RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Tower Hobbies
Logged in as Guest
  Printable Version
Ziroli B-25 Mitchell - 101"make firm offer - RTF
Seller:  1972stroker
Details:   $3,800.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Page: <<   < prev  53 54 [55] 56 57 58 59 60 61 62   next >   >>
Login
RE: Top Flite B-25 ARF (Tecnical, tips, sugg... - 2/19/2008 8:31:37 PM
Greg2102
Status: offline
Thanks Normand,
Two VP-30s it will be with a T in the vent line.
If the Saito 82s were sitting on their sides, the left engine with the head facing the fuselage and the right engine head facing outboard would that flex pipe work? Saito also has a part which comes out of the engine and is an immediate 90 degree angle, not the hard pipe but a fitting, I wonder if that would work?
Greg
(in reply to normandouellette)
       Post #: 1351
RE: Top Flite B-25 ARF (Tecnical, tips, sugg... - 2/19/2008 8:46:57 PM
normandouellette
Status: offline
Hey greg forget about it, not enough room I know the part and it is too big! The exhaust is level with the cowling. Sideways with the exhaust spitting to the floor would also be good but my mind works symetrical.... No matter what it will be noisy and oily...
Really no matter the set up this is the most powerful set up available for this plane @ 1.5HP each side in this size, you cant beat that. You can spin 3 blade MAS 14 x 6 @ 9000RPM and 3 blade MAS 12 x 8 @ 9900RPM. Enough power to spare very surprizingly for the size of this plane. My first feeling was that a pair of 125's would be the least but I flew this plane with the 82's and it is fantastic.
Normand
(in reply to Greg2102)
       Post #: 1352
RE: Top Flite B-25 ARF (Tecnical, tips, sugg... - 2/19/2008 9:17:00 PM
fytrjok
Status: offline
Tim,
Us guys up here in the thin air were wondering if the 70's would provide the necessary zip to motivate a 20lb+ Warbird. I think I asked that question about 15 pages ago and never received an answer. I figured it was one post you may have missed...no big deal. Obviously, since I've flown this plane successfully in Denver we all know the 70's work! I'm running a pair of the OS Surpass FSII's (because I had a pair on hand) and they are certainly adequate with the right props. I'd be willing to bet that I will come to the same conclusions as you did re: optimum proppage. However, altitude effects planes and engines significantly as we all know. What you learned by experience, I am reinforcing. Up here (5280ft.) we generally power our models with engines at the upper range of the recommended specs. Since there was no "range" given for the B25 and you convinced me that 70's were sufficient...that's what I went with. After flying the B25 a 1/2 dozen times or so, I'd say 90fs would be the maximum at this altitude. I'm sure some will engineer a way to do that but not me! The 70's work fine and sound great! The plane flys very scale at 1/2 to 2/3 throttle with the 2 bladed prop. At sea level prop choice is not as critical and flaps are a bit more effective. I love taking my heavy metal to Warbird fly-ins at sea level! It's like flying on a big pillow. I've seen guys whose elevator usage would invert their plane in a heartbeat at altitude. I believe flying up here enhances a pilot's skills, not only in flying but in building light as well. Again, you did a great job developing this B25...if it flys great up here on 70 fs's it'll be magnificent at sea level! I will be testing the MAS 12/8's this weekend. I'm hoping they give me the same pull as the APC 13/8's. I'll also be testing the APC 13/7's and I'll bet these will be the best for this plane...but the 13/8's worked very well.
       Post #: 1353
RE: Top Flite B-25 ARF (Tecnical, tips, sugg... - 2/20/2008 5:05:26 AM
normandouellette
Status: offline
Fytrjok,
Flying at 850mb is thinner air and require longer takeoff and landing run. Definitely you have this against you. It would be hard to answer the question you asked before because you're alone up there! You certainly are able to tell us more about it. My opinion is that since you run the engine leaner than at sea level, you can increase the nitro level and fly your B-25 with 12 x 8 MAS 3 blades. You will increase the torque and run your engines with 20% to 30% nitro will enable you to increase fuel consumption and get that extra power on take off. The speed is not your problem since you fly at theorically the same airspeed, but up there means this bird fly at least 20% - 25% faster than at sea level for the same airspeed.."pressurewize". Take off fly is more or less the same. Landing this plane definitely requires better skills because 25% faster on the landing speed is not to be neglected and mistake are increased by the same. I see your runway is long and brakes would be a good idea on this plane at this height
I have seen your pictures and Kudos to you, you built it nice and certainly enjoyed it.
