RE: DL-50 engine
Tower Hobbies
Logged in as Guest
Users viewing this topic: mohawk, skyleader slx
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DL-50 engine
Page: <<   < prev  69 70 [71] 72 73 74 75 76 77 78   next >   >>
Login
RE: DL-50 engine - 5/11/2008 10:24:05 PM
craigteffe
Status: offline
TBM is the worst prop that i have ever ran. Vess, NX and Menz are my favorites.
_____________________________
Craig
(in reply to jacklegchris)
       Post #: 1751
RE: DL-50 engine - 5/11/2008 10:37:45 PM
jacklegchris
Status: offline
I've been thinking abouttrying a Vess but the A,B,C has me a little messed up. Before I order one I'll have to figure that out. Maybe the 22A? This Saturday I might be able to maiden my PA Edge 540T/DL-50 Combo . Can't Wait!!!!
Click to see fullsize image.
Click for fullsize
< Message edited by jacklegchris -- 5/11/2008 10:48:54 PM >
KJV THAT''S THE BOOK FOR ME
(in reply to craigteffe)
       Post #: 1752
RE: DL-50 engine - 5/11/2008 11:33:59 PM
craigteffe
Status: offline
On that plane a 22B or a 23A would be a good choice, the nx 22X8 would also be a good prop. I have a PA edge with that same engine and it is way over powered. It is balistic.
Craig
       Post #: 1753
RE: DL-50 engine - 5/11/2008 11:49:21 PM
jacklegchris
Status: offline
Mine weighs in at 14.3 lbs without fuel. The problem I've had here is always being under powered. A 40 size plane with the top recomended engine is just not enough. I have to use 60 size engines to get the power needed say a .91 4-stroke. I'm hoping that this will not be an issue with my edge. I'm tired of always being under powered.
       Post #: 1754
RE: DL-50 engine - 5/12/2008 6:51:48 AM
bcchi
Status: offline
The two wire cable that comes with the DL is a extra lead that can be installed on your battery pack or switch harness to match the Futaba battery lead on the RCXL ignition. You probably will not need if you use all Futaba wire harness parts.
BCCHI (AMA)2500
(in reply to Test005)
       Post #: 1755
RE: DL-50 engine - 5/12/2008 6:41:09 PM
choopi
Status: offline
Greathobbies here in Canada will be selling the DL100. At $750 not bad price but I was expecting it to be a bit cheaper.
http://www.greathobbies.com/productinfo/?prod_id=DLEDL100
Eric
(in reply to bcchi)
       Post #: 1756
RE: DL-50 engine - 5/12/2008 6:47:53 PM
meridianflyer
Status: offline
It will be interesting to see What DLusa will seel them for. Just checked their web site, no price yet. If their as good as the dl50's, still cheaper than the other guys and worth the price, maybee.
(in reply to choopi)
       Post #: 1757
RE: DL-50 engine - 5/12/2008 7:55:33 PM
Bob Pastorello
Status: offline
I wrote Bob with this DL 100 question. He said "later in May", estimated price somewhere around $750. Includes two mufflers, RcExcell Dual-lead ignition. If it is as good as the 50, but double-good, then it will be well worth it, IMO.
Bob Pastorello www.rcaerobats.net
Learn from others...you can't live long enough to make all the mistakes yourself....
(in reply to meridianflyer)
       Post #: 1758
RE: DL-50 engine - 5/12/2008 10:52:25 PM
Mitsu1
Status: online
In that pic, .. looks like they have decided to make just one muffler ... and use it on both sides instead of a left and a right muffler. Looks odd.
(in reply to Bob Pastorello)
       Post #: 1759
RE: DL-50 engine - 5/12/2008 11:02:09 PM
Bob Pastorello
Status: offline
Agree it might look odd, but saving the cost of a "left" v.s. "right" may be the reason; although I have to admit, I wouldn't mind paying $50 more to have it look "proper"...
(in reply to Mitsu1)
       Post #: 1760
RE: DL-50 engine - 5/13/2008 2:46:41 AM
Bosco2
Status: offline
They are still learning how to do things in the world of industries and competition, They will learn,
I feel for the people in china at this time,
Having more fun than a human being should be allowed to have.
       Post #: 1761
RE: DL-50 engine - 5/13/2008 2:58:06 AM
Bob Pastorello
Status: offline
Yes, very true.
On a DIFFERENT topic..... just curious.... do you all drill your props in an "X" pattern so you're up against compression at 2 o'clock, or a "+" pattern, where the blade is exactly vertical (or horizontal) ??
I know my preference, and rationale, but would like to hear others????
(in reply to Bosco2)
       Post #: 1762
RE: DL-50 engine - 5/13/2008 4:10:46 AM
jacklegchris
Status: offline
personally I like the x. I tried the+ and didn't like it as much. It didn't feel to me like I was getting the full force of the flip at the +.
       Post #: 1763
RE: DL-50 engine - 5/13/2008 4:35:43 AM
Rfabbre
Status: offline
I very much perfer the X. I stand behind the plane and personally feel like I get a much stronger flip with the compression starting at 2 o'clock(10 from behind)
       Post #: 1764
RE: DL-50 engine - 5/13/2008 12:49:32 PM
FlyingGreg
Status: offline
I noticed that "+" pattern in the photo as well and had the same question. I use the "X" but don't know why. I do have a comfortable "flipping" position at about 2:00 posisiton. I wondered if there was any structural reason to drill props one way or the other. Any opinions?
...nothing in moderation...
(in reply to Rfabbre)
       Post #: 1765
RE: DL-50 engine - 5/13/2008 2:46:20 PM
3DNutZ
Status: offline
x pattern for sure
(in reply to FlyingGreg)
       Post #: 1766
RE: DL-50 engine - 5/13/2008 3:41:20 PM
