RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Carden Aircraft Extra 330S - 40%
Seller:  misfit
Details:   $3,000.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Page: <<   < prev  116 117 [118] 119 120 121 122 123 124 125   next >   >>
Login
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 2/27/2012 9:28 AM
norm
Score: 100
Last Login: 6/12/2013
Status: offline
Gonzalo,
the saito 90 3 cylinder is really too weak of an engine to power this plane. In reality the "90" means nothing but the size of displacement and it is 3 "30's" fighting each other. there is a great loss of power and the engine is somehow comparable to a 45 - 4 stroke which i think would be even stronger.
I have the 3 cylinder Saito 90, the 450 and the 170, they all are great looking, "pieces of jewelry" good to look at, but wont deliver power. Too much mechanicc to move around in this size engine.
Normand
_____________________________
Some think " if I had ""I would do" and" I would be"...Try to be you will do and you will have.
Hide Signatures
(in reply to Gonzalo38)
       Post #: 2926
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/6/2012 12:29 PM
raaf
Score: 100
Last Login: 6/19/2013
Status: offline
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to agmurf)
       Post #: 2927
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/6/2012 12:34 PM
raaf
Score: 100
Status: offline
I AM GOB SMACKED I ACTULLY UPLOADED A PHOTO OF THE COCKPIT OF MY B25.ITS NEVER WORKED BEFORE SO ILL TAKE THIS ONE.ILL PUSH MY LUCK AND DO ACOUPLE MORE TOMORROW
Hide Signatures
(in reply to raaf)
       Post #: 2928
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/6/2012 12:36 PM
raaf
Score: 100
Status: offline
THAT PHOTO IS MK1 NEXT ONE IS I THINK BETTER.
RAAF
Hide Signatures
(in reply to raaf)
       Post #: 2929
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/8/2012 11:51 AM
raaf
Score: 100
Status: offline
hi guys.
Well the time has come for the maiden flight.ive done a series of grond runs and all is well i just hope i havnt missed anything.I've also put 3 tanks of fuel through each motor which i bought when the b25s came out [big mistake] after reading some of the suggestions on this thread.
The motors run sweetly and havnt flamed out during static testing so no excuses
AUW is 19lbs with all the bling even electric retracts, not to heavy i think.
Hide Signatures
(in reply to raaf)
       Post #: 2930
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/9/2012 2:04 AM
agmurf
Score: 100
Last Login: 2/2/2013
Status: offline
quote:
ORIGINAL: raaf
hi guys.
Good luck and keep us posted.
Hide Signatures
(in reply to raaf)
       Post #: 2931
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/14/2012 8:10 PM
Fidelity101
Score: 100
Status: offline
Can anyone with experience on this plane comment on whether a pair of thunder tiger 91 four stroke engines would be to much? I've got an offer for a package deal with those motors but I'm concerned the added 10 ounces per motor and larger size may cause issues in terms of fitting inside the canopy and causing me to add tail weight to an already heavy plane.
Also, has anyone compared the flight of this plane to the hangar 9 twin otter? The twotter can handle a single engine failure without a huge cause for panic, but other than that, I wonder if the feel of flight will be similar?
Hide Signatures
       Post #: 2932
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/14/2012 8:40 PM
cobi.p
Score: 100
Last Login: 3/27/2013
Status: offline
I do not see any problem with these engines, you need only coordinate their installation ,that it all, I am flying with two engines RCV91-CD and it work wonderful , was a bit of work to match them but not something special, he flies very well on one engine to . i use 2 APC 3 blade 13/8
i believe in " KISS " (Keep It Simple Stupid)
flying c.m.p P-40 1.20 building the don smith B-24 J 1/9
Hide Signatures
(in reply to Fidelity101)
       Post #: 2933
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/15/2012 2:17 AM
Speedracer2112
Score: 100
Last Login: 6/10/2013
Status: offline
quote:
ORIGINAL: Fidelity101
The question is the total weight of the engine since we don't know what the reference engine is. 10 more ounces than what?
You really want a light plane. Nothing flys worse than a brick. It takes all the fun right out of it.
SR
120" ASM B-17G, WingSpan Models 1/9th Scale B-17G, TopFlite B-25 Mitchell, 95" ESM B-25, TopFlite Cessna 182,
Hide Signatures
       Post #: 2934
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/15/2012 6:38 PM
Fidelity101
Score: 100
Status: offline
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAHTS&P=ML
This is my curret engine.
The extra 10 ounces was compared to a similar 72 size...but I agree that I need to compare it to the stock motor which is no longer sold. Here are the weight and measurements.
Thunder Tiger .91 FS
SPECS: Displacement: .91 cu in (14.97cc)
Bore: 1.114" (28.3mm)
Stroke: 0.937" (23.8mm)
Practical RPM: 1,800 - 12,000
Output: 1.6 HP @ 11,000 rpm
Weight: 26.20oz (742.8g) without muffler
Crankshaft Size: 5/16-24
Height from Mounting Tab Bottom to Top of Rocker Arm: 3.77" (95.7mm)
Height from Crankcase Bottom to Top of Rocker Arm: 4.63" (117.7mm)
Width at Mounting Tabs: 2.36" (60mm)
Width of Crankcase below Mounting Tabs: 1.69" (43mm)
Center of Mounting Holes Same Side: 0.98" (25mm)
Center of Mounting Holes Opposite Side: 2.05" (52mm)
Center of Crankcase to Drive Washer: 2.62" (66.5mm)
Distance from Backplate Screw to Drive Washer: 3.64" (92.5mm)
Stock recommendation: OS FL-70
- 1 cylinder
- Displacement: 0.699 cubic inches
- Bore: 1.091 (in.)
