mowery1
IN, USA Status: offline
Dave, I noticed that when you mounted your robart retracts that you moved them in towards the wheel wells....Was that because of the length of the struts sent with the retract package?? I have the same retracts and I'm getting ready to install mine as well...Just wanted to make sure I was installing them correctly...Did you have to grind away some of the fiberglass to mount them properly in the seats ? Mine are too wide to "drop right in" Thanks for the help! Rick
_____________________________
Authorized dealer for Fei Bao, Tamjets, Yellow Aircraft, Jetcat, Aero-Works, FlyEagle Jets, QQ aircraft
