RE: Elan Has Arrived!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Lambert Kolibri Nano-Turbine - Smallest Turbine In The World - RTF
Seller:  SinCityJets
Details:   $3,200.00   |  10/25/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Elan Has Arrived!
Page: <<   < prev  69 70 [71] 72 73 74 75 76 77 78   next >   >>
Login
RE: Elan Has Arrived! - 6/23/2009 11:21 PM  1 votes
BaldEagel
Score: 103
Last Login: 11/8/2009
Status: offline
OK Guys Watch this space the 120SX is going in the Elan tommorow and posibly will be flown in the afternoon, will be interesting to see the pitot and GPS reading compared to the P80, will let you all know tommorow.
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to BaldEagel)
       Post #: 1751
RE: Elan Has Arrived! - 6/24/2009 6:07 AM
Henk Visser
Score: 100
Last Login: 11/7/2009
Status: offline
You will like the P120 sx!
I converted my Elan from P-80 to P120 se last year.........what a blast
Hawe-modelltechnik rep
www.hpvjets.nl
Hide Signatures
       Post #: 1752
RE: Elan Has Arrived! - 6/24/2009 7:44 AM
turbinepeter
Score: 100
Status: offline
baldeagle
I have a P120 in mine, albeit it is not an SX, you will like the 120 in the Elan,
Enjoy and look forward to see what figures you get from your GPS.
Regards
Peter
Hide Signatures
(in reply to Henk Visser)
       Post #: 1753
RE: Elan Has Arrived! - 6/24/2009 7:48 AM
cgroen
Score: 100
Status: offline
Oh yes
I have a P160SX in my Elan, GREAT fun on takeoff and verticals, I have turned it down to around 115.000 RPM (approx 13 Kg), but planning on mounting my JetCat pitot tube, and dialing the turbine up to max RPM's, what would be the maximum allowed speed to set the ECU to ? (200 mph/320 Km/h or is that too much ?)
Regards,
Carsten Groen
Hide Signatures
(in reply to turbinepeter)
       Post #: 1754
RE: Elan Has Arrived! - 6/24/2009 7:56 AM
Ali
Score: 100
Status: offline
too much
the max we ever got an elan to when testing with a 34 lbs thrust turbine was around 180 mph. Please remember... these models are not designed or constructed for speeds anywhere near 200 mph.
Regards Al
Ali Machinchy. Al''s Hobbies - European Dealer for Airworld. BVM, Tams, Jet Cat, AMT, Skymaster, PST Jet, pull over, Jet 1A
Hide Signatures
(in reply to cgroen)
       Post #: 1755
RE: Elan Has Arrived! - 6/24/2009 8:11 AM
cgroen
Score: 100
Status: offline
OK,
so would say 180 mph be a "safe" speed, I know that it all depends on the flying style, and I know one has to be carefull with the maneouvers going full speed, but on a strait and level flyby, would 180 mph be within "safe limits" ?
I don't want to break anything or risk anyone's health!
Regards,
Carsten Groen
Hide Signatures
(in reply to Ali)
       Post #: 1756
RE: Elan Has Arrived! - 6/24/2009 8:29 AM
turbinepeter
Score: 100
Status: offline
Ali
Damm, all this time I have been flying my Elan with the P120, I thought it was hitting 200mph!!!
Need a different airframe then!
Hide Signatures
       Post #: 1757
RE: Elan Has Arrived! - 6/24/2009 10:05 AM  1 votes
BaldEagel
Score: 103
Status: offline
Peter
Have a look at Ali's new Mach 1 airframe, not out yet, but looks like its going to be a good one, a larger version is on the cards to take a P120, but not just yet, I am sure Ali will put this right if I got the information incorrect.
Mike
Hide Signatures
       Post #: 1758
RE: Elan Has Arrived! - 6/24/2009 10:43 AM
Didier
Score: 100
Status: offline
Be very very carefull when going faster then 270 km/h (170 m/h) with the ELAN!!!
I've got a pitot-tube and a fast running P-120SE.
2 times I crashed almost because when I was going full power in a dive, the elevator was simply not effective anymore.
The elevator became effective after slamming the throttle back.
Thought the elevator servo's where not strong enough (JR8311) so I replace them with 2 JR8411 with thicker servo extensions wires .
The second time it happened again, so basicly its the model that is not able to handle >165 M/h.
