RE: Elan Has Arrived!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Elan Has Arrived!
Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: Elan Has Arrived! - 10/29/2007 1:17:23 PM
Synthetic
Status: offline
Sandor,
Can you explain your comment about the Elan with the "almost a gallon" fuel tank? Do you mean the landing gear you have designed for the Elan needs to be stronger for fuel tanks of a gallon size?
Don
_____________________________
Say hi to my cute bunny...his name is Stewart, but you can call him Stew.
(in reply to geh3)
       Post #: 226
RE: Elan Has Arrived! - 10/29/2007 3:18:18 PM
digitech
Status: offline
quote:
ORIGINAL: Synthetic
Sandor,
Don
No no
this time and our experiance with USA pilots we kinda guessed someone would upgrade its total weigth by factor 1.4 .
dont worry ..the new springs are fresh from the factory...REINFORCED
Sandor Kruise
Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF.
"Home of the Pro-Lynx Gears"
(in reply to Synthetic)
       Post #: 227
RE: Elan Has Arrived! - 10/29/2007 3:35:12 PM
kylargo
Status: offline
HAS ANYBODY HAD ANY PROBLUM WITH THE WINGS NOT GOING ON RIGHT DUE TO THE CENTER SPAR TUBE IS TO TIGHT WITH THE WING, I HAVE TO FIGHT THE WING TO GO ON WHAT DO I DO?
(in reply to WHMC)
       Post #: 228
RE: Elan Has Arrived! - 10/29/2007 3:54:32 PM
Synthetic
Status: offline
Thank you Sandor.....
The reason I asked is because the Sullivan tank Boomerang Jets USA is selling is a 125 ounce fuel tank.
Don
(in reply to kylargo)
       Post #: 229
RE: Elan Has Arrived! - 10/29/2007 3:57:36 PM
Synthetic
Status: offline
kylargo ,
Check with AV8RK from post #199. He has had a lot of trouble getting his to fit right. Send him a "PM" and I bet he'll help you out. Hopefully you won't have to go to all the work that he has had to do on his Elan.
Don
       Post #: 230
RE: Elan Has Arrived! - 10/29/2007 4:17:04 PM
Countryboy
Status: offline
quote:
ORIGINAL: kylargo
I for one ran into this problem.Chances are you will have to lap sand the tube sockets in the wing and sand on the spar tube it's self. Fit the spar tube into the fuse section first. Once satisified with that, remove the spar and fit it into each wing panel one a time. Sand carefully so that you can slide the spar fully in, while trying to retain as tight of a fit as you can get.
Once you get them to fit, install the spar back into the fuse along with the anti-rotation pins, and without the booms on see if the wing panels will slide on & off of the spar and rotation pins together. Then fit the booms in place and try the fit of the wing again to make sure it will still go on and square up with the booms.
I found that with the booms installed, they tend to alter the rotation pins slightly in they seem to spread the pins apart when you fully push the booms in flush with the molded fuse wing root section.
       Post #: 231
RE: Elan Has Arrived! - 10/29/2007 5:08:12 PM
rcguy!
Status: offline
quote:
ORIGINAL: kylargo
First thing to do is kill the CAPS!
Second thing is to read post #56
Dave Rigotti
       Post #: 232
RE: Elan Has Arrived! - 10/29/2007 7:25:24 PM
Henk Visser
Status: offline
A few pictures
I found it wise to reinforce the ply holding up the top hatch!
I saw a hatch came of a Elan during flight at Jetpower.
Futher BVM heatshield in the engine bay cheap fire ensurance!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
There''''s no gravity it''''s the earth that sucks!
http://www.hpvjets.page.tl/Home.htm
(in reply to rcguy!)
       Post #: 233
RE: Elan Has Arrived! - 10/29/2007 7:27:57 PM
Henk Visser
Status: offline
And some more
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Henk Visser)
       Post #: 234
RE: Elan Has Arrived! - 10/29/2007 8:26:57 PM
turbinepeter
Status: offline
For those that wanted to see my install.
Its a P120 SE with a 2ltr tank from RS components.
Jet1-A retracts(XL).
I have had 10 flights with a P80 and it goes well, but the P120 just gives it that little bit more "Fun Factor".
But remember to use the throttle sensibly. Tee hee. !!!!!! Alan C does NOT suggest you use anythinh more than a P80.
Regards
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by turbinepeter -- 10/29/2007 8:39:52 PM >
       Post #: 235
RE: Elan Has Arrived! - 10/29/2007 9:26:47 PM
Turbiner
Status: offline
quote:
ORIGINAL: kylargo
Yes I had to do quite a bit of work to get wings fitted. The post from Countryboy is good advice, thats how I did it. I also found that the tailbooms have to be spread slightly when fitting the tail plane.
       Post #: 236
RE: Elan Has Arrived! - 10/29/2007 9:34:47 PM
geh3
Status: online
Nice installl, hey, where's your RX? and how far forward are your batteries THANKS
(in reply to turbinepeter)
       Post #: 237
RE: Elan Has Arrived! - 10/29/2007 11:02:35 PM
rcguy!
Status: offline
Alan,
Do you know the dimensions and capacity of the Sullivan tank?
Dave Rigotti
(in reply to geh3)
       Post #: 238
