RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC!
Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/19/2008 4:01:01 PM
RC4X4
Status: offline
I did the same as Graham with the landing gear cuffs. I didn't use the black tubing.
Here's where I mounted my switch. I mount it so it can be turned off on the outside.
There is two locations already laser cut on both sides in the front.
Cory
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to diamondave)
       Post #: 51
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/19/2008 4:09:30 PM
diamondave
Status: offline
thanks, is there a trick to tightening the axle with the wheel pants on? i even tried hoging out the one so the retainer part would fit but then the tire rubs, so if just slid over the threaded part i cant figure out how to hold it while i tighten the lock nut????
(in reply to RC4X4)
       Post #: 52
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/19/2008 4:11:26 PM
diamondave
Status: offline
btw, i didnt even notice the cut out for the switch...awesome set up, thanks for pointing it out
       Post #: 53
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/19/2008 6:16:52 PM
flyinGraham
Status: offline
yep file the spats out and use the lock nut to lock them up against the collet inside mate
Graham
_____________________________
Graham Roscoe
www.freestyle-rc.co.uk / www.extremeflightrc.com
       Post #: 54
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/19/2008 7:54:25 PM
diamondave
Status: offline
okay, but how do i hold the axle itself once in the gear while trying to tighten the lock nut???, maybe i am missing something obvious here i dont know
(in reply to flyinGraham)
       Post #: 55
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/19/2008 11:08:31 PM
diamondave
Status: offline
will have her done tomorrow, still didnt get the pants on, i filed out so the rectangle fits in the pant but that moves the wheel closer and hits the pant, like it needs that space of the thickness of the wood glued in for a proper fit, i'll figure something out or not use them ...
has anyone felt the need to use bigger washers on the back of the firewall for the motor?? i used the ones that came with it but was curious, i know on the 45" some people were crushing the firewall and having failures, so i used bigger washers on that one and just went snug to where the wood "dented" a bit, just wondering if anyone has had any issues of the smaller washers coming through easier, would change them now while its still apart if you think so
       Post #: 56
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/20/2008 10:18:42 AM
flyinGraham
Status: offline
I have used all the stock gear including the washers for the motor mount, I have had 30 - 40 flights mostly all out 3d and had no problems what so ever mate
Graham Roscoe
       Post #: 57
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/20/2008 3:47:39 PM
diamondave
Status: offline
sound....will have some pics later hopefully, should be all buttoned up, next weekend maiden if my charger comes in this week, supposed to so i hope so
       Post #: 58
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/20/2008 11:27:53 PM
diamondave
Status: offline
here is it, all done, turned out nice i think, hope to get the charger this week and fly next weekend .... wasnt sure about putting all the decals on but once started i thought they looked good, so there she be
curious, is there a way you guys hold the motor from turning to tighten prop? i used a screw driver in through the back of the spinner, it worked but i am thinking there has to be a less barbaric way...
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 59
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/21/2008 7:14:59 AM
flyinGraham
Status: offline
looks great mate, I know what you mean it is a bit of a squeeze!
Graham Roscoe
       Post #: 60
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/23/2008 12:14:02 AM
diamondave
Status: offline
i test ran the motor in the house(gotta love electrics) just to set up throttle settings, man this thing is going to rip, i had the tail between my legs, almost left bruises on my calves, haha
       Post #: 61
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/23/2008 7:08:15 AM
flyinGraham
Status: offline
haha nice one, yep it is an insanely powerful motor, wait until you see the perfromance it gives in a 5lb plane!!!!
Graham Roscoe
       Post #: 62
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 1/23/2008 11:55:53 PM
diamondave
Status: offline
they are calling for rain saturday ...i live in the desert, i can litterally count the times it rains on my fingers, and this saturday may be one of them , but i am ready sat or sunday for the maiden, my charger should be here any day
       Post #: 63
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 2/1/2008 9:20:11 PM
diamondave
Status: offline
well i am all set for a maiden this weekend, still not feeling great but good enough to fly, this cold is hanging in there, sucks, anyway good weather for tomorrow and ready to go, will let you know how it goes, maybe take pics or vids too
       Post #: 64
RE: EF 58" Extra-300 BUILD THREAD -- ELECTRIC! - 2/4/2008 6:51:37 PM
diamondave
Status: offline
well i got to fly finally, i was getting interference though on my range check, so i was cautious to fly, i got a glitch once in a while so i only flew twice and i kept it up high in case of hits, i really like it from what i can tell, i changed recievers to a pcm and ran my antenna a different way and will try again this coming weekend, i can tell this is going to be very fun to fly, just need to figure out whats up with my set up
       Post #: 65
