eugene
Joined: 6/5/2002 From: Indiana| USA, IN, USA Status: offline
Weight is a tad over 15# ( 12-14 must be powered with rubber bands) I balanced it 5 3/4 " behind top LE.. Other bipes I've had balanced at the LE of the lower wing... I use a 20oz tank, good for 12 min. flying time... My point was, when landing, low and slow, it seems to run out of pitch control just before touch down..drops and bounces.... I'm going to tinker with the C/G, as the wing area should give it plenty of support a low speeds..moving the weight further back will make the pitch control more effective.. Bipes can be fun, but do take more attention to trimming.. 15# is really no problem for the DL50. does knife edge loops with ease... I've used two props...a XOAR 22-8, and a Menz 20-12. Either did a good job, the Menz pulled it a little faster.....if your're going into the 17-18# area, I would recommend the 22-8, this engine is pretty tough for it's size.......
