/2008 11:40:31 PM
ozzmanace
Status: offline
johnny rotten i just watched your vid. nice plane. what was that a giles? the compititions down under are sure different than u.s. this weekend (weather permitted) i'll snap some shots of my flying field here in cherokee, north carolina. it really should be a real flight flying field. but i grew up in the mojave desert. flying when it wasn't over 120 degrees.
       Post #: 684
RE: New SV Gassers - 5/14/2008 3:11:48 AM
GUAIO
Status: offline
just received my SV26
how do you retard the timing?? I dont know how to do it!
I ll install t his engine on a 81" AT-6 from CMP PRO
should be fun
       Post #: 685
RE: New SV Gassers - 5/14/2008 4:32:59 AM
freeonthree
Status: offline
You move the hall sensor in the direction of rotation. You should make a degree wheel, and set it so the spark occures at 30 deg BTDC. You can do it with the plug out by turnin the engine. (Static Timing)
(in reply to GUAIO)
       Post #: 686
RE: New SV Gassers - 5/15/2008 5:39:07 PM
togatoga
Status: offline
Thanks for the tips freeonthree.I just received the 26 and looks OK.A bit of paint came off the sides but i guess thats cosmetic.Overall, for the money I suppose I shouldn't quibble.The ignition looks like a rcexl clone. Engine alone weighs 985gm.The black steel muffler is kinda heavy but looks tough.
       Post #: 687
RE: New SV Gassers - 5/15/2008 5:47:10 PM
freeonthree
Status: offline
26 what ? There sold under 22 different names. Check the timing first, mine was off 10 degree's... If there's a little hole in the throttle butterfly, plug it, or it wont idle down to a useable speed. My SV26 muffler was trash, not worth tossing in the trash. Buy a slimline or other quality unit for it.
       Post #: 688
RE: New SV Gassers - 5/23/2008 5:38:47 AM
GUAIO
Status: offline
ran my SV26 today for the first time on a test bench...started right up and ran ok...at half stick and up...the engine sputters a little..could it be too rich or the timing off ?? but I think its going to be a strong runner
       Post #: 689
RE: New SV Gassers - 5/23/2008 5:51:31 AM
