ca$hey
Joined: 11/30/2005 From: drouin, , AUSTRALIA Status: offline
quote:
ORIGINAL: jstanton Jhonny, I have one question. I see you are putting the SV 26 on a plane that will have a cowl. How easy is the engine to start if you cannot choke it when it is cold? The larger WT-644 carb that is used by Zenoah on their G-26 should give the engine at least 500 more RPM's with the same prop. I know this becaus I changed out a small carb on my Ryobi to one at it jump up 800 RPM. Good luck Thanks mate With the carb so close to the engine box,,I had to put a hole in the engine box,,So with a hand held valve grinding stick (with the rubber suckshion disk on the end) I can put it up the fuss inside thru the hole straight on to the back of the carb ,,,turn it over by hand till its nice and wet,,,,she will start first flip ,,very easy to start