Th fastes speed I recorded with the Elan was 290 km/h (180 m/h), that was also almost my second crash....
3D-Aerobatic, Combat and Speed fan!!!
Hide Signatures
       Post #: 1759
RE: Elan Has Arrived! - 6/24/2009 11:14 AM
digitech
Score: 100
Status: offline
quote:
ORIGINAL: Didier
your my favourite customer DJ
Sandor Kruise
Dealers for:JetCat,Graupner,Emcotec,Skymaster,Pro-Lynx,Airpower,Jets-munt,Xicoy,Jet-1A,Composite-ARF,Behotec.
"Home of the Pro-Lynx Gears"
Hide Signatures
(in reply to Didier)
       Post #: 1760
RE: Elan Has Arrived! - 6/24/2009 12:07 PM  1 votes
BaldEagel
Score: 103
Status: offline
Thanks for all the warnings chaps, I will moderate my enthusiasm, if I can. LOL.
I will post what readings I get when I come back from the field.
Mike
Hide Signatures
(in reply to digitech)
       Post #: 1761
RE: Elan Has Arrived! - 6/24/2009 8:52 PM  1 votes
BaldEagel
Score: 103
Status: offline
Guys
The wind today was at 40mph, but I did fly and the GPS and Pitot did confirm a 40mph difference, I was over 180Mph in some of the runs, but on not one occasion did I run out of elevator authority in fact on one reversal I pulled 9.96G which did not concern me at the time utill I saw the readout, but does prove how well the design of this ariframe will withstand some abuse, don't do it too often though, if I had to draw a conclusion from all this, it has to be that this airframe does not need a P120 the P80 is perfect for it, if you want something fast and adrenaline pumping do what I will be doing next, a C-ARF Rookie with full vectored thrust and the 120SX to power it, should be fun.
Oh one other thing, the spool up from the SX is absolutly amazing its just like a petrol engine, move the throttle it responds, landings have never been so easy, you can come in with the throttle closed and it will open up to go around, but its so good you can feather the throttle and get it on the numbers without a problem.
Mike
Hide Signatures
       Post #: 1762
RE: Elan Has Arrived! - 6/24/2009 10:29 PM
cgroen
Score: 100
Status: offline
I have not seen the lack of elevator authority either, I have 2 8511 on the elevator, and even doing dives with the 13 Kg push, no sign of problems with the elevators ?!
But then again, I don't (yet) know the max speed, the pitot will hopefully tell...regarding the pitot, I'm looking for a nice place on the ELan for it, I have the BVM pitot mount, but it's soo bulky, any other good ideas for the mounting ?
Regards,
Carsten Groen
Hide Signatures
       Post #: 1763
RE: Elan Has Arrived! - 6/24/2009 10:47 PM  1 votes
BaldEagel
Score: 103
Status: offline
quote:
ORIGINAL: BaldEagel
Fitted the Pito tube into the wing stub, I think it looks much better than the BVM Mount?
Mike
Post 1540 on Page 62 shows how I mounted mine, the tube the pitot is in is part of an old bent aerial off a 35Mhz Tx, by using a tube cutter it reduces the dia just enough to be an interfearance fit for the pitot, you will have to bend the bottom angled pipe to be parrallel with the other pipe and install from the outide, but then you would have to do that with the BVM mount as well.
Mike
EDIT: Better pic uploaded.
Click to see fullsize image.
Click for fullsize
< Message edited by BaldEagel -- 6/25/2009 12:08 PM >
Hide Signatures
       Post #: 1764
RE: Elan Has Arrived! - 6/25/2009 12:10 PM  1 votes
BaldEagel
Score: 103
Status: offline
Just in case you get to the same place I did, the installation instructions are not clear, this diagramme cleared it up for me, but its not in the instructions.
Mike
Click for fullsize
Hide Signatures
       Post #: 1765
RE: Elan Has Arrived! - 6/25/2009 12:20 PM
cgroen
Score: 100
Status: offline
Thanks Mike,
that makes it very clear!
Only thing is I'm scared that the protuding (sp?) tube will easily be broken off at the position during "hangar handling" etc.
