bubbagates
Joined: 5/30/2004 From: Elizabethtown, PA, USA Status: offline
Cambo, I cannot say much on the hardware for the current generation so I'll leave that to someone with a newer engine, but I will say YES, locktite everything, that's a must do for every gas plane. If you are using metal gear servos locktite the screws that hold the servo arms on as well. Not a good thing when a servo arm falls off in flight, Look at it like this, if it's metal and uses a bolt/screw locktite it. I use blue for everything but the muffler. For the muffler I use Permatex High temp gasket sealer. I just open the tube, stick the bolt in it to cover the threads and bolt on the muffler/header. I've never had one come loose doing it this way. Some use red locktite with good luck and I've seen people use the green two-part locktite as well.
_____________________________
Bill James Normal is not something to aspire to, it's something to get away from
