gr8taz nitro
MO, USA Status: offline
quote:
ORIGINAL: P47Tbolt quote:
ORIGINAL: lil-redrex Also in his pics it states its a CM6 plug, looks to me more like a 14mm plug that SV use, not a 10mm CM6. Possibly just the photo angle, but looks like the standard bigger stick through the cowl plugs that SV use with thier engines also. You are right about the spark plug.If you look at the middle pic on post 1681,you can see on the plug in the engine reads CMR on it. I looked locally for a CM-6,thought I found one,went to pic it up and it was a CMR6 NGk plug.It was a 14 mm plug with longer threads. So I am still looking locally.probably will have to order a couple. I get mine from the local O'reilly autoparts store. I think I paid $4 per plug last time I got em about a month ago. If you can't get em try your LHS if they are a horizon dealer. Horizon Hobby carries cm6 plugs now for $6.35 each now, part#EVO30013309. They're higher than a parts store, but they have em in stock now.
_____________________________
If bullets bounced off supermans chest, why did he always duck when they threw the gun at him?