Well, I must just learn to be careful
Regards,
Carsten Groen
Hide Signatures
       Post #: 1766
RE: Elan Has Arrived! - 6/25/2009 12:25 PM  1 votes
BaldEagel
Score: 103
Status: offline
I have everything on my Elan set up for operation and accesability on the left hand side of the fus, the pitot is on the right hand side, so far so good, I also leave the wing incidence pins in and seem to hit those more often than anything else, the long one is a bit of a pain when it digs you in the side, but that is offset by the convenience of fitting the wing easier on that side.
Mike
Hide Signatures
       Post #: 1767
RE: Elan Has Arrived! - 6/25/2009 12:44 PM
Henk Visser
Score: 100
Status: offline
I glued the wing incidence pins with BVM aeropoxy to get rid of the huge slob!
My horizontal stabilizer could be moved almost 8mm!
After glueing the pins there is almost no slob left! And it fly's even better than before
www.hpvjets.nl
Hide Signatures
       Post #: 1768
RE: Elan Has Arrived! - 6/25/2009 10:16 PM
Socomon
Score: 100
Status: online
Gents:
Is the Elan build manual (not the Digitec retract manual) available to download for pre-purchase inspection?
Hide Signatures
       Post #: 1769
RE: Elan Has Arrived! - 6/25/2009 10:23 PM  1 votes
BaldEagel
Score: 103
Status: offline
quote:
ORIGINAL: Henk Visser
The only huge slob I have is my mechanic, sorry Mark??? LOL.
No insult intended Henk, I know English is not your first language, but you meant slop as in sloppy, excess movement.
Mike
Hide Signatures
       Post #: 1770
RE: Elan Has Arrived! - 6/25/2009 10:30 PM  1 votes
BaldEagel
Score: 103
Status: offline
quote:
ORIGINAL: Socomon
Gents:
I was not able to find one prior to my purchase, it is in the same line as the plastic kits of old, lots of line drawings with stick this to this with this glue, so it does not tell you a lot, but sufficient to get the job done, notes at the end on movements, C of G and mixes are all spot on, there is so little to do that you do not need a more detaild manual.
Mike
Hide Signatures
(in reply to Socomon)
       Post #: 1771
RE: Elan Has Arrived! - 6/25/2009 10:38 PM
Socomon
Score: 100
Status: online
Thank you Mike.
I been flying EDFs and this would be a first forray into turbines. I always like see a manual first whenever possible as it helps to give me a sense of what I am getting into and (usually) helps to assure me that I can handle the project.
I guess there is no manual that covers the part that will be most foreign to me anyhow - the location and installation of the various turbine and fuel system components.
Hide Signatures
       Post #: 1772
RE: Elan Has Arrived! - 6/25/2009 10:54 PM  1 votes
BaldEagel
Score: 103
Status: offline
You will find that everyone on here has their own opinion on what equipement to use and where to put it, the most useful piece of information given to me was that without the wing, booms and tail on but with the canopy on legs down and full UAT the C of G is about 1" in front of the front incidence pin, that is a good starting point, I am now behind that position and the position recommended in the manual, but for a first flight it was ideal.
This thread is very long, but there are some good instalation shots on it, that will give you an idea of where everything needs to be put, if I get into the office tomorrow I will post a couple of my instalation shots to start you off.
Mike
Hide Signatures
       Post #: 1773
RE: Elan Has Arrived! - 6/26/2009 6:14 AM
Henk Visser
Score: 100
Status: offline
quote:
ORIGINAL: BaldEagel
Mike
LOL no problem Mike
But you know what I mean?
I could move my tailbooms with horizontal stabilizer, in my opinion you never stop trimming you plane when you tail is moving!
At a recent jetmeeting in The Netherlands I checked a few other Elans and almost every Elan hat this SLOP!! LOL
Didier also posting here at the forum told me he glued the wing incidence pins and now the plane is far better to trim.
www.hpvjets.nl
Hide Signatures
       Post #: 1774
RE: Elan Has Arrived! - 6/26/2009 8:31 AM  1 votes
BaldEagel
Score: 103
Status: offline
I have to admit I have not noticed any SLOP in my tail booms, but will check more thoroughly next time I rig, I wonder if the slop develops over time? I only have 20 flights on mine so will keep an eye on this for the future.
Socomon.
A couple of instalation shots for you to digest, and a couple more of the pitot instalation.
Mike
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by BaldEagel -- 6/26/2009 9:32 AM >
Hide Signatures
       Post #: 1775
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.641RCU1
