RE: Elan Has Arrived!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Elan Has Arrived!
Page: <<   < prev  46 47 48 49 [50] 51 52 53 54 55   next >   >>
Login
RE: Elan Has Arrived! - 6/8/2008 12:11:31 AM
CPing
Status: offline
Here's a question for the folks who fly Futaba.
It's too windy to fly this weekend but I went to the field anyways. Was getting the "learn" part setup on my P-80 but not sure how to setup the failsafe. I have a 9C with a FASST module...anyone with the same setup?
(in reply to Big feet)
       Post #: 1226
RE: Elan Has Arrived! - 6/8/2008 4:49:16 AM
bcovish
Status: offline
Craig, I would post this in the JetCat support forum and/or the Futaba support forum. For those that don't know, this is Craig's first turbine powered aircraft. He has the sport scheme Elan.
_____________________________
Bob-O Austin TX
Sticks and stones may break our bones, but words will break our hearts
(in reply to CPing)
       Post #: 1227
RE: Elan Has Arrived! - 6/8/2008 4:57:37 AM
gooseF22
Status: offline
I can say that on my super 8 with module, I used the throttle cut and put it on a mix switch, so with the cut on, that was trim low, stick low. and with it off, that was ready.
The only trick is binding for engine kill on the spektrum. when you turn the TX on for bind, very quickly cycle the trim switch before it begins to transmit or it will always set it to idle for failsafe
Understand that was spektrum, so I dont know how much applicability that has other than the throttle cut.
Goose
Team Fromeco
(in reply to bcovish)
       Post #: 1228
RE: Elan Has Arrived! - 6/8/2008 5:06:23 AM
gooseF22
Status: offline
Hey you guys with alot of sorties,
whats the censensus on Crow settings and flap settings and elevator settings?
Right now Im only running about 15 degrees of flap for takeoff, with no elevator mix, and 80 degrees with 3% down mix for landing, but only have 7 flights so far. No crow at present.
what say you?
Goose
Team Fromeco
(in reply to gooseF22)
       Post #: 1229
RE: Elan Has Arrived! - 6/8/2008 9:27:35 AM
F-18DiamondBack102
Status: online
20 flights, no crow and have no intention of adding it as it really don't need it IMHO.
Indecision is the key to flexibility...
       Post #: 1230
RE: Elan Has Arrived! - 6/15/2008 8:44:20 PM
Big feet
Status: offline
Hi guys,
My Elan arrived 10 days ago but due to other commitments I didn't get to start the build until Monday last. The turbine, UC, extension leads, tank, servos only arrived three days ago.
I maidened her today and all I can say is, 'What a feeling, what a plane, the long nights and little sleep was worth it'.
I want to say a big THANK YOU to Sandor at Digitech Turbines. Fast service, excellent parts supplied and quick delivery.
For those interested the build time table looked like this,
Mon 9 pm - 1.30 am
Tue 9 pm - 2.00 am
Wed No oppertunity to work
Thur 2.00 pm - 2.00 am
Fri 9.00 am - 3.30 am (saturday morning)
Sat 11.00 am - 6.10 am (Sunday Morning, today)
Maiden flight at 3.30 pm today.
Click to see fullsize image.
Click for fullsize
Please remember, RC is dangerous to your wealth
(in reply to F-18DiamondBack102)
       Post #: 1231
RE: Elan Has Arrived! - 6/18/2008 11:48:15 PM
Big feet
Status: offline
Hi guys,
I was wondering if you are using the bolt to hold the top hatch on as per the kit, or has anyone opted for a quick release system.
If so, what are you using? I would like to be able to get into the model fast if neccessary. I'm guessing the bolt is used instead of the normal plastic latch pin due to the heat from the turbine??
Cheers,
       Post #: 1232
RE: Elan Has Arrived! - 6/19/2008 3:31:32 AM
gooseF22
Status: offline
bolt currently. some guys using a nylon one and it seemed to work well.
I coated the back part of the canopy underside with BVM heat treatment
Goose
Team Fromeco
       Post #: 1233
RE: Elan Has Arrived! - 6/22/2008 7:19:34 PM
skywarrior
Status: offline
Alan,
have now completed the basic colour change scheme and another few hours will have the fiddly bits done and a tidy up.
Looking forward to flying it again, this time with the retract valve set more accurately!
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Turbinac)
       Post #: 1234
RE: Elan Has Arrived! - 6/23/2008 12:02:24 AM
Big feet
Status: offline
Very nice, is that a different hatch attaching method visable in the last shot?
(in reply to skywarrior)
       Post #: 1235
RE: Elan Has Arrived! - 6/23/2008 9:00:28 AM
skywarrior
Status: offline
Hi
yes its two Multiplex hatch latches, sliding versions with brass balls from ball centered clevis soldered onto the pin and then trimmed back with a dremel. The Multiplex units have nice long slide pin and large catch pin and easy to slide. I prefer these to some others which have very short pins that do not stick through fus skins very far.
Still some work to do in tidying up. Dont take any notice of the angle of the tailplane as its just resting there !
David
       Post #: 1236
RE: Elan Has Arrived! - 6/24/2008 5:38:20 AM
kev-o
Status: offline
Hi Goose
i run similar flap settings to yours for take off and run crow on landings full flaps ,whatever you can get and 15mm of up aileron both sides . you will be amazed at how much you can slow her down and maintain controlability. i was flying mine today on a grass field a lil bit of head wind and on landing it rolled out abt 20ft to a stop without brakes... i amazed other jet pilots at how slow i could get it and still not worry abt dropping a wing etc.. try it an see what you think... set it up and fly a few circuits wtih the gear down and full crow just be prepare to add abt 30% more throttle to go the same speed. Helijet and i run identical setups and they rock...
Boomer Elan
Jetcat P70
JR9303 2.4
jr8231s
behotec retracts and brakes
duralite a123 rcvr packs
duralite limn 2300 ecu pack
under 22lbs now fuel(its light)
Kevin
BC''s ALTECARE RC REPRESENTATIVE
DURALITE REPRESENTATIVE
       Post #: 1237
RE: Elan Has Arrived! - 6/24/2008 10:02:39 AM
Turbinac
Status: offline
Skywarrier,
Very nice colour scheme. Gives the Elan a new look!
I get quite a few enquiries asking for information on how to go about preparing and painting the Elan and the XL for custom schemes.
How about giving us some info on the method you used? How much initial preparation did it take and what paints were used etc..
I look forward to seeing you and the Blue Elan at Abingdon or another meeting soon.
Alan
Alan Cardash,
Boomerang Jets Ltd./Boomerang Jets USA Llc.
       Post #: 1238
RE: Elan Has Arrived! - 6/24/2008 2:43:52 PM
