RE: DL-50 engine
Tower Hobbies
Logged in as Guest
Users viewing this topic: Ed Vollmer
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: DL-50 engine
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: DL-50 engine - 11/4/2007 8:29:13 PM
Cambo
Status: offline
I got my cap with the DL out at the field today. I was hopeing to fly it but ended up spending the most time getting the engine to start. I first tried starting it at my house with my dad. Not even a sputter. The tank was barely full so i figured i would completely fill it and head out to the field were a someone who has experience with gassers could help. We kept going through the procedure, cholk, spin, fire, no cholk spin, start. Nothing. It would caugh once or twice but never stay running. The gasser guys were baffled. We noticed the engine had very little compression but we were not sure if that was the problem. So, we kept trying. A few times it would run for a 1-2 seconds but would always die. Someone suggested using the fuel pump to force some fuel into the carb. On a side note, one of the main problems we had today was the throttle servo was POORLY setup (nylon pushrod). It was VERY unprecise in the bottom range so we really had no idea if the throttle was closed, or at idle, or half way open. Back to starting the engine. After we flooded the carb with my fuel filler pump i went to start. Flipped it through once, nothing. Again, nothing. Once more............................BRRRRAAAAAAAAAAAAAAAAA. The engine was at half throttle. I must have leaped ten feet it scared me so much. But my dad was strongly holding the plane so i was safe . The engine was running strong. FANTASTIC transition but a rough idle. We decided to kill it and try starting it again. Nothing, it burped a few times but wouldn't start. So we did the same thing with the fuel pump and got it started again. This time, one of the gasser guys walked over and said my low end was way to lean. He richened ut up and the idle calmed down. We killed it, tryed to start it again (the normal way), and it fired right up. We repeated this a couple times with success. So i guese my needles were out of wack. The gasser guys say that if the low end is too lean it will not draw fuel to well. I would have guesed it was a rich idle from my glow experiences. At full throttle the plane lifted off the ground. It has amazing power. I am getting 6200 RPMS on a xoar 22-8. And that was its first run ever . I can't wait untill it breaks in and i move to a 50:1 blend. BTW, the plane is 13.5 pounds.
(in reply to Al Lewis)
       Post #: 201
RE: DL-50 engine - 11/4/2007 8:42:27 PM
Cambo
Status: offline
I might add that the throttle probabley wasn't completely wide open with how crappy my throttle setup was.
(in reply to Cambo)
       Post #: 202
RE: DL-50 engine - 11/4/2007 9:37:02 PM
paul5992
Status: offline
Thats great cambo welcome to the family. Lou should I run a 23A on a motor thats not broke in yet? I was gonna switch to the 23 a or b once I was on synthetic oil but not now. Wanted to stay with a break in prop. My xoar was a beechwood I like a week prop so if I hit it on the ground hopefully the prop breaks not the motor or the fire wall. Thats why I don't run plywood or carbon. The prop picked up a little stick in the grass. Talk about dumb luck.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 203
RE: DL-50 engine - 11/4/2007 9:49:34 PM
paul5992
Status: offline
Cambo you could check and tune your needles a little to get more rpms with that xoar I was running 6900 on my xoar. Or it could be your throttle linkage.
(in reply to Cambo)
       Post #: 204
RE: DL-50 engine - 11/4/2007 9:56:56 PM
Al Lewis
Status: offline
Well I'm getting 7400rpm on the 23A so I don't consider that too much of a load on a new engine. If it was only spinning 6800 I might change it but not with it's current performance.
_____________________________
Take Offs are Optional, Landings are Really Nerve Racking!! Al Lewis AMA #821623
(in reply to paul5992)
       Post #: 205
RE: DL-50 engine - 11/4/2007 10:02:37 PM
paul5992
Status: offline
Lou how is your top speed is it really low with that prop? How many gallons of gas do you have threw your motor?
       Post #: 206
RE: DL-50 engine - 11/4/2007 10:17:36 PM
Al Lewis
Status: offline
No top speed is great but I don't fly it wide open except on take-offs. I vary the speed of the engine to cycle it and help it to wear in better. It probably has 1/2 gallon of gas through it. I went to 50:1 Belray yesterday for all of my engines.
       Post #: 207
RE: DL-50 engine - 11/4/2007 10:21:39 PM
paul5992
Status: offline
Lou you think that after a half a gallon of gas that its broke in good enough that you can go synthetic?
       Post #: 208
RE: DL-50 engine - 11/4/2007 10:23:51 PM
Al Lewis
Status: offline
We'll see! The 50:1 Belray H1R is probably going to offer just as much protection as a 32:1 mix of some cheap stuff. Don't forget, the idea is to get things to wear in. I'll let ya know how it works out but my bet is it will be just fine. There use to be an old saying when I was a teenager "break it in like you're going to run it" I'm going to see if that holds true with these little guys.
       Post #: 209
RE: DL-50 engine - 11/4/2007 11:08:01 PM
Al Lewis
Status: offline
Hey Scott, do these things run backwards down-under???? I'm sure they still run great!!
       Post #: 210
RE: DL-50 engine - 11/4/2007 11:13:54 PM
paul5992
Status: offline
What kind of hinge glue do you guys use? I have flat hinges and the pacer hinge glue I used let loose on one elevator. I'm mad and a little glad it didn't reck my plane!!
       Post #: 211
RE: DL-50 engine - 11/4/2007 11:18:13 PM
dlenginesaustralia
Status: offline
nope... but they love it when you try and turn them inside out
       Post #: 212
RE: DL-50 engine - 11/4/2007 11:43:11 PM
Al Lewis
Status: offline
I use Elmers polyeurethane. You should also pin flat hinges.
       Post #: 213
RE: DL-50 engine - 11/4/2007 11:44:26 PM
paul5992
Status: offline
pin them with what?
       Post #: 214
RE: DL-50 engine - 11/4/2007 11:57:14 PM
