RE: DL-50 engine
Tower Hobbies
Logged in as Guest
Users viewing this topic: adamasonyx, manuelcasaas, XtremeRaptor
  Printable Version
Used Quadra 35 with Spring Starter and Muffler - RTF
Seller:  gdeezer
Details:   $140.00   |  10/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DL-50 engine
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: DL-50 engine - 10/21/2007 12:11:08 PM
pupmeister
Status: offline
After reading through various posts in this and the previous thread Let's try again DL-50 I decided to order an Engine from DL Engines Australia on Monday and received it on Tuesday. If this engine runs as good as the service that I received, I will be one happy man, for people living in Australia I can seriously recommend ordering from them.
Although I know that I have received the latest version of this engine (version 3 I think), could somebody please tell mr what all the changes are from version to version, and why were the changes were made?
Pupmeister
(in reply to edward cobb)
       Post #: 51
RE: DL-50 engine - 10/21/2007 12:38:57 PM
Mitsu1
Status: offline
The changes were .... in no particular order: An upgrade version to the ignition module, an upgrade from the original cage type engine mounts to mount of different design, and finally on the latest version, an upgrade of the case mounting tabs that are now almost twice as thick as the original. Standard standoffs are supplied instead of the cage type mount, which results in an overall reduction in weight even with the mounting tabs being increased in thickness. There may be something I left off, but this is what I can remember.
(in reply to pupmeister)
       Post #: 52
RE: DL-50 engine - 10/21/2007 11:24:57 PM
paul5992
Status: offline
Just an update on my dl-50. It runs and starts very good. My camera on the other hand went dead.
No jammies today!
http://media.putfile.com/SD-model-yak-DL-50-24
< Message edited by paul5992 -- 10/21/2007 11:48:10 PM >
(in reply to Mitsu1)
       Post #: 53
RE: DL-50 engine - 10/21/2007 11:39:02 PM
ultimate1
Status: offline
I have soom pretty good info that the next DL you'll see is a 170 they want to beat DA to the release
(in reply to paul5992)
       Post #: 54
RE: DL-50 engine - 10/21/2007 11:59:49 PM
bubbagates
Status: offline
Hearsay is no good, please provide proof
_____________________________
Bill James
Normal is not something to aspire to, it's something to get away from
(in reply to ultimate1)
       Post #: 55
RE: DL-50 engine - 10/22/2007 1:56:31 AM
chuck l
Status: online
I just ordered my second DL50 today. Obviously I'm very happy with the first one. In talking with Bob this afternoon, I thought it might be good to share this information.
22x8 Xoar - 7200 rpm
Elev 850'
60 degrees
Bisson wrap around muffler
< Message edited by chuck l -- 10/22/2007 4:56:16 AM >
(in reply to bubbagates)
       Post #: 56
RE: DL-50 engine - 10/22/2007 3:12:43 AM
skreamer
Status: offline
I love my DL 50. I recently got a great price ($425) on the the other two letter 50 that has been the standard for years and decided to see how good they really are. Cosmeticaly prettier. Pick up more substantial. It ran well but went lean when inverted (All twelve flights). All the pilots present got a goood laugh out of that. Didn't die but am going to put the DL 50 back on and sell this other high dollar engine and buy another DL. Guess I should have taken tach readings and done side by side comparison.
(in reply to chuck l)
       Post #: 57
RE: DL-50 engine - 10/22/2007 4:24:29 AM
paul5992
Status: offline
Chuck, Are you on synthetic or still breaking in? I have the same setup and I'm getting 6950 on my xoar. Same temp and altitude. I'm running 32 to 1 Lawn boy.
Also I have a J-tec pitts muffler. Not stock.
       Post #: 58
RE: DL-50 engine - 10/22/2007 5:00:23 AM
chuck l
Status: online
paul5992,
I'm running Amsoil Dominator 50:1 and only have a couple of gallons through it at the most. Also, I made an error on the muffler on the engine, and corrected my post. The muffler is a Bisson wrap around. I will be using a Bisson side mount on the second DL50.
Chuck
       Post #: 59
RE: DL-50 engine - 10/22/2007 5:21:28 AM
Lormuhl
Status: offline
DL170? Tell us more. Im in the process of building a 46% H9 Ultimate and after talking with DA about purchasing a DA150, they said I should wait till the DA170 comes out. More info on DL170 please.
       Post #: 60
RE: DL-50 engine - 10/22/2007 10:26:30 AM
drewbags
Status: offline
quote:
ORIGINAL: craigteffe
Does anyone have a canister setup on this engine and which one would you all recomend? Also where can i purchase.
I am using the KS cannister (86V-4) with a 3W 23x8 and getting 7200rpm; that is on a fully run in engine on synthetic oil. I get mine direct from KS in Germany, but not sure if there is a distributor in your part of the world.
Here is a short clip of my RCLeague YAK54 with the DL50 - great engine, just putting engine #2 in an SD-Models 30% YAK.
http://uk.youtube.com/watch?v=5_dlAyYRTNk
(in reply to craigteffe)
       Post #: 61
RE: DL-50 engine - 10/23/2007 2:49:59 AM
edward cobb
Status: offline
Trying to start a little activity on this thread. Since it was closed and restarted their hasent been much posted. Here is my latest DL 50 mount. Choke is manual as per pull handle comming toward the front. This is held in check by a wittled down servo arm (hitec). Installed the opto remote cut off LED in the center of the servo arm (should be able to see the on light in the pictures) this is from a post by aerobob in which he installed about the same. Will provide more as the work moves along. I finally had one of the poor fitting spark plugs that were talked about on the last thread. Went to NAPA and ordered a box of 10 NGK CM-6 plugs, these are the ticket to a better fitting plug and I think I will be happier with the brand name.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to drewbags)
       Post #: 62
RE: DL-50 engine - 10/23/2007 3:15:06 AM    <
