i figured out how to attach mattracks tracks! cheaply and easily!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> i figured out how to attach mattracks tracks! cheaply and easily!
Page: [1] 2   next >   >>
Tower Hobbies Today's Special Offer! Brands Products
Login
i figured out how to attach mattracks tracks! cheaply a... - 10/15/2007 3:18 AM
s_harn
Score: 100
Last Login: 2/19/2012
Status: offline
i figured out how to attach those radioshack mattracks to a Tmaxx! i found out that the flywheel nut that holds on the flywheel for the nitro evader ST fits into the hex slot in the tracks, AND it's screw pattern is a perfect match to the stock tmaxx tire mounting stud thingie. but anyway im gonna run by homedepot and find a nut thats about 5/16 in size with the right thread and is about 1inch long, and a bolt for the other side =3 i'll have pics up hopefully within the next week or two!
< Message edited by s_harn -- 10/16/2007 4:14 AM >
Hide Signatures
       Post #: 1
RE: i figured out how to attach mattracks tracks! - 10/15/2007 3:31 AM
arcticcatwill
Score: 100
Last Login: 5/15/2009
Status: offline
when you put them on post some pics or a video!
Hide Signatures
(in reply to s_harn)
       Post #: 2
RE: i figured out how to attach mattracks tracks! - 10/15/2007 3:47 AM
s_harn
Score: 100
Status: offline
you bet yer rump i will =D
Hide Signatures
(in reply to arcticcatwill)
       Post #: 3
RE: i figured out how to attach mattracks tracks! - 10/16/2007 1:13 AM
s_harn
Score: 100
Status: offline
i will have pics and possibly video tonight if all goes well! then i'll post the parts needed to make them fit =3
Hide Signatures
       Post #: 4
RE: i figured out how to attach mattracks tracks! - 10/16/2007 1:15 AM
s_harn
Score: 100
Status: offline
Hide Signatures
       Post #: 5
RE: i figured out how to attach mattracks tracks! - 10/16/2007 4:03 AM
s_harn
Score: 100
Status: offline
sorry for the craptastic vid but my cam sucks, hopefully this weekend i'll borrow my friend with his camcorder and record it in action.
http://youtube.com/watch?v=-Y-U3ckHZMg
List of parts needed.
1 Radioshack Hummer H2 Mattracks edition (80$)
4 10-32-3/4" coupling nuts (ace hardware 2.65 for a 6pack i do belive unless i priced it wrong at the cashier XD oops)
4 10-32-1" machine screws
some epoxy to make the tread stops.
and a dremel as always =3
First if you have a drill bit just a bit larger then the screw it'll save you lots of time, first bore out the mount holes in the tracks so the screw will fit through on all four tracks.
Then take yerself some epoxy (use the two part steel epoxy for best results) and push a good bit into the holes above n below the axel on the hub carrier and let it set up n dry and drill/tap for a 8-32 or 6-32 or just stuff them inside while it's still maluable to make the track stops so they don't flip on theselves.
While the epoxy drys you can put on the coupling nuts on to the stock tmaxx axels (they might be a lil tight but the threads stay true so don't be shy about a lil wrench force) it'll be a 5/16" nut so you can use your glowplug wrench if you don't have a socket handy =)
then install your tracks and use the 10-32 screws to hold the tracks on. (don't do like me and get self countersinks get flat head's so they don't spread the plastic n bind up)
if all went well you'll now have mattracks tracks on your Tmaxx!
Hide Signatures
       Post #: 6
RE: i figured out how to attach mattracks tracks! - 10/16/2007 4:27 AM
arcticcatwill
Score: 100
Status: offline
Cool Now I want to see the T-maxx running while their on there!
Hide Signatures
       Post #: 7
RE: i figured out how to attach mattracks tracks! - 10/16/2007 4:29 AM
s_harn
Score: 100
Status: offline
as you saw there firmly attached =3 tomarrow im gonna make the tread stops though i may do it tonight, dunno yet o.o; and they survived a 3foot drop test onto the floor, and best yet it raised the whole truck up about a inch or two and widened it almost a full inch on both sides!
