krproton
IL, USA Status: offline
The situation with the decals is the first sheet (the one separate from the addendum) is missing a few decals (bombs, the white text that goes under the canopy on the left side of the fuselage, and a few other monor things). The decal sheet included with the addendum that says "use this decal sheet, not the other one" is improved. Also, when you get to the end of this project--the very, very end, and you are working on the instrument panel, you will notice the top I.P. (instrument panel) decal that is supposed to have clear windows over the gauges, is in fact filled in with white. What I did with mine was punch out the white "windows" with brass tubes sharpened on the end. If this doesn't suit you, we will shortly be getting in replacement I.P. decal sheets that you will be able to get through Product Support. We should have those in a few weeks.
< Message edited by krproton -- 10/25/2007 5:57:18 PM >
_____________________________
Tim Lampe Hobbico R&D
