MLDELARUELLE
Joined: 4/28/2004 From: V - S - F - FRANCE, FRANCE, METROPOLITAN Status: offline
Great Video ! Perhaps, in my humble opinion, you fly too fast. What are the engines ? Do you fly flull throtle ? On the other side, I need help about the retracts. I've mounted Eurokits retracts. They fits, but I have a problem for closing the traps with the legs. If there is no traps and lever, the retracts retrats (!) well. If I set the lever, the leg push the lever, but not full movement , except if I set the speed retract using the valve to 100%. In fact, the spring to expand the retract is very strong in Eurokits, so the force inducted by the air pressure is not strong enough to close the retract. I've tried with 3.5 bars of pressure in the tank. Which pressure do you use ? I would like to know if there is a similar pb with the Robart's retracts ? And how to solve it ? Does anyone tried another way to close the gear doors ? Thanks ML
< Message edited by MLDELARUELLE -- 3/29/2008 11:12:27 PM >
