smarks
CO, USA Status: offline
quote:
ORIGINAL: Paul Cataldo Hey guys, I've got a question about the DA85 throttle setup, that I'd like to ask you all. I was wondering how many of you are hooking up the pushrod to the throttle with a 2-56 ball link, and how many of you are hooking up the throttle with a 4-40 ball link??? Is that what you guys are using? (regular Rocket City or Dubro styled ball links with the black nylon slipped over the brass ball with hole drilled in it?????) OR Are you guys using the other type of ball links, where you have the spherical brass ball "post", where the clear plastic nylon part slips over the brass ball? I have noticed that even a 2-56 Rocket City type ball link is VERY tight fit, and only allows the throttle servo to be mounted in one specific location. Not a big deal, but I just wanted to see how everyone else hooked up their throttle pushrod????? I cannot even find a Nelson Hobbies 2-56 ball link, part # RCL77B. Anyone know where I can find one??? Nelson does not have any in stock right now....I would prefer the Nelson 2-56 ball link, instead of the Dubro one..... Prolink with 4-40 ball links that came with the bird. Works great, but I did have to dremel a little off the engine mount because the ball link would hit it at full throttle.
< Message edited by smarks -- 3/2/2008 1:05:39 AM >
