RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Tower Hobbies
Logged in as Guest
Users viewing this topic: rslstft, Hibrass, cobi.p, mikster55
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Page: <<   < prev  49 50 [51] 52 53 54 55 56 57 58   next >   >>
Login
RE: Top Fl... - 2/1/2008 3:58:54 AM
danrc2
Status: offline
anyone who use nelson hobby hinges for their bomb bay doors, how did you get the to stick. i used a medium CA but its not holding the way i want them to. any suggestions??????????????
thanks
dan
_____________________________
GO BIG OR GO HOME!!!!
(in reply to beat098)
       Post #: 1251
RE: Top Fl... - 2/1/2008 2:07:34 PM
krproton
Status: offline
quote:
ORIGINAL: beat098
krypton, where is the pivot cup for the nose gun in the kit?
Hi beat.
I don't know where the pivot cup is packaged. As you know, there are a lot of bags in this kit! It's probably in with the rest of the other injection-molded, painted parts of the nose-gunner cockpit/pilot's cockpit. Or maybe it's in with the machine gun parts.
Tim
Tim Lampe
Hobbico R&D
       Post #: 1252
RE: Top F... - 2/1/2008 2:16:30 PM
europatc74
Status: offline
Trying to deside what to do about a remote safety ignitor. Recessed or fixed cap etc. Were to put it. Single or double etc. Anyone have pics of there setup they would like to share??
(in reply to krproton)
       Post #: 1253
RE: Top Fl... - 2/3/2008 11:32:41 PM
D_wilbur
Status: offline
I checked out the centering of my nose gear, it is centered. what I found out is that my nose gear was twisting when the wheel bumped the gear door and was jambing up. I bent the wires that holds the wheel straight and know the nose gear works smothly. Thanks krypton
       Post #: 1254
RE: Top F... - 2/4/2008 4:46:18 AM
timothy thompson
Status: offline
well look at what my daughter and her hubby found tonight. yes 4 in leg span! fort polk Louisiana yes shes a recluse!
Click to see fullsize image.
Click for fullsize
(in reply to D_wilbur)
       Post #: 1255
RE: Top F... - 2/4/2008 2:31:06 PM
dthomp8007
Status: offline
Well my kit arrived from TH with some damage so they are sending me out a new kit. I had two wing panels with 3 inch long dents and 3 dents on the top fuselage just fwd of the white stripes. I guess it really doesnt matter since I cant really start putting it together since Robarts retracts are on backorder. I guess I will spend my time emailing TF about building a GIANT F4U ARF!!!!!!
Happy flying everyone
Devin
(in reply to timothy thompson)
       Post #: 1256
RE: Top F... - 2/4/2008 2:54:08 PM
normandouellette
Status: offline
I cannot beleive that there is no descent F4U ARF from a reputable company like Top Flite. H9 make one, it flys well but lacks a lot of detailing...and no flaps. How many are we waiting for this to happen? Answer Enough to make this a profitable decision for TF. The same with this TF B-25 always on B/O and accessories on B/O must indicate some interest for a model that cost and guts restrictive for modelers ....
(in reply to dthomp8007)
       Post #: 1257
RE: Top F... - 2/4/2008 2:56:57 PM
timothy thompson
Status: offline
pin the hinges in with model railroad or dollhouse brads! I know what you mean as they did take a while to set up. remeber never open them at full speed throttle back. I have a few gaps on my lt door and will take care of it later. The holes in the hinges are for the brads.
Now you may run into the same issue i did that the top of the brads hit and the doors wont close all the way. I carefully used a dremel cutting wheel and ground down the top of the brads. The a drop of thin ca and now its fine except for a small area i need to reinforce
       Post #: 1258
RE: Top F... - 2/4/2008 3:11:57 PM
krproton
Status: offline
quote:
ORIGINAL: dthomp8007
Devin
Hi Devin.
I'm waiting for the Robart retracts too (for my second B-25!). They are due in today. I would be glad if they came in any time this week.
Tim
Tim Lampe
Hobbico R&D
       Post #: 1259
RE: Top F... - 2/4/2008 3:17:48 PM
danrc2
Status: offline
thanks tim,
i did use meduim ca and t-pin. i will give it another try.
thanks
dan
       Post #: 1260
RE: Top F... - 2/4/2008 10:32:27 PM
europatc74
Status: offline
Krprotron, any idea if TF received any replacement front gunner canopy glass. I have one on order as a replacement. Thanks Dave.
(in reply to danrc2)
       Post #: 1261
RE: Top F... - 2/5/2008 3:35:57 AM
D_wilbur
Status: offline
I have started molding a nose piece for my B-25 I was going to up load pic's having trouble.
Click for fullsize
Click for fullsize
(in reply to europatc74)
       Post #: 1262
RE: Top F... - 2/5/2008 3:38:11 AM
dthomp8007
Status: offline
quote:
ORIGINAL: krproton
Devin
Hi Devin.
Tim
Hey Tim,
Yah when I called Robart last week they said they hoped they would be in by 2-8 and over to Tower with in a day or two. I guess everything will be coming on the same day. My replacement B-25 will be here Wed.
Question for you.... With as many of us that you hear asking (sometime begging) for a TF F4U Giant ARF/ARC do you pass that up the line at TF that people on the forums would like to see that ASAP?
Thanks Tim
Devin
       Post #: 1263
RE: Top F... - 2/5/2008 5:05:45 AM
sevans16
Status: offline
Good news on retracts, I have my bird in the box still. Waiting on retracts and need to buy one more OS 81.
I would also like to see a Corsair Giant Scale ARF offered, I have the kit on standbye. I know if I ever build it there will be an arf version annouced soon after.
AMA# 737516
       Post #: 1264
RE: Top F... - 2/5/2008 5:47:37 AM
normandouellette
