RE: CEN Racing Cares
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> CEN Racing Support >> RE: CEN Racing Cares
Page: <<   < prev  1 2 3 4 [5] 6   next >   >>
Login
RE: CEN Racing Cares - 2/2/2008 4:38:57 AM
muck76
Status: offline
quote:
ORIGINAL: RCnut771
Please, Please make a 2 speed available for the MG 16. That would be awesome! also a trick looking anodized cooling head would really add to the truck. The MG 16 is embodies what I think is very clever engineering and I would like to see more optional parts available so I could further exploit the abilities of this amazing little nitro RC
Thanks, look forward to your reply
i am all for a head and a tuned pipe of sort.
(in reply to RCnut771)
       Post #: 101
RE: CEN Racing Cares - 2/2/2008 4:43:52 AM
egiggy
Status: offline
How fast does a stock mini mg16 go?
(in reply to muck76)
       Post #: 102
RE: CEN Racing Cares - 2/6/2008 11:02:16 AM
wriffwraff
Status: offline
Finally, I have the time to post the results of the previously noted set up change(s). I experienced positive improvements with the 10/20/5 set up. So much so, that I don't see a reason to change it up anymore when running on small to medium tracks locally. The truggy performs and handles very well with that diff oil configuration. The only other modification I made was the 70 weight shock oil up front. That did not work at all The truck would not jump or land properly nor would it handle the ruts or bumps. The 70 with oil up front proved both entertaining and hilarious I switched back to 60 weight up front and I plan to try 55 [if it exists] or 50.
I would also like to take this opportunity to rescind my earlier suggestions and posting to cen manufacturing regarding the steering of the cen matrix truggy, as I have since discovered that the turning issues were due to improper front linkage set up, as well as improper transmitter set up. My linkage's [ steering, ackerman and upper arms ] and radio [ steering trim ] required tuning adjustments, as they were a bit out of synch. In short, I've come to appreciate the fine art of tuning caster, camber, toe in, shock positions, shock dampening, ride height, droop and most of all " STEERING TRIM " I mean, the steering trim alone solved most if not all of my " this truggy turns way too wide " issues I felt like a totally noob when I figured the steering sub-trim function out on my radio. The right and left steering end-points were maxed out at 125 each, however the steering dual rate trim which controls the " maximum servo travel " was only set at 70% So in my case, that was 70% of 125% left and right steering. Until I read and understood page 25 of my Spektrum Dx2.0 radio manual, I had no idea that I could inrease or decrease the radius of the steering servo. So for the past year now, I've only used the " Steering Trim " . I had totally overlooked the " Steering Dual Rate Trim Adjustment " All things considered and understood, I immediately decreased my left and right steering endpoints to 100% each [ left and right ] and increased the percentage of the dual rate from 70% to 90% The wheels are almost at full lock at that setting and I can continue to tweak it at the track if at all necessary. So now that I understand " dual rate trim ", I imagine that my Cen Matrix Truggy now turns as sharp as, if not sharper, than any other truggy on the market
All things considered, perhaps an apology is in order to cen and to this forum, as it appears that my " steering " and " turn in " issues were an oversight on my part. Please excuse me
I don't know, I guess I just wanted to run my truggy for the past year. However, I now understand and respect that you can't run properly, unless you've tuned properly. So to start, I've read and bookmarked online set up articles for the past couple of weeks and I ordered a truck camber tool today
< Message edited by wriffwraff -- 2/6/2008 11:04:18 AM >
_____________________________
.21 Axe Rossi Mamba & .26 Sportwerks engines/JP3 pipe/Dx2 radio/Hitec 5955TG & JR9000T servos/5F/20C/3Rdiffs & 60/50shocks
(in reply to Andrew Smolnik)
       Post #: 103
RE: CEN Racing Cares - 2/14/2008 12:32:42 AM
Status: offline
We are happy to hear of your discoveries and we hope you have a great time with your car! Appology accepted.
Best Regards
CEN Racing - www.cenracing.com
(in reply to wriffwraff)
       Post #: 104
RE: CEN Racing Cares - 3/17/2008 9:29:57 AM
Mr Terminator
Status: offline
How about some fresh bodyshell designs for the MG16...?
2xGenesis/2xMG16MT/VRX-2 Pro/HB Lightning GTX2/NB16T/Micro T/HE 1:16 M1A2 Abrams.
(in reply to CEN Racing)
       Post #: 105
RE: CEN Racing Cares - 3/19/2008 9:50:49 PM
slawhammer
Status: offline
I have a problem with one of the people who supply your products(CEN) www.headrushhobbies.com I ordered a product over 15 days ago.
paid with Pay Pal and even e-mail them ..but no responce from them..I would not send or advise other people too them for any thing...
I do not think I would ever order any thing from them again...Yes Cen Direct did not have what I wanted to order..So maybe Cen will look into this.
I am sure other people have had the same issue with headrushhobbies...I have read in different forums ahout some issues ..
Proud Owner of Genesis GST 7.7 truck ...NX76 Engine
Proud Owner of 1/5 Scale Big Foot/FireHammer 29 CC engine
(in reply to Nick2618)
       Post #: 106
RE: CEN Racing Cares - 3/21/2008 4:59:43 AM
trarena
Status: online
quote:
slawhammer Date 3/19/2008 9:50:49 PM
Hey dude, kinda surprised to hear you say that about Headrush Hobbies. I'd suggest you send a pm to Robert Hull. He is incredibly helpful on every forum I read.
