MLDELARUELLE
Joined: 4/28/2004 From: V - S - F - FRANCE, FRANCE, METROPOLITAN Status: offline
Hi Howard, If you connect your batteries in parallel, if one cell one one battery fail, the second one will discharge in the first. I intend to use this : http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAFM9&P=7 When the first battery is discharged, a led blink. For the retract, I choose the Eurokit brand. First because I have already theses retracts. They fit. And with theses retracts, without pressure, the retracts are locked down. To retract gears, it use air pressure. To extend gears, it free the air. Then a spring locked them in down position. In fact, I don't like robart retracts because of the pressure needed to extend (ok with the failsafe unit, the pb is corrected). And because the bottom of the retracts are in a (strong) plastic. Best regards ML
