Super08
AB, CANADA Status: offline
quote:
ORIGINAL: krproton quote:
ORIGINAL: Bob Pastorello quote:
ORIGINAL: krproton Guys, when I advance the throttle after extended down lines (when the throttle was at idle) the engine hesitates and sounds like it's going to quit before it "spools up" again. It always sounds like it's going to quit, but never has - just kinda unnerving. My needles are set so at full-throttle it runs perfectly and at half-throttle or a little below it burbbles/four-strokes (if that has anything to do with it which I don't think it does). Any suggestions? Tim, nearly always a "throttle up" hesitation is too lean a low needle. It is easy to miss the sweet spot, since the low end affects the high, you can be tweaking away and get the high "perfect", but the low is lean. My "test" is to leave a fully-warmed up engine at it's sitting-still idle....if it gradually speeds up, the low end is lean, if it slows, it's rich. Very much like glow motors. I try for a solid idle without variation, even if left at idle for 30 seconds or more, then advance (dump) throttle to full immediately. If your low end isn't right, you'll see it RIGHT there. Thanks Bob. I got in three more flights tonight and I think I have the hesitation thing cured; First though, I must confess, I also switched propellers. Yesterday, when I was experiencing the hesitation problem, I nicked my brand new carbon Mejzlik prop on my final landing (crap!!!). So I had to go back to my Zinger wood Pro (also a 22 x 8 - same as the Mej). So, after I mounted my Zinger, I tweaked the low end by richening it ever so slightly - I also richened the high end just a hair as well. On the ground, the idle RPM seemed constant. In the air, there was no hesitation at all - it seemed to be totally all gone. One other thing, yesterday it was pretty hot and humid, but today it is not quite so hot and less humid. Well, the problem seems to be all gone. Tomorrow I am going to fly my new propeller - Xoar 22 x 8 laminated. I'll keep you posted. Thanks again!!! Tim Tim I use Xoar exclusively. I like the laminated for their great looks and strength ( I have a bunch of them), but for performance the PJA or the new Swords give a little better rpm and throttle response due to their lighter weight. I noticed a difference on my Fuji. I have some 22x8's so when I get the time I am going to do a test with both props (pja and pjd) to see the exact difference doing a run up and tach, switch props and then restart and re-tach. I have one of their new 3D props I an going to try some time when I get the opportunity. Thank care Doug
_____________________________
If I buy one more engine it''s going to hurt more than my wallet if my wife gets ahold of it.......
