RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: Top Flite B-25 ARF (Tecnical, tips, suggestions)
Page: <<   < prev  58 59 60 61 [62] 63 64 65 66 67   next >   >>
Login
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/12/2008 12:55:24 AM
krproton
Status: offline
Toreo,
thank you for the video. Congratulations! Your B-25 looks nice and I hope you enjoy many successful flights. Be careful you don't crash into the boy on the runway!!!
Tim
_____________________________
Tim Lampe
Hobbico R&D
(in reply to toreo)
       Post #: 1526
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/12/2008 5:08:44 AM
kochj
Status: offline
Looks like a real p*u*s*s*y cat to land!
Winning isn''t everything, it''s all there is.
(in reply to krproton)
       Post #: 1527
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/12/2008 6:51:08 AM
toreo
Status: offline
quote:
ORIGINAL: chris923
Toreo:
Does your B-25 have a Gyro in it?
Chris
No! I did many times tested my twintrainer with gyro on rudder, and had only positive opinion about gyro in case of single engine out.
But i newer used any gyro in new model. On next flight session i will use gyro on rudder and ail.
IMHO, right preset of rudders is help no less than gyro, in case of single out. Left rudder set 2-3 degree to left, right rudder 2-3 degree to right.
(in reply to chris923)
       Post #: 1528
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/12/2008 9:53:19 AM
camdyson
Status: offline
Toreo,
What engines are you using? Look a bit like Enyas?? Curious since it coped on one so well. Thanks for the video.
Tim,
You'll have to wait a bit longer for the "finished" shots - I build ARF's a bit quicker than the Chinese built the Great Wall....
Cam
(in reply to toreo)
       Post #: 1529
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/12/2008 10:31:23 AM
toreo
Status: offline
quote:
ORIGINAL: camdyson
Toreo,
I use OSMax-FL70 with 3 blade 12x6 MAS prop. When left engine out, i make circle on full throtle right engine.
(in reply to camdyson)
       Post #: 1530
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/12/2008 12:16:41 PM
camdyson
Status: offline
Wow - that's VERY impressive for one FL70 on a 3-blade prop! Good flying too Thanks for the info' - the FL's look like a good value powerplant for this plane.
Cam
("RUTUBE"....he he he!..... )
(in reply to toreo)
       Post #: 1531
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/12/2008 2:48:11 PM
normandouellette
Status: offline
This is how it flys but toreo seems to have flown it in much relaxed manner!!!!! Amazing and good contlol. This is the loveliest plane I own, and those videos prove it is the best every time. I cannot wait to get up to date with my video downloading skills and it seems that the resolution is too high and make extra large documents. I will get help and post another video to add to this list.
toreo, ,
Normand
       Post #: 1532
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/12/2008 3:27:23 PM
toreo
Status: offline
Thanks, Normand! It is awesome plane!
(in reply to normandouellette)
       Post #: 1533
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/13/2008 2:19:09 AM
PHague80
Status: offline
quote:
ORIGINAL: camdyson
While I've got the 'ol camera in the workshop, I'll add a few others - the gimbal was just detailed a bit and repainted, bomb bay is sealed awaiting final paint, bomb door inners ready to be attached, plus a few of the aluminium tape added here and there. The hatch in the bomb bay floor (roof?!) is the gyro mount - it's stuck to the other side. Note no Nelson hinges as there's some problem with supply, so used up a few large Dubro pinned hinges.
Next step will be to add panel lines and steel-wool the lot, then prep and airbrush all the aluminium and assorted exhaust stains, panels etc. Once done, will weather and seal. ('Scuse me borrowing some of your techniques fytrjok!) Oh, and the missing outer fuel caps!.....
Cam
Oh, thanks to one of our other contributors for the rear cockpit and turret images - sorry I don't have your name in front of me.
Where did you find the pictures of the interior of the cabin behind the cockpit and upper turrent? I would like to do something similar to my Mitchell
Pete
       Post #: 1534
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/13/2008 2:29:24 PM
camdyson
Status: offline
Lyle who posted elsewhere in this thread (I think) did them - his email is lylevasser@yahoo.com
Ask him how his pilots are coming along too - he's an amazing sculptor.
Cam
(in reply to PHague80)
       Post #: 1535
RE: Top Flite B-25 ARF (Tecnical, tip... - 5/17/2008 1:02:36 AM
timothy thompson
Status: offline
cobi here it is! i started on pages 20 i think
       Post #: 1536
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/17/2008 1:28:02 AM
timothy thompson
Status: offline
interesting interior a pic! i put all that in there and your idea is really nice. with the glass on you cant tell anyway. school is done may 30. I just recieved my rivet tape to finish but im gonna fly her first! My wife has to go out and help me lift the plane after the outer panels are on. I fly alone and there is no way I can handle this on my own. shes never seen me fly anything except helis. i can get the fuse and center section out of the van and add the wings. But flipping it over requires two people. ill fill the air tanks hook up all the lipos and secure everything when the plane is upside down. All I need to do is get it turned over and fly.
       Post #: 1537
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/17/2008 6:26:10 AM
cobi.p
Status: offline
hello tim
i like to put 2 RCV .91 CD in the TF B-25 .
is it O.K ? .
thanks - cobi
i believe in " KISS " - ( Keep It Simple Stupid )
building the don smith B-24 J 1/9 scale
       Post #: 1538
RE: Top Flite B-25 ARF (Tecnical, tips... - 5/17/2008 11:33:57 AM
normandouellette
Status: offline
RCV91...
I'm not tim but if you permit, you will have to spin a 13 x 8 3 blade MAS with this engine. will fit in there, a buddy of mine did it.
Normand
(in reply to cobi.p)