I just spent the last week-end doing maintenance on my B-25..and after 5 flights, fine tuning it and revising all snags I must have spent at least 60 hours. I'm confident it is ready to fly now.
For the noze strut, iI placed a rubber groomet to avoid a knock on the oleo.
It is also a good idea to verify the wood bblocks holding the servos of the ailerons and flaps to acertain that they are solid as mine were broken loose on 1 aileron and 1 flap, I also placed a 2 sided foam tape between the hatch and the servo , just in case.
I agree with you for the B-25, it is a nice model and requires a TLC and lots of maintenance almost like the real thing, it is a machine!
Cheers,
Normand
(in reply to fytrjok)
       Post #: 1354
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/20/2008 12:10:25 PM
camdyson
Status: offline
Hi Normand,
Could you elaborate on the rubber grommet for the nose oleo?
thanks,
Cam
       Post #: 1355
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/20/2008 9:12:47 PM
normandouellette
Status: offline
Hello Cam,
Well it is extremely scientific and took me lots of egineering skills to develop this safety system for the front strut, and please do not reveal this to anyone! (what I said)
I remember earlier on this thread you revealed some secrets about magnets and it is good I have all kinds now. Finished are those days screw@%$ with screws, i try to see where I'll install them next, well I'll reveal this secret!
Here is some pictures of my groomet system. Sometimes the simplest is the most effective. I hope it will enable a bounce on the front strut instead of a knock and cause something to break, it has'nt been tested other than on a table but it is promizing for the cost!
Cheers,
Normand
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by normandouellette -- 2/20/2008 9:18:04 PM >
(in reply to camdyson)
       Post #: 1356
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/20/2008 9:51:24 PM
camdyson
Status: offline
Aah, very tricky. Thanks for the tip - might copy before the patent application goes through and I have to pay you.....
       Post #: 1357
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/21/2008 12:37:44 AM
RadarController
Status: offline
Alright guys... I'm kickin around the idea of getting one of these. Couple questions.. What's the deal with the engine selection? I see one guy using a couple 81's. Are a couple 70's not enough juice or is that just bling? As far as the Robarts are concerned. How many gear transitions does one air tank give?
       Post #: 1358
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/21/2008 12:44:50 AM
normandouellette
Status: offline
You will get the naswer to your questions in the first 10 pages of this thread. Hope you enjoy this plane.
(in reply to RadarController)
       Post #: 1359
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/21/2008 1:00:49 AM
RadarController
Status: offline
Anybody a promoter of Saito's? Say the 72 or 82?
       Post #: 1360
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/21/2008 2:21:52 AM
sevans16
Status: offline
Radar: the OS FS-70II have been discontinued. Not sure if the FL-70 would be the way to go(enough power). Lots of debate on the OS 70 Ultimate. The 81@ seems to be the new replacement for the 70II. A local flier has one with YS-63 and I hear it does quite well. There are a few on here using Saitos as well. Lots of choices. Just look for an engine you are familiar with or some of your locals can help you with. Since there are two engines I kept mine simple as possible to aid in reliability, ease of tuning and coordination of the two engines.
I forget all the details but: a reg air tank with 100psi?? fill is good for around 6-7 cycles. Most guys are going with the large tank. They added instruction for installing a large tank. Very simple, no worries.
Lots of info here on building if you do get one be sure and read through it all.
_____________________________
AMA# 737516
       Post #: 1361
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/21/2008 2:35:47 AM
RadarController
Status: offline
Why debate on othe 70 Ultimate? Seems like a light/reliable choice?
(in reply to sevans16)
       Post #: 1362
RE: Top Flite B-25 ARF (Tecnical, tips, sug... - 2/21/2008 3:23:51 AM
camdyson
Status: offline
There's been mixed response to these as some find harder to tune and set up, plus if you apply the KISS principle they have more to go wrong. Plus $$$. No doubt good engines if you're comfortable setting them up reliably. Ditto YS.
Since the 70 Surpass' is gone, the FL 70 ought to do fine - 81's even better but $$$$$.
Norm's Saitos sound a good option too, I just like OS (got a couple of the last 70 Surpasses luckily).
So long as it's oily and noisy (hi TT ), any of these are good once set up I'd expect.
Cam
