RE: DL-50 engine
Tower Hobbies
Logged in as Guest
Users viewing this topic: mohawk, skyleader slx
  Printable Version
XYZ-50cc Gas Engine
Seller:  XYZUSA
Details:   $249.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DL-50 engine
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: DL-50 engine - 10/25/2007 1:53:52 AM
paul5992
Status: offline
I've got a video for you guys if the upload would ever get done. From tonight. Flying at the private field I go to with some friends. The dl ran perfect eccept when I hit the kill switch when I was going for the dule rates. But I got it back on befor the prop stopped spinning. You gotta listen real close for me to say I hit the switch but its in there.
(in reply to Cambo)
       Post #: 76
RE: DL-50 engine - 10/25/2007 3:40:57 AM
paul5992
Status: offline
Ok, here you go guys sd model 30% yak dl-50 combo.
http://media.putfile.com/sd-model-yak-54-dl-50-51
(in reply to paul5992)
       Post #: 77
RE: DL-50 engine - 10/25/2007 11:26:32 AM
macflyklaus
Status: offline
Thank you for answer. I wait of the answer of dlusa.
       Post #: 78
RE: DL-50 engine - 10/25/2007 5:17:27 PM
Al Lewis
Status: offline
Great job Paul, on the video and the plane! Looks like you really got it dialed in.
_____________________________
Take Offs are Optional, Landings are Really Nerve Racking!! Al Lewis AMA #821623
       Post #: 79
RE: DL-50 engine - 10/26/2007 12:04:04 AM
paul5992
Status: offline
Thanks lou, And to all of you guys for the help. This motor is unreal. On my video you can hear my blip the throttle a whole bunch trying to get it to bog or die. It won't die or bog and the throttle response is unbelievable. On my 16.5 pound yak, thats full of fuel, Its unstoppable. It hovers at about 1/4 throttle. WOW, I love it!
(in reply to Al Lewis)
       Post #: 80
RE: DL-50 engine - 10/26/2007 3:38:25 AM
Cambo
Status: offline
I guese the new shipments of the DL's arn't coming in until tomarow . So i will have to wait a little longer. I am still really excited. Predicted weight for the plane it is going in is 13.5 pounds.
       Post #: 81
RE: DL-50 engine - 10/26/2007 12:00:39 PM
paul5992
Status: offline
Cam that thing is going to be a rocket.
(in reply to Cambo)
       Post #: 82
RE: DL-50 engine - 10/26/2007 2:50:36 PM
Cambo
Status: offline
Ya, i can't wait. It should be awesome.
I ordered a slimline fuel pump yesterday as i found that the one i was using for glow was not going to work. I am wondering how i should go about filtering my fuel. With my glow planes i filter before it gets into the tank. But i saw (after a search) alot of people using these cluncks that you can get at a motorcycle shop that help with foaming and filter your fuel.
The other thing i am wondering about is the prop. I really don't have the money to buy 3-4 different props. So i really wan't to know the best wood prop under 30 bucks are going to be. I have herd nothing but BAD things from zinger but positive reviews from xoar, vess, and jxf. I was looking at the JXF props that valleyviewrc sells. I can get a 22-8 JXF wood prop predrilled for the DL and shipped for $27. Anythaughts on that.
Cameron
       Post #: 83
RE: DL-50 engine - 10/26/2007 3:23:26 PM
Walt and Sage
Status: offline
quote:
ORIGINAL: Cambo
Cameron
Cameron.
We have tried that prop and went back to the Xoar quite FAST....
A Man's Character is his Destiny.........
........AMA 38255 "PRO BRO 2344"
(in reply to Cambo)
       Post #: 84
RE: DL-50 engine - 10/26/2007 9:41:07 PM
Cambo
Status: offline
Man, i just don't know were to look with these props. How about vess? Anythaughts?
(in reply to Walt and Sage)
       Post #: 85
RE: DL-50 engine - 10/26/2007 9:54:05 PM
arobatx
Status: offline
People like the Vess 23A on the DA50, also Mezjlik 22x10 or 23x8. Good props.
I know the Mezjlik is pricey...but NICE. The Xoar props aren't too bad, behind the Vess in my opinion, but inexpensive, and perform alright.
Chad
(in reply to Cambo)
       Post #: 86
RE: DL-50 engine - 10/26/2007 11:11:53 PM
Cambo
Status: offline
Could i run that prop for the break-in also?
(in reply to arobatx)
       Post #: 87
RE: DL-50 engine - 10/27/2007 12:06:48 AM
arrow66x
Status: offline
Try the 22b for break in... about $28. Then go to the 23a...$32
(in reply to Cambo)
       Post #: 88
RE: DL-50 engine - 10/27/2007 12:11:42 AM
craigteffe
Status: offline
I run the vess 23a and i get 7100 rpm on the ground. It has great breaking, I love this prop. Ihave ran Menz, Xoar, Tbm the vess is the best. I have not run the NX but i have a friend at the field that likes them.
Craig
(in reply to Cambo)
       Post #: 89
RE: DL-50 engine - 10/27/2007 12:20:53 AM
paul5992
Status: offline
Cam I think with your 13 pound air plane you won't be unhappy with any prop. I run a xoar and anyone I've talked to loves the xoar. It pulls hard right off idle. Aerobob said that the nx brand props are very good also. The vess has very good downline breaking. If you land on a closed in runway and if it is paved you might like the vess. I fly off of grass, and my field is big and wide open. So the big pull props are great. xoar 22x8, nx 22x8, vess 22b, would be the best for break in. I don't no about jxf props, sorry.
For the fuel filter I run an inline filter just befor the fuel dot so when I fill it with fuel it pushes anything in the filter back into the tank. And I run a fuel filter on the vent line. Trying to keep crap out of the tank.
< Message edited by paul5992 -- 10/27/2007 12:47:52 AM >
(in reply to Cambo)
       Post #: 90
RE: DL-50 engine - 10/27/2007 1:24:47 AM
Al Lewis
