Whistling Death
AL, USA Status: offline
quote:
ORIGINAL: Antique OK, I got permission from my good customer antique to use his log in info...And will NOT do it again.... Pettit, there's enough BS floating around in here without adding to it..Anyone who writes for a magazine should maybe do a little research before posting false information...My conversions, the VERY FIRST ever done to the G26, are COMPLETELY plug and play...You do, however, have to plug the battery connector (supplied) into the side of the engine...the complete ignition circuit is built in to the rear engine case..The spark coil is relocated to the space behind the cylinder where the source coil was...The prop stud the sometimes breaks off at the crank is replaced by a two piece UNBREAKABLE hub that uses a grade 8 prop bolt...The carb is rotated on a 3/8 G10 insulator block..The carb comes with a small arm bolted on to the shaft at the bottom of the carb, close to the center line of the engine..PLUG AND PLAY.... I'm out of here .. Ha Ha, who say ralph doesn't post here anymore?
_____________________________
CORSAIR Brotherhood Lucky #13 AMA# 856000
