RE: Elan Has Arrived!
Tower Hobbies
Logged in as Guest
Users viewing this topic: geh3, Snake Eyes
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Elan Has Arrived!
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Elan Has Arrived! - 10/25/2007 6:42:20 PM
RENO
Status: offline
BVM Bandit nose gear retract unit install!!
Skeet
Click to see fullsize image.
Click for fullsize
(in reply to rcguy!)
       Post #: 151
RE: Elan Has Arrived! - 10/26/2007 12:30:49 AM
rcguy!
Status: offline
Not going to get much done tonight. Patricia did send the correct hand servo mounts and the result is shown below. As a reference they must be the same hand as the flap servo mounts. Dubro 4-40 hardware and Dubro #493 horns. Covering is cut away from underneath the horn plates and 12 minute epoxy is used to secure the whole assembly. The horns did locate perfectly with the ply insets. I used JR heavy duty servo arms on the servo side.
EDIT ADD:
The Dubro horns allow me to match each half to have the same throw without using a "matchbox"!
Dave Rigotti
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by rcguy! -- 10/26/2007 3:42:24 AM >
(in reply to RENO)
       Post #: 152
RE: Elan Has Arrived! - 10/26/2007 12:36:30 AM
Synthetic
Status: offline
Dave,
Do you have a picture of where you put the plywood insets?
Don
_____________________________
Say hi to my cute bunny...his name is Stewart, but you can call him Stew.
       Post #: 153
RE: Elan Has Arrived! - 10/26/2007 12:44:44 AM
rcguy!
Status: offline
quote:
ORIGINAL: Synthetic
Dave,
Don
The plywood insets come installed from the factory on all control surfaces. A very nice touch!
Dave
(in reply to Synthetic)
       Post #: 154
RE: Elan Has Arrived! - 10/26/2007 1:12:30 AM
Synthetic
Status: offline
Thanks Dave, I was thinking it was something else..
       Post #: 155
RE: Elan Has Arrived! - 10/26/2007 3:57:53 AM
Countryboy
Status: offline
quote:
ORIGINAL: Synthetic
Does anyone have an extra "flap" control horn by any chance? It is the clear horn that mounts to one of the flaps. I only had one in my kit and of course I need two of them....
Don
Don,
I am sure a quick call to Patricia will net you what you need, but if you've got to have it now, grab yourself a piece of aluminum of the appropriate thickness and use your existing one as a template. Overlay it on you piece of aluminum and using a scribe, trace the original horn out onto the aluminum blank. Using a bandsaw, rough cut it to shape and then use small files to dress it out. Finish off by drilling the holes with numbered drill bits. An hour of your time, and your good to go.
Click for fullsize
       Post #: 156
RE: Elan Has Arrived! - 10/26/2007 4:59:28 AM
mick15
Status: offline
when i come to fit out my elan i think i will be tempted to recut the flap horns as it appears the holes are in the wrong place.
they should be in a line to facilitate the correct geometry.
m
(in reply to Countryboy)
       Post #: 157
RE: Elan Has Arrived! - 10/26/2007 5:09:40 AM
mick15
Status: offline
oops! i may have just put my foot in my mouth, i noticed in post #70 the horns are fitted the other way round!
m
(in reply to mick15)
       Post #: 158
RE: Elan Has Arrived! - 10/26/2007 6:36:10 AM
bob1393
Status: offline
Will someone please tell me how they got the retract air tank into the holes in the formers? I was able to get the brake tank in, but the retract tank is too long to fit in.
Thnx - Bob
       Post #: 159
RE: Elan Has Arrived! - 10/26/2007 12:51:31 PM
Synthetic
Status: offline
Countryboy,
I have contacted Patricia but she doesn't have any. She has been in touch with Alan and he is going to send it to me. Not sure how long it will take to get here from Europe though.
Great idea but I don't have a band saw and I don't know anyone who does. I will just have to wait until my replacement arrives.
Thank You,
Don
(in reply to bob1393)
       Post #: 160
RE: Elan Has Arrived! - 10/26/2007 1:20:21 PM
Turbinac
Status: offline
Don,
Your flap horn was mailed yesterday from London, so will be with you next week.
Alan.
Alan Cardash,
Boomerang Jets Ltd./Boomerang Jets USA Llc.
       Post #: 161
RE: Elan Has Arrived! - 10/26/2007 2:14:23 PM
Synthetic
Status: offline
Thank you Alan,
Don
(in reply to Turbinac)
       Post #: 162
RE: Elan Has Arrived! - 10/26/2007 2:49:21 PM
john agnew
Status: online
Guys
Can anyone who has an Elan give me the dimension from the wing retract mount inner edge to the wheel well opening. I want to check if oleos I have will fit.
John
       Post #: 163
RE: Elan Has Arrived! - 10/26/2007 3:08:07 PM
digitech
Status: offline
quote:
ORIGINAL: john agnew
Guys
John
its adjustable so a 140-160mm will do fine.
it needs a pretty long leg..
Sandor Kruise
Dealers for:JetCat,Graupner,Futaba,Fei-Bao,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF.
"Home of the Pro-Lynx Gears"
(in reply to john agnew)
       Post #: 164
RE: Elan Has Arrived! - 10/26/2007 3:20:30 PM
john agnew
Status: online
Sandor
From what you say the standard Jet1A leg which I have will not fit, it is 120mm from the axel centre to the trunnion block. I now have a spare set of retracts / oleos since I lost my Velox! So the question is do I buy another Velox which I have all the parts for or buy an Elan and have to buy new oleos etc. Why did Alan not design the Elan to fit the already available Jet 1A legs? Can you make Elan fit oleos with 10mm stubs instead of pins?
Best regards
John
(in reply to digitech)
       Post #: 165
