Robert 111
Joined: 11/10/2006 From: edmonton, AB, CANADA Status: offline
Tim, Here are my tips and suggestions, I hope some find them useful. #1 Those rare earth magnets in the kit worked so well holding the nacelle hinges in place while the glue set, I ran out and bought a bunch more of them, so I could do more than one at a time. #2 The optional OS exhaust headers available, OS Part # 7210900, will allow you to hide the mufflers inside the cowls. #3 “ Markal “ Paint Markers works very well on the tips of those black props, it’s durable, easy to apply and to touch up, the yellow matches the cowls and prop hubs as well. #4 Installing a switch on the retract servo will lock the wheels down when the plane is parked. And may save you the trouble of having to repair all those doors. #5 Reliable idles and good response is very important with multi engine set ups. This is much easier if you break in your engines and find their optimal settings, one at a time on a flying test bed like a trainer. # 6 One engine will always be stronger than the other. I like to put the stronger on left side and richen it up to match the RPM on the right . Never, never, ever, lean out the weaker engine to match the stronger!!! # 7 Coupling your rudders and ailerons (about 20% is a good starting point), will insure the proper rudder response if an engine should quit. I have had times with other multi’s when I had no idea an engine had quit until I could see the prop wasn’t turning. # 8 Keeping the weight down on any plane will make it a Joy to fly, rather than a Challenge. The B-25 is no exception. Less weight equals less stress for both the pilot and the plane. I Hope These Help With Many Happy Landings, ROB
