fytrjok
CO, USA Status: offline
I thought I'd add a couple more thoughts...first, that last pic is not a low pass. It's a shot just before touchdown...yep, I had to belly her in because my left gear refused to deploy. Turns out that the inside gear door push rod wasn't shaped quite right and was pulling on the door when the gear were retracted(binding). The fix was easy...disconnect door push rods and retract the gear. Then close the inner door and see how the push rod aligns. If it causes any binding at all you'll have some repairs to do to the bottom of your plane if you go fly. This brings up another question. If you only have two gear that deploy, is it better to land with the gear up? I've done it both ways...with two gear down(1 main, 1 nose) the plane will pull towards the collapsed gear. Be ready for that or you could inadvertently be heading for the flight line. I chose to land with gear up and ended up spending a couple of hours repairing the sheeting and covering. After all, it does weigh 21 lbs. Anyway, I love this model...it is truly majestic in the air. I believe that 2008 should be declared "The Year of the B25". I mean with H9, TF and now KMP all releasing B25's.....whatcha' think? And by the way, the field in the pics is where we will celebrate the 5th annual "Warbirds Over Denver", June 13, 14 and 15. I know of at least half a dozen B25's that will be flying together...more if any of you guys can show up! Doug
< Message edited by fytrjok -- 2/16/2008 8:26:29 AM >