C2X PRO BCE Arena, Ninja CEO B01A & MRT GRP .21, 2053 FLR pipe, Hitec 5955TG & ACE 1313, DX3R, Proline LPR''s, Rulux rims
(in reply to slawhammer)
       Post #: 107
RE: CEN Racing Cares - 3/21/2008 5:13:42 AM
The Real Dogman
Status: offline
LOL yeah Right!!
quote:
ORIGINAL: trarena
< Message edited by The Real Dogman -- 3/21/2008 5:14:35 AM >
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Matrix Arena/Wheely King Tuber/Axial AX
(in reply to trarena)
       Post #: 108
RE: CEN Racing Cares - 3/21/2008 3:16:55 PM
slawhammer
Status: offline
Hey Traena..Well like I said.. I e-mailed them 3 different times ..no reply..I called on the phone like 3 different times..no reply or would not answer phone...I even took this to CEN direct. Yeah some people
want you too buy there product..which is good..But people who sell OEM parts and then do not stand behind them are another story...Look Cen Direct and Cen support have been very good when I talk to them on the phone....No Problem with CEN Direct....It is not the first time with people who sell Cen products for Cen..That I have had problems with...Just like any thing else make the Company aware of the problems with those poeple...And Get the Company involved to clear future issues if they come up ...CEN after all wants people like my self and others to use the correct Parts for there Rc trucks and cars.
Do you understand now my friend....But thanks for your intrest in this issue......Feel free to Pm or e-mail me if you wish....
EDIT: Up Date on this ... Hmmmmm after talking to Cen Direct who in turn talked to headrush via phone..What do you know... I got a phone call from the people at headrush..My Issue will be taken care of.
Seems like they lost my order placed to them...Only took 20 days...So some times you have to do what you have to do to get things done..That is bring the main company in to the issue...
< Message edited by slawhammer -- 3/22/2008 12:03:53 AM >
(in reply to The Real Dogman)
       Post #: 109
RE: CEN Racing Cares - 3/22/2008 10:52:59 AM
derrick05
Status: offline
Theres no doubt that CEN is the king of the big trucks The GENESIS/NEMESIS/MATRIX are unstopable.They are the biggest fastest toughest vehicles in the industry,and I thank you for that,but all of your smaller trucks are a little on the flimsy side Just wondering if CEN would consider producing a 1/10 truck with GENESIS/NEMESIS quality and durability.There are a few worthy 1/10 trucks out there but unfortunately,CEN is not one of them,but I know you guys could make the baddest 1/10 on the planet if you would just go ahead and put it out there Dont get me wrong here,I know you need to keep something in every price range.I know everyone cant afford one of those big trucks,but maybe some of us would be willing to pay a little more for the meanest,toughest 1/10 on the planet
       Post #: 110
RE: CEN Racing Cares - 3/24/2008 8:12:57 PM
burningpoo
Status: offline
quote:
ORIGINAL: Andrew Smolnik
...but hobbyists that enjoy building kits are becoming a rare breed.
That just sucks.
Here's what I have for the GST...
Boot for the rev lever.
Can the front drive shaft and replace with nemesis.
Performance exhaust, might have to put a loop in it to help clear shocks/tower to keep it free flowing.
Street tires would be nice.
Different rim size, but tires that make it the 55 series size. Trying to give the truck a monster truck look, just wondering if they would stay glued though.
Had one more but forgot...
The first 3 I would really like to see.
{edit's edit}
This one is really needed, stronger plastic shocks, leaking threads sucks but is a easy fix with teflon plumbers tape...
< Message edited by burningpoo -- 4/14/2008 5:32:12 PM >
Taking unbroken toys aparts since 1981
       Post #: 111
RE: CEN Racing Cares - 4/17/2008 12:10:28 AM
Status: offline
Thanks for the great suggestions... they have been forwarded to R&D
Best Regards
(in reply to burningpoo)
       Post #: 112
RE: CEN Racing Cares - 4/28/2008 4:21:32 AM
off-road jato
Status: offline
Just got my gst 7.7 today (hands still killin me from pull starting), i broke it in as directed. the rear brakes were locking up when i let off the throttle, and front tires seem to be the only ones pulling. i let tension off of the rear brakes, front tires still doing the same. noticed that a bag came with the center diff lock wondering if this will fix the problem. and i was wondering if anyone has taken the exhaust baffles out and if it is better. thanks.
Jato 3.3 + hop-ups = Off-Road Jato
       Post #: 113
RE: CEN Racing Cares - 4/29/2008 5:20:46 PM
burningpoo
Status: offline
quote:
ORIGINAL: off-road jato
You might have to take the horn off the servo, reset the servo and put the horn back on, addjust brakes again. I took that baffles out of my truck, only problem is it leaks from the center of the pipe, going to put some auto gasket maker in there soon to see if that will seal it up. If this doesn't work, and you have a digital camera, puts some pictures in the forum under a new post telling about the problem and what all you have done.
Someone used a magnum condom with the center cut out to fix there leaking center exhaust problem
(in reply to off-road jato)
       Post #: 114
