Mitsu1
AR, USA Status: offline
The changes were .... in no particular order: An upgrade version to the ignition module, an upgrade from the original cage type engine mounts to mount of different design, and finally on the latest version, an upgrade of the case mounting tabs that are now almost twice as thick as the original. Standard standoffs are supplied instead of the cage type mount, which results in an overall reduction in weight even with the mounting tabs being increased in thickness. There may be something I left off, but this is what I can remember.
