RE: DL-50 engine
Tower Hobbies
Logged in as Guest
Users viewing this topic: PJModelA, dlenginesaustralia, jacklegchris, Spadkun, Paul Wise
  Printable Version
XYZ-26cc Gas Engine by SERCE, LLC.
Seller:  XYZUSA
Details:   $209.95   |  9/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DL-50 engine
Page: <<   < prev  71 72 [73] 74 75 76 77 78 79 80   next >   >>
Login
RE: DL-50 engine - 5/16/2008 6:11:30 PM
gboulton
Status: offline
quote:
ORIGINAL: Bob Pastorello
You will be smilin'........ that will be a GREAT combo!!!!!
I'm looking forward to it...especially ince it looks like I'll get this thing done in 14 lbs or so.
_____________________________
The free man will ask neither what his country can do for him nor what he can do for his country. - Milton Friedman
(in reply to Bob Pastorello)
       Post #: 1801
RE: DL-50 engine - 5/16/2008 6:32:24 PM
Bob Pastorello
Status: offline
At 14 lbs, your face will break from the smiling............be sure to report back!
And use a good prop.... you'll be the happier, and so will the engine.
NX
Xoar
JXF
Menz
BME
NOT
Zinger
Master Airscrew
Top Flite
TBM
Just my .005 (adjusted for recession)
Bob Pastorello www.rcaerobats.net
Learn from others...you can't live long enough to make all the mistakes yourself....
(in reply to gboulton)
       Post #: 1802
RE: DL-50 engine - 5/16/2008 9:16:10 PM
gboulton
Status: offline
NX
Xoar
JXF
Menz
BME
NOT
Zinger
Master Airscrew
Top Flite
TBM
Xoar 22x8's already on the way to the LHS. Have flown Xoars exclusively on my gassers for a couple years now, actually.
       Post #: 1803
RE: DL-50 engine - 5/16/2008 11:00:54 PM
Bob Pastorello
Status: offline
       Post #: 1804
RE: DL-50 engine - 5/17/2008 3:14:53 AM
Nelvick
Status: offline
What is that? dont understand what is a standford. I am a newbbie and i am lerning english too. Sorry.
(in reply to meridianflyer)
       Post #: 1805
RE: DL-50 engine - 5/17/2008 5:02:38 AM
T.Edney
Status: offline
Does anyone know the puchout or should i say vertical pullout power with it on the extreme flight 300? I love to fly 3d and just wonted to know if it had enough punch to get u out of trouble if the problem ever occured! Thx for any advise!
< Message edited by T.Edney -- 6/10/2008 1:32:34 AM >
(in reply to Nelvick)
       Post #: 1806
RE: DL-50 engine - 5/17/2008 6:12:34 AM
Super08
Status: offline
quote:
ORIGINAL: Nelvick
Standoffs are the four aluminum rods that mount the engine to the firewall. From the pictures you posted you have the standard ones that came with the engine which are 2 11/16" long. The red ones shown in the picture of my Wagstaff 300 are custom ordered ones that are 3" long. (post 1746) Hope this helps.
Doug
If I buy one more engine it''s going to hurt more than my wallet if my wife gets ahold of it.......
       Post #: 1807
RE: DL-50 engine - 5/17/2008 6:50:34 AM
Rush7
Status: offline
T.Edney the DL 50 will be a perfect match for the EF Extra 300. I put my trusty DA on the front of my Extra when I first got it......well guess what. The genius I am damaged the sheild on the spark plug wire and fried my ignition.
I just happen to have a DL sitting on the bench waiting on me to finish my Ultimate. I put the DL in the Extra and was very suprized to find that the DL right out the box was just as strong as my fully broken in DA.
To make a long story short the DL will have no problem pulling the Extra around with authority. If you really want to make some HP get a tuned pipe.....MTW RE2 or ES Composite. I have tested both on the DL and beleive me that either of the pipes will make the Extra scream like a raped ape.
One other thing about the DL's. Buy your motor from Bob at DL USA. He stands behind his product 120%.
quote:
ORIGINAL: T.Edney
http://www.crccflyers.org
Huckin' til it hurts
(in reply to T.Edney)
       Post #: 1808
RE: DL-50 engine - 5/17/2008 10:36:43 AM
rcguy!
Status: offline
quote:
ORIGINAL: Rush7
quote:
ORIGINAL: T.Edney
Rush,
Can you tell me the header you used with the ES pipe? Manufacturer, model number? What length?
Dave
(in reply to Rush7)
       Post #: 1809
RE: DL-50 engine - 5/17/2008 6:18:36 PM
gboulton
Status: offline
quote:
ORIGINAL: Rush7
I'm not sure what bothers me more...
The fact that someone knows what a raped ape SOUNDS like, or the fact that an airplane might mimic the noise.
(in reply to Rush7)
       Post #: 1810
RE: DL-50 engine - 5/17/2008 8:51:08 PM
Nelvick
Status: offline
The maiden video of my PW Extra 300S 1/4 Scale. Was so bad for me. The engine was very rich but works very well. Sorry for my english.
The tail was VERY VERY Heavy, rates was so highest and i lose the back weel in the pickup but i was lose the router. the rest is very well. Now i have add more weigth in the front and rejust the rates.
Here is the Video
       Post #: 1811
RE: DL-50 engine - 5/17/2008 8:59:45 PM
Nelvick
Status: offline
I was so close to crash. Dough Martin land for me.
       Post #: 1812
RE: DL-50 engine - 5/17/2008 11:39:06 PM
bobkra
Status: offline
Greetings all,
I was able to get some flying time in on the new DL100 today. The initial start was very similar to a new DL50. Flip ‘till it barks with the choke closed, open the choke and it’s running in 1 to 3 flips. I ran about 25oz through it on the ground to get an initial ring seat and check the carb settings. It has a wonderfully fast transition just like the 50.
The first flight showed very quickly it needed more leaning so I cut the flight short and re-optimized the carb. Second flight showed the same. On the ground, it seemed close but once it’s in the air, it isn’t. Anyway, 3rd time was the charm.
I mounted it on a plane whose finished weight came in just under 24lbs. I did so for a quick comparison to a similarly weighted plane with a DA85 mounted on it which weighs 23lbs (both with gas on board). What can I say… I used to thing the DL50 yanked the Bling and H9 260 around like toys but this 100 set a new standard of yanking.
Initial tach reading with a Vess 26B was 6700rpm. After 2/3rd gallon through it and a little optimizing on the carb, it held 6990rpm. I set the idle at 1700 which it seemed quite comfortable with. Again, the transition was fantastic; almost instantaneous.
Gas consumption seemed about as expected. The plane has a 24oz tank in it but a 30oz may be more appropriate. I’ll see what tomorrow brings.
Regards,
Bob
www.dlusa.net