- Stroke In: 0.748 (in.)
- Low RPM: 2300
- High RPM: 12000
- 1.100 bhp @ 11000 RPM
- Weight (no muffler): 16.50 oz.
Hide Signatures
(in reply to Speedracer2112)
       Post #: 2935
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/15/2012 7:16 PM
Mustang Fever
Score: 112
Last Login: 6/13/2013
Status: offline
Fidelity:
Use em. Just break em in real good, make sure they both have a reliable idle (at least 3 minutes without loading up- this means adjusting the low end mixture), around 21-2300RPM (USE A TACH), make sure they both have a 1-200 rpm "bump" on a pinch test at WOT (USE A TACH) and make sure you're synchronized on the ground. Contrary to a lot of the info floating around, it is perfectly acceptable to get the final synch by leaning one engine slightly, but always pinch test at WOT afterward. (You also want to make sure the throttle servo linkages are as geometrically identical as you can.)
I used a pair of 55 2S, and I'm betting your 91 FS will put out about the same power or slightly more. The extra weight will help- I had to use Higley heavy brass prop nuts on mine to get the CG.
Bob Hunt
Hide Signatures
       Post #: 2936
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/15/2012 8:52 PM
Speedracer2112
Score: 100
Status: offline
The things you should consider.
1. Do you love Thunder Tiger motors?
2. Are they ultra dependable?
3. Are they worth the extra weight?
4. You you want or need the extra HP?
5. Are they new?
6. Can you sell them and get what you want?
Don't use them just because they came with the plane. Go with what you know and like on a twin.
SR
Hide Signatures
(in reply to Mustang Fever)
       Post #: 2937
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/19/2012 2:50 PM
raaf
Score: 100
Status: offline
My 2 bobs worth.I got 2 of the 70s on mine and they work great.no trouble with idle no flame outs just reliabilty.
Hide Signatures
       Post #: 2938
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 3/19/2012 4:03 PM
Fidelity101
Score: 100
Status: offline
Thanks for the information. The two 91s I have are the older style but brand new in box. I've heard they are very reliable but I think I'll run them for a while on te bench before making a decision.
I was also thinking of selling them (for sale on Rcgroups) but I'm not sure of the newer version is better or if parts are available for the older version I have. Mine goes not have anodized parts.
Hide Signatures
(in reply to raaf)
       Post #: 2939
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/5/2012 2:02 AM
agmurf
Score: 100
Status: offline
I do not have the yoke posts and control yokes to put in place. Does anyone have what came with the kit they want to part with?
I found them hiding.
< Message edited by agmurf -- 4/15/2012 8:11 PM >
Hide Signatures
       Post #: 2940
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/19/2012 11:34 PM
JBoyd58
Score: 100
Last Login: 5/26/2013
Status: offline
Does anyone have a spare used or new nose windscreen and chin set? (TOPA-1715). I dropped mine, broke it into pieces on the front.
I'll pay fair value, plus shipping cost to me! Thanks, J.B.
Hide Signatures
       Post #: 2941
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/20/2012 11:24 AM
Speedracer2112
Score: 100
Status: offline
quote:
ORIGINAL: JBoyd58
I think I do. Not positive. I'll be home in one week and I will look.
You can also check with Hobby Services. They are very nice a will send you parts from destroyed/damaged kits.
SR
Hide Signatures
(in reply to JBoyd58)
       Post #: 2942
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/20/2012 2:03 PM
RCGuy41
Score: 110
Last Login: 10/25/2012
Status: offline
JBoyd58,
Go to this site http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTFT8&P=7 you can purchase the parts for $22.49 less shipping.
Bradley T Varvel
Hide Signatures
       Post #: 2943
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/20/2012 3:13 PM
JBoyd58
Score: 100
Status: offline
I should have mentioned, I've been all over the internet. And this part is on back order until late May.
Including Tower Hobbies. I was looking, to maybe get one sooner through a post here and there.
Thanks anyway!
Hide Signatures
(in reply to RCGuy41)
       Post #: 2944
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/20/2012 3:19 PM
norm
Score: 100
Status: offline
I have that, watch me brake mine now.... pm me
Normand
Hide Signatures
       Post #: 2945
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 4/28/2012 3:03 PM
Speedracer2112
Score: 100
Status: offline
quote:
ORIGINAL: normandouellette
Normand
I have one also. If yours breaks I'll send you this one.
SR
Hide Signatures
(in reply to norm)
       Post #: 2946
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 5/1/2012 6:15 PM
Speedracer2112
Score: 100
Status: offline
I'm going to Joe Nall with my TF B-25 and my ASM B-17. Anyone else going too ?
SR
Hide Signatures
       Post #: 2947
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 5/2/2012 1:35 AM
norm
Score: 100
Status: offline
thanx, kind of you but I'll pray the seson begins here!!
nORMAND
Hide Signatures
       Post #: 2948
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 6/5/2012 1:59 PM
Jyjkoz
Score: 100
Last Login: 5/13/2013
Status: offline
I am going to satrt my build .... I purchased two os 95v for the plane . Has anyone used them in this plane yet? Will they be a good match for the B-25?
Hide Signatures
(in reply to norm)
       Post #: 2949
RE: Top Flite B-25 ARF (Tecnical, tips, suggestions) - 6/5/2012 9:18 PM
rcnut101
Score: 100
Last Login: 5/24/2013
Status: offline
95's will pull it just fine. I am fling with OS 70's and it flies scale. It does fly well on one engine.
Hide Signatures
(in reply to Jyjkoz)
       Post #: 2950
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.855RCU1
