krproton
IL, USA Status: offline
quote:
ORIGINAL: morganew OK Guys, I am in an absolute panic. I've recently started building my B-25 in earnest. I was attempting to hook up the throttle control linkages to my O.S FS-70 Ultimate (yes the ones with the pump). Turns out the carb arm needs to be reversed (as was also true for the FS 70 Surpass II). Problem is, I see no way possible to reverse the arm on this engine. I removed the one mount screw, but the carb is asymmetric. It seems impossible to reverse. If this is true, then I really need to to complain to both top flite and Tower Hobbies. This was the engine that was recommended by Tower Hobbies as the replacement for the Surpass II for this ARF. I am hoping that I am absolutely wrong on this. I cant be the only one using the ultimate FS 70 on this plane. Please someone put my mind at ease. I am hoping KProton, will chime in here, or norm will chime in here..or anyone. Do I have two brand new useless FS 70 Ultimates? Say it isnt so... thanks guys. Hi morganew. First, sorry to put you in a panic. I don't have the resolution here at my fingertips as I have read your message from home, but I can troubleshoot from work tomorrow. But here are a few things...several reviews were done on the B-25 with the same engine as you. I don't know what they did with the throttles, but no mention was made of the situation, so presumably they figured out a reasonable solution. Second, have you considered the alternate throttle servo location? The one on the bottom of the wood nacelle? This may put your throttle servo in proper alignment with the carb arm. That's all I can think of for now. Tomorrow from work I'll get an Ultimate and look into this for you. Please stand by. Sorry. Thanks. Tim
_____________________________
Tim Lampe Hobbico R&D