< Message edited by s_harn -- 10/16/2007 4:31 AM >
Hide Signatures
       Post #: 8
RE: i figured out how to attach mattracks tracks! - 10/16/2007 4:40 AM
s_harn
Score: 100
Status: offline
also PICS!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 9
RE: i figured out how to attach mattracks tracks! - 10/16/2007 4:52 AM
arcticcatwill
Score: 100
Status: offline
You've given me inspiration to do this on my s-maxx, good thing its got 4wd
Hide Signatures
       Post #: 10
RE: i figured out how to attach mattracks tracks! - 10/16/2007 5:03 AM
s_harn
Score: 100
Status: offline
hehe =D glad i could inspire someone! though i have no idea what the hub carriers on the smaxx look like >> so i couldn't tell you how to make the track stops
Hide Signatures
       Post #: 11
RE: i figured out how to attach mattracks tracks! chea... - 10/16/2007 8:41 AM
NITROHOLICS ANONYMOUS
Score: 103
Last Login: 11/2/2010
Status: offline
video of it running would be great. Looks..... interesting
_____________________________
------------=:NITROHOLICS ANONYMOUS:=---------------
------------My job- Underwater Ceramics Technician------
Hide Signatures
       Post #: 12
RE: i figured out how to attach mattracks tracks! - 10/16/2007 1:46 PM
arcticcatwill
Score: 100
Status: offline
They should be the same as a T-maxx.....
Hide Signatures
       Post #: 13
RE: i figured out how to attach mattracks tracks! chea... - 10/16/2007 2:43 PM
zues_lil_buddy
Score: 100
Last Login: 2/20/2012
Status: offline
LOOKS AWSOME
only problem I think your going to find is the hex nuts on the pasenger side,
are going to thread them selves off the first time you punch it.
Shelf Queens Are For SISSIES lol
Hide Signatures
       Post #: 14
RE: i figured out how to attach mattracks tracks! chea... - 10/16/2007 8:12 PM
tommythecat
Score: 100
Last Login: 2/21/2012
Status: offline
I'll be interested to see how those hold up to the power and weight of the maxx. Very cool idea and nice job.
Hide Signatures
(in reply to zues_lil_buddy)
       Post #: 15
RE: i figured out how to attach mattracks tracks! chea... - 10/16/2007 11:30 PM
s_harn
Score: 100
Status: offline
it survives an eye hight drop into the floor so it's kinda sturdy so far o.O
Hide Signatures
(in reply to tommythecat)
       Post #: 16
RE: i figured out how to attach mattracks tracks! chea... - 10/16/2007 11:40 PM
s_harn
Score: 100
Status: offline
quote:
ORIGINAL: zues_lil_buddy
LOOKS AWSOME
i was thinkin that, and if i have the time and if it is a problem i MAY just drill n tap for a setscrew =3
Hide Signatures
       Post #: 17
RE: i figured out how to attach mattracks tracks! chea... - 10/16/2007 11:57 PM
Excell0602
Score: 100
Last Login: 5/7/2011
Status: offline
Looks great. Can't wait to see it running.
Replacment tracks would be expensive though!!!!
!Signature your in it put, this read to time the took you If
Hide Signatures
       Post #: 18
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 1:37 AM
RC_Basher20
Score: 100
Last Login: 7/16/2009
Status: offline
nice how fast? lmao
V-Twin E-Revo, Rustler VXL, Stampede XL-5
Hide Signatures
(in reply to Excell0602)
       Post #: 19
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 3:02 AM
s_harn
Score: 100
Status: offline
http://youtube.com/watch?v=crOmn6t34yw
http://youtube.com/watch?v=-r0REyOUefE in sand
new video of it working! it has a slight bind when goin forward, needs a bearing maybe, but this is more a proof of it working thing =D the plans are there, the challange to make it work has been met, now i employ you all to make it perfect for i have pioneered it =3
< Message edited by s_harn -- 10/17/2007 3:14 AM >
Hide Signatures
(in reply to RC_Basher20)
       Post #: 20
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 4:23 AM
zues_lil_buddy
Score: 100
Status: offline
I gotta say that is just way too cool Great work
Hide Signatures
       Post #: 21
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 5:45 AM
s_harn
Score: 100
Status: offline
pics of the maxx with the hummer body sittin on it =3 if only i had longer body posts XD
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 22
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 5:50 AM
s_harn
Score: 100
Status: offline
also thanks guys for all the awesome posts about inspiring you guys =3 makes me proud to be part of this hobby =D
Hide Signatures
       Post #: 23
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 7:56 AM
bob5429
Score: 100
Last Login: 6/25/2011
Status: offline
how does it hold up
Hide Signatures
       Post #: 24
RE: i figured out how to attach mattracks tracks! chea... - 10/17/2007 8:29 AM
sheograth
Score: 279
Status: offline
Looks like it would be a lot of fun in the snow.
RCUniverse.com | Wattflyer.com | RCUvideos.com
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
3.145RCU1
